Well.......CAUSE FOUND!!!!
Old 02-10-2009, 09:19 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Default Well.......CAUSE FOUND!!!!
Fucking vavle seat!!
Will this bore be ok with a hone, or will I need it boring out and bigger pistons now??
Time to call NMS!!!
Old 02-10-2009, 09:42 AM
muz
Wye Valley Hardcore
muz's Avatar
WTF happened there! Are they Det marks?
Old 02-10-2009, 09:46 AM
Karlos G
Balls Deep!
Karlos G's Avatar
More pics on this thread https://passionford.com/forum/ford-e...0396-well.html
Dont think it's Det mate, i'm no expert but it looks like too much material was taken from behind the valve seat if you look at the second pic in this thread.
Old 02-10-2009, 09:53 AM
StephenC
..BS Motorsport..
StephenC's Avatar
excess heat maybe causing the seat to drop out? you got any idea on temps she was running? any long periods of high constant revs?
Old 02-10-2009, 10:01 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Considering how hot it would have to be for that to happen I think the head would have cracked first, or at least blown the gasket! lol
Oil and water temps have always been ok (I have gauges, and MS logs the water temp also), no long periods of high constant revs, i'm very aware of things like temps as this engine has cost me alot of money so i'm always careful with it.
Again if you look at the second pic does it not look like too much material has been taken away from behind the seat??
Old 02-10-2009, 10:06 AM
StephenC
..BS Motorsport..
StephenC's Avatar
no expert bud, just going by what Karl told me when he did mine, he mentioned he'd rather I didnt put it on a rolling road as the excess heat and constant high revs had been know to weaken the seat and lead to premature failure, that was a few years back mind.
Old 02-10-2009, 10:12 AM
andy130
andy130's Avatar
but whats the point in selling heads if he KNOWS the seat will come out?
Old 02-10-2009, 10:14 AM
StephenC
..BS Motorsport..
StephenC's Avatar
think your taking that in the wrong context mate, basically, if you ABUSE it then it may fail, thats all. Dont think thats whats happened here though???
Old 02-10-2009, 10:30 AM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
It's still likely to be mapping issue, I'm sure thats what Karl will say and I tend to agree I'm afraid.
Old 02-10-2009, 10:46 AM
andy130
andy130's Avatar
aw ok so theres a chance it was cause by mapping?
Old 02-10-2009, 10:51 AM
Christian and Beccy
#1 in Spelling Club
If the timing wasn't optimum, then EGT's could have been high.
I reckon the turbo is fucked too.
Old 02-10-2009, 11:01 AM
TurboShed
Cossiemodo
TurboShed's Avatar
So who mapped it then?
Old 02-10-2009, 11:03 AM
andy130
andy130's Avatar
what is EGT's?
Old 02-10-2009, 12:09 PM
Chris69
Chris69's Avatar
what is EGT's?
Exhuast Gas Temperature
Old 02-10-2009, 12:25 PM
LEE-RS
Custom
LEE-RS's Avatar
that's not good, also i was reading back the thread when you got the head about you saying its got bronze guides and they look standard
is there any damage to the inlet side you got any pictures of the below the inlet valve ?
Old 02-10-2009, 12:30 PM
louie1
louie1's Avatar
Hi karl, as i said in your other thread it looked like a valve seat may have dropped as the damage is quite severe for any det etc. i would like to have a look at the valve seat grind and give you an opinion on why it failed if you want me to let us know.
it has been known if you have the head faced it will lower the amount of alloy to hold in the seat. a few cossies have dropped valves due to over skimming.
Old 02-10-2009, 02:25 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Got no way of meassuring EGT's unfortunately, Turbo is off and seems ok from what I can see?!
Am I right in thinking Timing would have to be too retarded for high EGT's?
Me!
I'll take some for ya! Yeah suposed to be bronze guides, that what it says on my reciept and what i've been charged for??!
Yes Louie you opinion is welcome mate! Pop round tomorrow sometime if you like? I'll PM you my number gice me a bell!
NMS have asked me to send it to them so we'll see what they have to say!
Old 02-10-2009, 02:43 PM
old nick
old nick's Avatar
it's been k-lined [bronze guide liner]
Old 02-10-2009, 02:48 PM
clarke5700
YES I KNOW I CANT SPELL
clarke5700's Avatar
o dear mate thats not good intresting to see what they say about this. have you decided what you are going to do yet?
Old 02-10-2009, 02:57 PM
Christian and Beccy
#1 in Spelling Club
Karl - This is why we have our opinion that timing need to be set in one of two places. Rolling road or engine dyno.
Retarded timing = high EGT's
However, without measuring the effects of timing changes, you couldn't ever really truly know where the optimum point is. On the dyno, you can make timing changes, whilst monitoring power/torque output and EGT's (or if thats not available, the physical appearance of the turbo/manifold) which goes a long way towards gauging advance/retard and whats actually beneficial.
Really, in my opinion, the engine will be at its happiest in terms of safety and temperatures close to the point where it makes most power. OK, if you're peak power is at or close to the limit of internals etc, then thats not entirely true, but generally thats the case.
Old 02-10-2009, 03:03 PM
clarke5700
clarke5700's Avatar
i asked about EGT's ages ago and never got a proper ancer.
i wish it was put like that for me lol
LEE-RS
Custom
LEE-RS's Avatar
ahh that is ok then there k-lined bronze inserts, its just the way they sound on the post about the head sounds like he means full bronze guides
Karlos G
Balls Deep!
