View Full Version : Ford Escort RS Turbo
- front wings
- knocking lock to lock
- S1 / S2 metering heads??
- s2 boosts fine in 3rd,4th,5th but 2nd takes a while
- HELP!!!! Bonnet catch just broken!!!
- what tyre's
- what tyre's
- Recommend me a lowering spring please?
- s1 vs s2 suspension.?.?
- Escort key
- Little ends....
- Thinking of selling up....
- s2 backfires when turn engine off
- setup, who and how much?
- can delete.sorted now.
- Series 2 RS issues
- turbo problem after oil change
- S2 RST mfi tuning
- problem with my s2 ??
- How much???
- bleed valve and actuator rod length...
- clutch problems
- Been on the rollers yesterday
- ecu needed
- what to look for when buying a 2nd had bottom end
- front mounts V chargecoolers
- my estate shell mk4!
- Escort rst S2 speaker question?....
- turbo timer
- GAZ GOLDS
- Well.......CAUSE FOUND!!!!
- 88 spec dash different to 90 spec?
- 290bhp in a cvh rst
- Rs 3 spoke
- t3 ???
- Need a Fiesta RS Turbo Cone Filter ASAP!!! Blackpool
- Scuttle Removal
- f.a.o peoples running 1.8 zvh
- now got smoke coming out of the breather!
- Well..........
- Electrical problems - COME GUYS REALLY NEED YOUR HELP..
- RS Turbo as a track car
- Handbrake light
- efi conversion, megasquirt or cosworth
- efi idle problem
- Essential Mods/Upgrades for Fiesta RS Turbo
- relay fault on escort turbo, can anyone help!!
- Solid lifters
- fly wheel
- big problem with airtec intercooler
- S1 gearbox housing on S2 gearbox?
- S2 escort rs turbo @ 10psi what power?
- would you buy something from someone with spelling this bad?
- Remote locking!
- mef motorsport
- help mk4 headlining
- hi...can anyone help?
- Show us your Series 2 cut out front bumpers
- MFi running lean on one pot?
- Will this be any good for us????
- Not Holding Boost
- 8" incher
- RST MFI setups
- mint 90 spec tailgate needed with spoiler
- GEAR BOX
- Boost gauge
- Engine advice erst
- zvh engine oil
- erst work
- cutting out ?
- zvh 250-270 whats needed?
- servo discharge
- Alternator / Starter Question
- New cam, tappets etc..
- Amber or clear indicators?
- engine mount help
- water leak from radiator
- Standard actuator, where from?
- Will 4x4 calipers fit behind softlines?
- amual valve
- nuts n bolts underside rs turbo?
- Water Problem
- Looking for some 88 spec front seats
- KE Jet questions
- Are there any Traders on here that deal with AP Racing?
- diff question
- Anti Roll Bar Shackles
- Pics of your bucket seats...
- ZVH's good and bad sides of it?
- inlet manifold stud
- t3/t4
- What type connector is this?
- Turbo to Intercooler hose size?
- Dashboard Lights
- Brake fluid leaking from master cylinder
- fuel
- blue smoke!
- S2 master cylinder rebuild kit
- Starting Trouble
- Should i be able to move actuator rod myself?
- Geabox question
- rs s2 owners club?
- I think my car is broken
- Looks like my spare box needs a little more attention than i'd hoped....
- Escort rs turbo set up
- fuel sender
- FRST Headgasket advice please
- A few questions (boost etc)
- Cutting out after a few seconds-HELp!
- Brake lines
- Efi alloy inlet manifold how much bhp can i run
- no brakes again *problem found*
- whats wrong?
- roof skin needed
- Daily runner?
- 1/4 mile times and next santa pod rwyb
- Carbon fibre roof skins?
- no brake pedal after refitting brakes.help.
- delete
- Is there a gt2872r
- Help please! RS turbo wont fire up?
- focus brembo brakes
- binding brakes
- Gt28701r how good is this turbo
- Fiesta Turbo Engine Diagram
- 3" Mongoose system making way to much noise
- Front bumper supports MK4 escort
- any good body shop in swindon
- Megasquirt with EFI Flywheel and CPS question..
