oil pressure and volt gauges
Old May 31, 2009 | 09:03 AM
lianneFRST's Avatar
lianneFRST
Default oil pressure and volt gauges
im fitting a electronic oil pressure gauge into my sierra 2wd cossie unfortunatly no instructions can anyone advise me how to wire it up ive fitted the adaptor to the block but now iam at a loss
also i have a volt meter and also not sure how to go about wiring it up?
any guides would be most appreciated
Old May 31, 2009 | 04:04 PM
Voltmetre is simple negative and positive, depending on whether you want it to read all the time or just when ignition on wire accordingly, may also have a backlight to wire in, same again neg to earth, live(for bulb) to sidelight circuit light, from ciggy lighter etc.
The oil pressure gauge again will have a backlight so wire this as the voltmetre is, and then on the adaptor you need a pressure sender, to give the variable earth to the gauge, the other gauge wire live will be connected to an ignition controlled source.
Old May 31, 2009 | 08:08 PM
LHD220Turbo's Avatar
LHD220Turbo
most will only have 3 wires, feed (red), earth (black), illumination (orange or green)
but i worn you that electroinc pressure gauges are shite, much better with a mechanical one
Old May 31, 2009 | 09:28 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
yep second that, they look the nuts but hard to see exactly whats going on......
Old May 31, 2009 | 09:31 PM
LHD220Turbo
yup, and more often than not, inacuratre too
you also need to make sure the sender is the correct one for the gauge, because you cant mix n match senders and gauges
Old Jun 1, 2009 | 07:07 AM
Why this crap is always spouted about innacurate gauges purely because they are electric is beyond me.
There is no reason why a lecky one should be any less or more accurate than a regular mechanical one, so long as it has a matching pressure sender, and your regulator part of the alternator works perfectly.
They will normally use either a thermal pressure transmitter and indicator(gauge), where a analogue signal will be produced and represented on a gauge showing pressure, the signal produced is directly proportional to the pressure applied inside a pressure sender by the diaphragm contacts and heater coil.
A more expensive type will use a piezo crystal but where again pressure applied will induce a differing voltage across a fixed value resistor which again is directly proportional to the oil pressure.
I don't think most people are after accuracy down to 1/1000 of a psi, I have el cheapo TIM gauges, that is within 2psi of actual at 13.8 volts which I think is close enough, epecially when you consider the engine has been at that pressure all the time, the only difference is now with a gauge you know it, it worked before with the same pressure.
Old Jun 1, 2009 | 04:54 PM
lianneFRST's Avatar
lianneFRST
thanks for the replys, i was told the mechanical are a risk due to having a oil line running from the engine to the gauge hence why i opted for electric
Old Jun 1, 2009 | 05:14 PM
There is of course a risk with a line carrying oil, in case it breaks, but just put 5/6 coils in it just where it goes to engine, this will minimise any vibration and be ok then, I use a bit of tube and wrap it around it gently to shape.
IainRS1700T
Sep 25, 2015 06:44 AM
dombanks
Sep 21, 2015 08:38 PM
Brickhouse
Sep 21, 2015 11:00 AM
tib2220
Sep 14, 2015 12:33 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
