M.O.T Fail. Help on parts to buy/How to fix
Hi there I need some help on what parts to buy or how to fix my car the bits its failed on is listed below. If it helps it was a 1.6 but now a full st170 conversion including rear disk conversion gearbox etc. Cheers
Reason(s) for refusal to issue Certificate
Anti-lock braking system warning lamp does not illuminate (3.4.1b)
Nearside Rear wheel bearing rough when rotated (2.6.1)
Offside Rear wheel bearing rough when rotated (2.6.1)
Exhaust emissions carbon monoxide content at idle excessive (7.3.D.2c)
Exhaust emissions carbon monoxide content after 2nd fast idle excessive (7.3.D.2b)
Exhaust emissions hydrocarbon content after 2nd fast idle excessive (7.3.D.2b)
Exhaust emissions Lambda reading after 2nd fast idle outside specified limits (7.3.D.2b)
Nearside Rear brake recording little or no effort (3.7.A.4a)
Offside Rear brake recording little or no effort (3.7.A.4a)
Parking brake efficiency below requirements (3.7.A.10) **DANGEROUS**
Advisory Notice issued
High level stop light not working
Front and rear discs corroded and pitted
it needs both rear wheel bearings replacing, the ABS light not iluminating maybe the bulb, both rear brakes and the handbrake are not working, so need checking/fixing/replacing, front brakes need cleaning/replacing as per advisory, and the emissions are failing badly, id change the lambda sensor as a first port of call, and check the cat hasnt gone
it needs both front wheel bearings replacing, the ABS light not iluminating maybe the bulb, both rear brakes and the handbrake are not working, so need checking/fixing/replacing, front brakes need cleaning/replacing as per advisory, and the emissions are failing badly, id change the lambda sensor as a first port of call, and check the cat hasnt gone
No mate its registered as a 1.6 still tax and insurance is too much lol
Cheers for your reply. Have i got to get the same st lambda sensor or something different (No good with engines) My mate told me it would fail on emissions before i had taken it in. Because they will put the reg in it will come up as a 1.6 and it will tell them what emission it should be and because of the conversion it will fail on all four is it true or not?
well your car is logged as a 1.6, so the reg will obviously bring up a 1600, the emissions for a 170 motor being a 2 litre will be a lot more, so unless you are going to change it on the log book, it will have to pass 1.6 emmisions test i would have thought mate, which even if it was running perfect, is still going to be too high to pass 1.6 emmisions
emmisions is probably all to do with the lambda sensor being duff as st170's love to eat them!! EDIT: they have 2 sensors, 1 pre cat that feeds the mixture info to the ecu and is by far the most important one!! and second is post cat just to check the cat is working so you could just swap the 2 sensors over to see if one is faulty or both. from what you've said though the connector may have broken off.
ABS could just be the bulb. i'd check the fuses (should be 2 in engine bay fuse box) and do an abs test on wet grass to check its actually working!
both rear wheel bearing need replacing and to do that requires a proper press although its not hard to remove the hubs.
with the brakes theres an advisory on corrosion on ALL 4 discs so i'd replace ALL discs and pads and bleed the whole ystem through with fresh fluid (including the clutch as uses same reservoir). so long as the callipers are working as they should (clean them up while they're off and regrease the slider pins) this should sort the inefficiencies out and if the rear discs and pads are badly worn then it will sort the hand brake out too.
this should get all the fail points sorted and then just got the high level brake light which is prob just a connector issue.
if theres still problems after that then get back to us, hope she passes for you though 8)
insurance wise i hope you have declared the engine conversion otherwise if you have a smash the assessor will instantly realise its got a 2l st170 engine in it and not the 1.6 and your insurance will be voided!!
Accident waiting to happen then, pre MoT.!!
You're tearing about in what is effecively an uninsured 2.0l conversion with no rear brakes and dodgy wheel bearings.
Nice to know you'd have a consience if you hit someone or something.
I'm not against the mods on your car, but you should bite the bullet and pay the resulting modified insurance, or not do it until you can afford it.
not a problem mate, here to help 8)
hopefully the abs is just a fuse or at worst the bulb blown (if the bulb has been removed you'll have bigger issues) as thats the problem that could trip you up.
Just checked the bulbs. Half have been taken out because air bag has gone off and abs is not wired up More money!
Russ Payne
25-09-2015 08:29 PM
