i've got spare pistons if you want to use a used one, you sure it's not lots of low impact det marks?
maybe one cylinder running lean?
i've never seen it that bad, but i have got 4 knackered oversized pistons with similar markings when running a carb turbo setup on the wrong dizzy on my xr2 turbo technics setup.
second thoughts, have you compressed the valves in to see if the valve guide/seats are complete?
No, another thing to check tomorrow! If a seat dropped then i'll be making a call to NMS!!!
Cheers!
No it's not Det, the end of the plug was bent up against itself so something has got in there for sure!
Valves will be out tomorrow and i'll get some pics up, if it has dropped a seat then hopefully NMS will be decent about it as i've not even had it 6 months probably only done 4K!
Originally Posted by crazycage
you can have the chambers 3d cnc machined ferriday eng do it .
If there is enough meat left, there is some really deep gouges!
if they are deep you can weld them up before you get it machined .
mine was far far worse that that,thats nothin and is an easy repair looks like something has got in there you missing anything when you fitted the efi conversion ive seen this before a few times .Imagine what mine was like when the valve head came off at 7000k ish and battered the fuck out of it and its back on my car today so i wouldnt worry pal
tim
jesus pal dunno been done tice as i ripped it apart twice lol wasnt that bad nothin like hundreds urs looks a straight forward job tbh dont worry to much but whats the bore tube like? pics
tim
Yeah turbo is fine from what I can see withotu stripping it down!
tim
Oh that doesnt sound so bad!
Bore had very slight pitting around the top 1" IIRC defo no scoring, didnt look to hard as I was taken aback by what I had just found!
Will investigate more tomorrow and get some pics of the head with the valves out and of the bore.
At the very least then i'm looking at a head repair and new valves, replacement piston, bore hone and new rings all round.