Karlos G's Avatar
More pics, inlet side is fine.....
Looks like Bronze inserts to me?........
Close up of the exhaust port......
Another thought, if I had high enough EGT's to unseat the valve seat would I not be seeing a nice glowing manifold/turbo? Never even after a good run have I had it happen, and i've pulled over and opened the bonnet to look for that very reason.
Old 02-10-2009, 03:06 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Yeah as I thought, well IMO my timing is far from retarded (not that i'm any way as experienced as you!), and never had a glowing manifold or turbo as above
Old 02-10-2009, 03:07 PM
StephenC
..BS Motorsport..
StephenC's Avatar
without sounding awful I think the mapping of your own engine and fitment of your own cam is going to render any kind of warranty etc null and void on that head.
Christian and Beccy
#1 in Spelling Club
This is why 'Chips' are very second-rate compared to 'Live mapping'.
Chips have to be very conservative because if you optimise the timing for the 'test' vehicle and ANYTHING is different with any of the vehicles that the copied chip gets fitted to, the engine could very easily shit itself. So, chips are usually on the rich side and with retarded timing, or else the manufacturer is taking a chance!!
Let's not forget that other things can cause high EGT's, such as exhaust backpressure etc, but whatever else is wrong, optimal timing will make it the best it can be.
Old 02-10-2009, 03:12 PM
Christian and Beccy
#1 in Spelling Club
Karl, I meant to say earlier, when Tony's failed at Brunters a few years ago, his turbo looked fine, but it wasn't until it was properly inspected that aluminium 'swarf' was found embedded into the BACK of the turbine wheel. There was alot of materal floating around in that combustion chamber and I'd not be surprised if some of it said 'hello' to the turbine wheel on the way out. I hope not for your sake, but you'd not want to build that engine back up, then lose it again because the turbo goes on to shit itself.
Old 02-10-2009, 03:13 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Old 02-10-2009, 03:14 PM
clarke5700
clarke5700's Avatar
so am i right in thinking that say a crapy map or chip with lots of fuel on WOT and not alot of ignition advance that that most of the fuel will not be burnt on the power stroke and when the exaust valve opens will make its way out of the engine giving the glowing hot manifolds turbos ect ect?
what is a safe or routh ball park figure in terms of EGT's?
Old 02-10-2009, 03:15 PM
Karlos G
Balls Deep!
Karlos G's Avatar
You may be right, but not if it turns out to be a fault with the machining of the head which is what i'm hoping for!
Old 02-10-2009, 03:31 PM
Ford RS Enthusiast
Power
Ford RS Enthusiast's Avatar
looks like too much metal as been removed at the bottom of the exhaust port and its dislodged broken away the valve seat up into the port
Old 02-10-2009, 03:33 PM
Christian and Beccy
#1 in Spelling Club
I don't want to fuel any part of the argument against NMS. Karl really does know what he is doing, it could be caused by any one of so many different things I'm afraid.
Old 02-10-2009, 03:48 PM
LEE-RS
Custom
LEE-RS's Avatar
Saying that tho Christian you are also a so called CVH god with having the second fastest CVH on the planet NMS have Karl for there tuning but what you achieved was amazing really, you went from a average everyday bloke to what you are today, but i guess your leaving that all behind now your getting rid
Karlos G
Balls Deep!
Karlos G's Avatar
Thats what I think, but who knows!
Yeah I know his rep which is why I had him do the head for me in the first place.
What do you think of my Timing map Christian, it's not to retarded is it?
Old 02-10-2009, 03:57 PM
Christian and Beccy
#1 in Spelling Club
Karl, I'm not a supporter of looking at timing maps and analysing them. It depends on alot of different factors, which is why I say that 'live' is the only way. It's not snobbery, I hope it doesn't come across that way.
I've only had ONE engine failure in 10 years and that was when I fitted a Cometic head gasket, since going back to standard, it's been fine. Even then, that was only a head gasket failure. Remember my car is tuned 100% on the dyno and used for top speed.
Old 02-10-2009, 05:13 PM
rstdave
rstdave's Avatar
Not got the facilities to check my egt's but my turbo/manifold always glows after a good thrash.....never has it caused any issues so not thought much about it but i wonder why yours would never ever glow red even after a hard drive Karlos??
Old 02-10-2009, 05:15 PM
Rick
Rick's Avatar
There's plenty enough timing in there. Unless it's seen 7k plus sustained that really shouldn't of happened. Having said that, CVH valve's are a ticking time bomb, which is why I eventually moved away.
Old 02-10-2009, 06:37 PM
crazycage
crazycage's Avatar
what was your valve clearances i'd put money on that being the cause.
Old 02-10-2009, 06:44 PM
Rick
Rick's Avatar
Agreed. Forgot you had solid lifters. 99% sure the valve seat overheated due to too small a clearance.
Rick.
Old 02-10-2009, 08:39 PM
Karlos G
Balls Deep!
Karlos G's Avatar
No thats cool I understand mate.
Rick.
Yes mate solid lifters and newmans cam.
Valve clearance? How and where do I meassure that?
Quick Reply: Well.......CAUSE FOUND!!!!
