Is there any other option to connect oil temperature gauge on fiesta st except sump plug and sandwitch plate? car is fiesta st... I mean if there is sensor for oil temp allready somewhere.
These use paper oil filters don't they, so not sure if you can get a sandwich plate? Somewhere where its in the flow of oil would be best, T-piece might not give an accurate reading of temperature.
Liquid(oil) conducts heat very well, in the oil pressure switch position it will give a truer temp reading than in a sump subject to airflow, and that's before it is compressed by the oil pump and picked up more heat.
