wastgate
Old Sep 4, 2009 | 07:14 PM
matt-zvh's Avatar
matt-zvh
Default wastgate
hello people need to pick brains really what sort of bhp do you need to run a external wastegate my m8 has has has got wastegate fitted to manifold all good also with screamer pipe all pumbed in internal wastegate is closed off took it down road screamer pipe opens up good flutters in first gear after that no flutter at all so just wondering what power you need??? cheers
Old Sep 4, 2009 | 07:26 PM
white2lsr's Avatar
white2lsr
I think to be worth while it has has has to be running big power
Old Sep 4, 2009 | 07:28 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
not so much power really, it depends how much boost you're running and the restrictions of the manifold.
a cvh turbo can run over 300bhp on a standard manifold, although it isn't as brilliant as a free flowing tubular one.
equally an actuator is only as good as the spring, so a new actuator at the right rating will be fine for decent power, i'd say 300bhp again, more if you look at cossies.
basically when you find the turbo is struggling and the wastegate opens too soon, then it's time to change.
Old Sep 4, 2009 | 07:35 PM
matt-zvh's Avatar
matt-zvh
i see where your coming from we was wondering if we should change the internal spring trouble is it was running and working fine on the engine i got which was a stage 3 built running 240bhp his engine is not far off 195 so think maybe change spring if no good il have it back on mine cheers guys
westfieldturbo
Mar 20, 2015 10:07 AM
throttle jockey
Mar 22, 2013 09:53 PM
sean2k
12
Oct 23, 2009 08:38 PM
Raj B
Aug 3, 2008 07:42 PM
