turbo problem after oil change
Old 04-10-2009, 12:44 PM
AJ-RST1
The posh are up!!!
AJ-RST1's Avatar
Default turbo problem after oil change
as above i changed the oil today in the s2 before oil change turbo was on full boost at 3000rpm roughly, now it is full boost at 4000rpm, whats gone wrong only done a oil change.
ideas please
Old 04-10-2009, 01:02 PM
Karlos G
Balls Deep!
Karlos G's Avatar
Wierd one! Oil starvation to the turbo maybe? I'd be careful boosting until you find the cause mate.
Pull the oil return to the sump off for a few seconds with the engine running and check oil is coming through from the turbo!
Old 04-10-2009, 01:10 PM
orionmojo
orionmojo's Avatar
Did you use the same grade oil? if its much thicker it might restrict the engine.
Old 04-10-2009, 02:00 PM
AJ-RST1
The posh are up!!!
AJ-RST1's Avatar
same oil grade mate.
Old 04-10-2009, 02:02 PM
AJ-RST1
The posh are up!!!
AJ-RST1's Avatar
ill crank it over and get some oil pressure to the turbo, but weird how it was fine this mornin then i did oil change now it gone weird
Old 04-10-2009, 05:00 PM
orionmojo
orionmojo's Avatar
and the levels are all good? i mean theres not too much in?
Really, really odd problem. i cant think of anything at all that would have any affect on it
Old 04-10-2009, 07:33 PM
xr2wishy
Bodger of Blackburn
xr2wishy's Avatar
i'd be pulling turbo off and running oil back through it, sounds like something has found its way through.
big_Rad
15-09-2017 09:36 AM
ekjim
17-08-2015 08:57 PM
st220kyle
16
14-08-2015 06:13 AM
track.focus'd
12-08-2015 05:53 PM
mattman1234
24
01-08-2015 11:46 AM
Quick Reply: turbo problem after oil change
