Starter motor help
Starter motor help
A friend of mine has recently had a ZVH put in his S1. Starter motor is fucked. What is the best/cheap alternative. Been doing a little research and been told a diesel one is stronger. Also a 1.8cvh/2.0dohc sierra starter is the one to go for. Any help guys on what to go for and part numbers if you have them.
Regards
Paul
Regards
Paul
So what diesel model do we need the starter motor off, or will any do.
I had heard the diesel ones are stronger so may aswell change now while its out instead of reconditioning and waiting for it to go again
yeah i supose u can u should buy 1 off them heat wraps carnt remember who makes them it like the exhaust bandage stuff that reflects heat should help it live a bit longer