- Replacing fm-antenna coaxial cable.. easy job?
- Paddle Clutch
- Where can i find an adaptor plate so i can fit cossie discs and calipers to my RST?
- my rs turbo feels hesitant when it begins boost...?
- turbo let go ???
- 10-60 oil for my s2?
- rs turbo calipers and 4x4 calipers, whats the difference?
- Pace charge cooler?
- Please tell me one of you lot isn't ebaying this
- Fuel Tank Sender unit
- Venhill Powerhose Plus
- A question about boost!
- Cosworth 2wd alloys on s2
- Rs turbo timings ignition and cam
- looking to sell a dumpvalve.which type?
- best place for a g/box???
- changing injectors
- a few pics of the car
- s2 starts easy on a cold morning, but on a mild morning it takes longer.
- Dizzy help?
- For Mappers, Tuners, and anyone else interested of course!
- does anyone know the outer diameter size
- Anyone no where i can purchase a half cage for my s1
- gotech mini x list of parts
- My RS vs Ferrari :O
- New Heated screen prices
- boost pipe question
- 5th gear....what a C**T!!
- steering wheels boss problems
- starting problems
- Rear hubs. Are they interchangable?
- Stuttering when putting foot down
- how much brake fluid??
- Which HT leads?
- Piper 285 T2
- Well 17psi is my limit for now.....
- What exhaust should buy?
- cabby mfi turbo hot start prob.. PLZ HELP!!!
- noble motorsport!
- my s2 wont pick up from idle help
- Blue relay under dash help
- New rs turbo cabby..
- chargecooler/intercooler
- bailey breather.
- FAO morph
- Help.. Got no bloody brakes
- Takes ages to start...
- god im confused. Ideling problem. Boost leak maybe.
- Help getting higher voltage at my fuel pump
- RR result question
- that pressure turbo use?
- Adjustable track control arms
- car wont idle or run well wen its up to temp but if u turn car of and bak on its fine
- my s2 starts fine boosts well but when it gets up to temp it goes splutterie
- starter motor problem
- Escort Mk3/Series1 Dimensions?
- spark plugs
- what bhp do we reckon ???
- Pic request merc grey s2 on 17'' rondells please?
- White Wheels On Red RS's!
- header tanks
- s2 turbo cabrio tracking setting
- As promised pics of my freshly rebuilt car!
- Pictures of My Cossie 4x4 rear Brake Disc Conversion
- Which turbo?
- relays under the dash what are they? s2
- Just a quick one....
- ignition table cvh efi turbo
- Warm starting probs s2 rst mfi
- S2 Audio Equaliser
- best way to fit sump gasket?
- wastgate
- my engine wont pick up from idle
- RWD rear mounted engine advice
- s2 wont find any radio stations, changed everything Help!!!!1
- rewire help please
- forged pistons
- standard CR of a Escort RS Turbo??please
- How should i run in my rebuilt engine??
- My turbs it finally running!!
- will these wheels fit?
- no boost
- dump valve
- cvh trigger kit
- what options do i have?
- s1, how low on 17`s???
- wow
- aftermarket petrol tanks? anygood?
- My old RS Turbo
- dillema
- For anyone interested in Newmans Cams... FITTED NOW.... A FEW TIPS!!!
- axle weight
- Det Cans.....
- T3 Comp Housing Intake Hose Diameter 63mm?
- 20mm lowering springs?
- Starter motor help
- Less Lag?
- Good Bosch KE/metering unit links for people
- Make my car handle!!!
- Will a cosworth steering wheel fit?
- sqeaking (whining) noise???? suggestions please
- brakes
- fueling not richening on boost
- What do you gues think of my S2?
- Oil breathers
- S2 decent service
- S2 Starting problem Help
- Oil leak solved! New problem help!!
- drain plug for gearbox
- polished alternator
- G407 0KM black RSt
- body panels
- Whats it worth? (not for sale yet)
- Will they fit?
- Help Needed!!! Oil Leak!
- help
- LSD help, sorry in a rush.
- gotech gurus help needed
- ford escort COMBI VAN
- Halfords 20% off Oil.
- FTAO MegaSquirt Users Please!
