focus TDDi help
Old Jun 2, 2009 | 07:00 PM
white2lsr's Avatar
white2lsr
Default focus TDDi help
Oil around the intercooler pipes. Should I be concerned??
cheers for any help.
Old Jun 2, 2009 | 08:38 PM
dan-dan's Avatar
dan-dan
It will be normal, always get it on diesels but try retighening the hose clips if you can.
Old Jun 2, 2009 | 08:56 PM
steves24V's's Avatar
steves24V's
As above see it loads when servicing them at work i normally give the hose clips half a turn and clean the oil off job done.
Old Jun 2, 2009 | 09:10 PM
dan-dan's Avatar
dan-dan
i see that aswell at work, trucks do the same just tighten and wipe clean sorted
wowk
Mar 30, 2021 07:49 PM
tankybaby66
Feb 6, 2016 02:24 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
