- Ford KA 1.3 8V Duratec P0030 Fault Code
- mk4 fiesta overheating
- Sierra Cosworth 2wd rpm counter not working ...
- 03 Focus Sport TDCI Problems
- Focus 2.0 TDCI 06 REG
- Cooked CVH
- Decompression Zetec Turbo
- What oil to use?
- Repairing a loom..
- focus keeps cutting out
- FRST Front Bumper help
- S2 Misfiring Higher Revs
- mt75 box oil seal
- zetec turbo advice
- Sierra Sapphire cosworth buying/maintenance
- spark plug gapping
- Diesel AFR's- Diesel Tuning.
- fiesta mk4 brake pedal has become hard - help! first post on this site
- s2 rs turbo KE
- cosworth cv joints help please
- cosworth relay
- Torque bolts on flywheel
- st24 gaskets
- Likely culprits? n/s steering knock...
- alternator bracket alternatives
- Over-revving and high idle on Mk1 Focus
- Anyone know what this is for??
- Recaro seat repair
- ST170 Global Window Open/Close
- Engine enquiry?
- Crossflow rebuild
- Clutch issues
- Cometic MLS Phuzion Head Gasket Ford Cosworth YB
- wiring problem on mk5 xr3i cabby .plz help ppl !!
- correct valve to guide clearance
- Focus ST170 drive shafts - Are they the same as the other models?
- Focus 1.8 zetec e blacktop upgrading cams
- Auxiliary air valve
- 2.0 TDCi
- Boost peaking and dropping
- injector cleaning
- Mk 4 Escort boot
- modded car but filler cap comes off?!?!
- Were and what to buy
- Will an rs turbo head run on a carb engine?
- can i take the abs of my 2wd cossy
- Fiesta Turbo Engine Conversion into 2I
- zetec install
- o5 plate transit 90ps stutters on full throttle
- Please Help Mondeo mrk 2001 TDDI fault codes
- sierra cosworth brake lights
- Lost the keys to the immobilizer
- zvh
- fiesta diesel
- escort Mk6 abs light wont go out
- Smokey
- Escort diesel van, rear brake adjusters
- cossie rocker gasket
- 2002 MK3 Mondeo Dashboard test.
- s2,automatic choke sticking on help please!!!
- cossie oil leak.
- Gear difficult to select when hot
- S2 Missing Up Revs
- Xr3i vacuum hoses
- S2 Alternator Issues
- YB won't run
- cannot get rearprop shaft to fit black 50p??????
- Weird Cold Start Issue with Focus
- rear diff???
- escort diesel compression
- Wiring an AMP meter gauge - help !
- Engine systems fault
- 2wd Diff mount fitting problems??
- Battery in boot , what tray ?
- rhd light
- 99 Escort Van 1.8 non-turbo - Wont start...help!
- Ka project... Little help please :)
- Gear change for Sierra Cosworth
- Zetec on bike carbs won't start
- motor swap
- HELP with my escort 1.8si
- Zetec Turbo Oil Return Pipe
- capri dials?????? help!!!
- 4x4 car loom in 2wd saff
- poorly ganada
- S2 Escort rs turbo non start
- pistons RS 1800???
- Cosworth YB 205 Spark plug Problem help needed
- How much
- knackered my 12v power supply
- Fuel Injection Pump Help -DESPERATE!!!!
- Converting 4wd to Rwd
- Zetec cam specs..
- help needed in the lincolnshire area
- Fiesta 6000 CD Player Code
- ECU Swap
- i need help fiesta rs 1800
- cossie fuelpressure
- mt75 gbox cradle??? escos rwd conversion.
- Advice on porting a head
- Cosworth computer with white screw l1 or l6
- rwd escort cosworth prop???
- escort cosworth front propshaft uj
- electric windows
- Priming Hydraulic lifters.
- Which sump gasket
- after market fan controller
- idle valve mk6 escort
- mkII escort bias pedal box setup
- How to remove seat cover and sponge on MK6
- fitting 4x4 intercooler?
- Alternator question
- fuel pressure
- Fiesta Ghia 1.25 Zetec S reg 1998 Rear Wiper Not Working - Can Anyone Help Me Please
- weird goings on :(
- kxf250 hard to start
- Oil cooler adapter bolt
- T Reg Escort Turbo Diesel Van help please...
- Help me please
- Reusing engine bolts
- black top engine mount
- Rs Turbo Slight Misfire
- st170 cam actuator whitch is + and - and when should cam kick in?
