dump valve
03-09-2009, 04:13 PM
dump valve
hi guys. which dump valve to go for as mine is leaking i have a baileys at the moment what happens if i dont have 1.
thanks joe
03-09-2009, 04:24 PM
Ok then
You wont have a gay noise
03-09-2009, 04:25 PM
where does the vacum hose go from the end ov the dump valve cheers i dont want 1. propa chavvy
03-09-2009, 04:33 PM
More boost Igor!
Quote:
Originally Posted by
T28 RST
Plug it, and tie it up out of the way.
03-09-2009, 04:54 PM
for what its worth i got a forge one i am about to put on flea bay new there like £100 ish
03-09-2009, 04:57 PM
thought dump valves were good cuz they keep the turbo spooled up between gearchanges
03-09-2009, 04:59 PM
depends if its a vta or re-circ type etc i guess
03-09-2009, 05:12 PM
and turbo chatter wears your turbo quicker
03-09-2009, 06:29 PM
More boost Igor!
jamieRST
It doesn't keep it spooled up - anti-lag does that - the DV simply prevents the turbine stalling, hence, slightly decreased lag.
Scott-rs2k
Sort of - in my experience a VTA one is better because the hot air isn't sent back to the air box.
jamieRST
Depends on the size of the turbo, and whether it's well maintained or already on its way out.
03-09-2009, 06:38 PM
I would use a GGR GpA type with filter to stop dirt ingress on idle and replaceable diaphragm, this will stop ur turbo slowing up so much between gear changes. I have one for sale at £100posted UK
03-09-2009, 07:13 PM
will it be ok on the 1.6 as its on ggr as for a cossy?
03-09-2009, 07:50 PM
Bodger of Blackburn
you need a twin piston one when using mfi, single or diaphragm will be fine for other applications.
pistons are better for higher boost and yes i have one on my rst cab and zvh efi xr2, helps reduce the lag when changing gears on aggressive driving as the turbo spins in the same direction, unlike when you don't have one it can stall and has to spool all over again.
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
RS-Rikki
21-09-2015 07:27 AM
rs_jim
19-09-2015 08:41 PM
