t3 ???
Bodger of Blackburn
yes and the above is inaccurate.
you can fit an erst t3, cossie 2wd t3 and a cossie 4wd t3.
you can just unbolt the erst core from the turbo housing, 6 bolts, probably really stiff and change cores over.
however you'll find ideally you'll need a bigger exhaust housing, i'd go for a 0.48 one, have a search for one, won't cost much, maybe Ł10-30.
then you don't need to alter anything else, just maybe the actuator bracket and spin compressor housing by loosening the bolts spinning and tightening the bolts again.
but if you wish to get less restriction on the tubo, get a cossie turbo with 0.48 housing and modify a cossie down pipe.
i've done all the above at som epoint and now settled with a cossie housing and down pipe on a 4wd turbo as this is the biggest power one.
It Wasnt Me!
So basicaly you've just said the same as what i've said, only he's to take his turbo apart, then realise he'd be better fitting the cossie core and housing he's just taken off and to modify his downpipe to suit? ![Surprised](https://passionford.com/forum/images/smilies/bigcry.gif)
Lad asks if a cossie turbo will fit, it will, and to do so, you'l need to modify the downpipe.
Bodger of Blackburn
well its going on a efi engine stage 2 chip, biege's , front mount, std bottom end and head so wat turbo would be best lookin to get cam fitted and maybe some headwork in future