- f reg sierra front speaker size
- Dipstick length
- 4x4 Fuel regulator adaptor
- zetec clutch
- Mk4 Fiesta Stoppers..
- Stuck in ireland. PLEASE HELP
- indicators
- rs2000 with 1.4 gearbox
- Violent shuddering under braking above 60mph
- Help Fiesta RS 1800 16V 130 BHP
- CV joints ..
- rs turbo piper cam bp285t
- ka help
- Mk3 Fiesta with 'Herbie' like steering !
- swopped ecu and car wont fire up
- Air con will not switch off properly on 02 focus
- St170 head gasket
- Which ecu?
- efi xr3i temprature problem
- what oil for first startup rebuild zetec?
- what clutch
- HELP !! S2 alternator - wiring
- Spongy brakes again!
- central locking problem on focus mk1
- cisbo reversing sensors
- General turbo conversion questions...
- Mondeo MK1 Emissions
- How hard to do rs2000 mk5 head gasket
- MK1 Focus RS turbo rebuild options for the Orion
- few things...
- s2 rs turbo cut out and will not start
- code needed for stero
- Squeeky Poly Bushes
- mk1 focus central locking problem
- Oil breathers
- Escort RS Turbo Radiator?
- 300 bhp Cosworth
- 2002mk1 focus rear wiper
- ht leads are wrong
- advice needed
- XR3i headlight problem
- Gearbox oil leak
- Help needed
- Ford smax 2.5l turbo petrol flywheel bolt torque
- Which standalone is better?
- brake light problem
- escort mk2 mexico putting redtop xe in do i need a header tank
- mk2 orion window door seals where from?
- help im a dumb ass
- 2001 Mondeo Zetec S 2.0 non starter/ poor runner
- Caliper seal kits and uneven brake pad wear
- Fiesta MK4 Auto to manual
- Bike Carb Options
- Will Escort cosworth front calipers on an rs turbo
- st10 seat swap
- fiesta mk4/5
- Unstable saph
- Which dipstick
- wiring loom
- Wiring loom
- Anyone in essex
- Engine cutting out and restartiong problem
- Trip Computer problem.
- 97 escort 1600 brake light/instrument lights fuse location???
- Heat Shielding
- Help!!! White Smoke
- Radio wiring help wanted
- Dreaded Wax Oil/Under-seal
- morettes
- What is needed to remap a MK1 Foucs RS ECU?
- zetec ecu code also
- Capri Engine Conversion
- Cosworth fuel rails, are they the same?
- Cosworth Stalling
- Reshell cosworth
- MK4 Fiesta....
- what zetec engine is this?
- Escort RS turbo running on 2 cylinders
- M.O.T Fail. Help on parts to buy/How to fix
- Cams & Lifters
- Cosworth dashboard electrical problem.
- mk6 brakes
- calibra turbo pistons V xe 'red top' pistons for zvh/zetec turbo
- Hhhheeeeellllpppp!!!!!!!!!!!!!!!!!!!!!
- mk6 escort hunting
- s2 overboost problem
- help i.d my ecu and chip series 2 rs turbo
- Clutch cable problems
- Focus ST170 Race gearbox
- cosworth t5 gearbox
- brembo Rs focus brake help
- clutch change questions
- ZE-NC3810 Head Unit
- head work and cam re-profiling in the london area
- Another issue with gear selection on ford escort
- 9x15 minilites / Compo ML's
- S1 turbo running issues
- mk2 escort pinto what gearbox?
- Mk 4 1300 gearbox help
- changing thermotat on 1.8zetec
- how easy of a job is a wheel bearing on a focus(w reg) to do?
- Towbar Issue. Please Help
- Cosworth ignition amp
- Bad feedback
- Poly engine + g/box mounts... Thoughts???
- idle air tick over
- boost gauge setting
- OMG help needed
- 4x4 MT75 + diff strength?
- new cosworth clutch slipping
- where to connect oil temp gauge-fiesta
- Sensor for Cosworth YB
- zetec turbo van fueling!
- Cvh rockers needed
- smelly brakes
- Engine change?
- fiesta heater problem.
- Few questions on mk4 esc cabby rst conversion
- I've got some fury shit...
- CVH cam
- mot and emissions results
- focus heater/blower problem
- pressure in my crank
- more power what engine
- ford fe to 351 engine swap
- ZVH to Zetec Turbo Mk4 Escort
