ford fe to 351 engine swap
Old Aug 24, 2010 | 12:25 AM
jnshumes's Avatar
jnshumes
Default ford fe to 351 engine swap
I have a 1973 ford with a 390 in it and will be swapping in a 351 from the early 80's. Can I use the same bell housing or will I need to find one for a 351?
Old Aug 24, 2010 | 04:56 PM
Need a lot more detail is the 390 a FE gen 1 or 2 ?, is the cleveland an "M" ?, if so the answer is defo no, as the M series cleveland uses the same bolt pattern as the small block, which is also the same as some V6 ford also!!
JoeyBoyden
Jan 4, 2024 02:36 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
vdubo7
Aug 2, 2015 08:17 PM
