dump valve need help asap plz
Old Jun 10, 2009 | 02:36 PM
sams td's Avatar
sams td
Default dump valve need help asap plz
ive bought a dump valve for my 1.8 td endura and havent got a clue where it goes can someone please tell me where it goes and what i need plz ??
im gettin so stressed over this :/ need some help big time lads
cheeRS
Old Jun 10, 2009 | 03:24 PM
cozmeister's Avatar
cozmeister
More boost Igor!
1.8 TD? Diesels don't have dump valves because there's no throttle plate for the compressed air to get stuck behind...
If you did want to hook it up, you need a hose from the inlet manifold to the vaccum connector on top of the valve. The valve needs to be situated between the outlet of the turbo's compressor housing and the inlet manifold. The hose on the exit of the intercooler (if you have one) would be suitable.
Old Jun 10, 2009 | 03:46 PM
sams td's Avatar
sams td
cheers m8 it has a top mpunt intercooler. if i got a t piece and put it between the outlet of the intercooler would that be ok and would i need the top hose or would it be ok through the bottom?
Old Jun 10, 2009 | 04:01 PM
cozmeister's Avatar
cozmeister
More boost Igor!
You can mount it either 'side' of the intercooler.
But don't forget you need the vacuum port on the valve connected to the inlet manifold for it to do anything. A pic of your engine bay might help.
Old Jun 10, 2009 | 08:23 PM
sams td's Avatar
sams td
ok m8 cheers
its the same engine as this --- http://cgi.ebay.co.uk/Ford-Endura-DE...3A1%7C294%3A50
cheeRS
Old Jun 11, 2009 | 12:28 PM
rs combi's Avatar
rs combi
cheeRS
get on to the derv doctor he dose the kit for td's mrs has one on her 306
theres a solenoid linked in to the brake servo to get the vacume to open the dv uses a microswitch that is activated when you back off the throttle
sure he will be able to sort you out
Nov 1, 2015 06:53 PM
DAZZER
Sep 30, 2015 08:43 PM
fordrallycar
Sep 30, 2015 07:57 PM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
