View Full Version : Ford Escort RS Turbo
- series 1 rear disk conversion problems
- hybrid turbo for S1
- Series 1 takes 10mins to start!
- My wheels
- next tuning step?
- C331 VUE
- under boost pop and bang
- Engine comparisons
- soyz zortzzz
- black number plates?
- Bak on Black rims and slammed!
- 2L ZVH it will bump off but wont start of key!? PLEASE HELP!
- adjustable wiper speed switch
- colortune (gunsons from halfords) STU ,????
- pillar pods
- Exhaust housing bolt conversion thing lol
- uprated s2 fuel pump??where from
- De-comp plates, Your views
- how fast?
- Whining Noise when running above 15PSi
- turbo oil plumbing
- ** POWER ENGINEERING ROLLING ROAD SHOOTOUT ** 4th FEBRUARY
- 18" alloys on escort cab???
- boosting trouble
- Arghhhhh turbo lagg!!!
- Which flywheeel do i use??
- Over fueling
- Adjusting Boost
- Bro's S2 back fires when turned off
- ECU PLUG??
- rough power estimate and heloo?
- fuel accumulator
- rs engines?
- Cosworth 4 pot's onto escort rs
- Think ive broke my gear box?
- how many rs left
- 2.1 zvh
- wiring loom
- Low Comp Pistons
- Smoking when cold?
- Quick Shift and Fuel Cap
- ne1s granarda on here?
- what cam and actuator
- 1/4 Mile Times
- M16 Inlet Manifold
- Zetec
- there you go boys and girls.............BEAT THAT
- My Escort RST
- Which front mount intercooler.......?
- ACT Temps
- mk 3 estate turbo project................
- Whats the tread size fitting on the RST master cylinder?
- engine advantages
- alloys
- newbie with new S1
- fuel metering head?
- gearbox - starter motor?
- What wheels on my red series 2
- ERST problems ?????HELP??????
- Why oh why is my camshaft oil seal leaking?!?!?
- uprated clutch ratchit
- s2 rst pics
- Keeping the turbo but slight prob
- bumper inserts
- Diesel gearbox in series 2
- ATTENTION ALL.......
- Any one running MegaSquirt?
- Replacing RST Clocks
- series 1 doesnt like starting
- Alternator wiring help.
- where can i get injector pipes from?
- Info n a lil problem
- Interior Parts
- ZVH WHAT OIL
- Few plug colours please - iknow someof you are good with the
- new exhaust
- rear disk conversion.............
- Cossie management S1 inlet
- CHEAPEST PLACE FOR ZETEC OIL PUMP
- im just about to go buy oil but.......
- was it anyone off here?????
- how much to fit my cossie management on s2??
- Series 1 Servicing......whats worth doing ?
- Should i get....
- modified zetec rods for ze-vh
- intercooler water spray kits.
- 4 x 4 loom is always live and shouldnt be ..................
- RST Inlet Pics Request
- Standard breather Mod
- is it normal for a dump valve to spit out a bit of oil ?
- Fitting Escort Cosworth Caliper's and Discs to a RST ??????
- What turbo to get?
- break grinding as stopping?
- 12PSI - WHY?
- WILL EFI INLET MANIFOLD FIT MY RS TURBO HEAD
- Thread size ?
- 2L ZVH WOULD I GAIN BY FITTING 5TH INJECTOR
- fitting instructions for a roll cage
- Renault fitment wheels on a erst
- looking to swap 90 spec recaro front seats 4 half leather 90
- Lower cambelt cover, CVH fit on to ZVH?
- Adjustable TCA's
- Price for an Escort RST
- 7 spoke rs alloys
- lee hicks chrome cage
- newcastle users? meets?
- zetec pistons
- misfre????
- pink pink pink?
- adjusting boost...
- whats a c.p.s
- E.C.U chipped
- charging fault/altinator
- can you put a standard 1.6 cvh in a turbo
- s1rrst alloys 4 sale
- ignition ???????
- NEED RAPID HELP!!!
- 0-60 and topend S2's
- st170 gearbox
- Pace 1/2 IC Fitting?
- Sound Proofing
- exhaust manifold rst
- CAR COVER???
- air corector
- any one know any good chat rooms for us ford nuts
- q plated turbos can you put a private plate on one
- Holding back when coming on boost
- Hot Start help!
- Help needed Peepstons!! What do I go for?
- hot!!??
- somethings not right at all
- Anyone in the Manchester area
- bottem valence for 88spec front bumper(black trim)
- Headunit wiring
- Fiesta IC and Escort IC, are they the same?
- after burner rear lights on s1?
- were is the cheapest place too buy a new turbo cvh engine
- escort series one reshell
- Swirl pots
- me new RSturbo
- only superunleaded????????
- no idal and no start
- Pace Intercooler
- tube exhaust manifold for rst?
- Rolling Roads in Essex
- Pro Alloy FMIC
- S2 PrObLeMs....
- S1 Do's and Don'ts Please . . .
- WANTED: RED SAMCO COOLANT HOSES!!
- What chip ??
- 20psi ??
- sunroof leakin
- Running high boost on standard IC, what would happen?
- my first escort turbo
- MFI to EFI, best route.... (conversion)
- Just bought a new ic
- boost ???????
- fuel pump mounting help!!!!!!!!!
- water leak.....
- p.f. grudge match
- 1.9 or 16valve zetec turbo
- ZVH water pump adaptor plate
- Break it or Sell it
- standard S2 head gasket??
- What are the best sparks??
- The joys of ebay!
- longer dipstick
- Set Up
- black diamond combi discs!
- Steering wheel wobble
- flip out screen in series2 turbo
- using focus st170 bottem end as 2lzvh conversion?????
- zvh cosy mangement or 5th injector
- series 1 Brakes
- What is this?
- Rattly after oil change!?
- "what does an rs turbo weight"
- rst lifter tapping???????????????????????????
- Hot ERST
- exhaust rubber - what one?
- took my d/v of, i need louder flutter, how?
- Fuel consumption on ERST
- mk4 xr3i
- what wheels fit my van............
- Bubbly roof
- help needed
- s1 ecu question...
- running like a pos
- S2 Standard Hoses??
- Vibrating Clutch Pedal?
- 1.9 engines
- im new here, heres some pics of my RST
- right question for all u experienced people with S2`s
- Pics Of My Rs
- S2 into MK4 combi?
- Fitting fuel pump carrier....
- engine hunting on warm up
- Pics of me new S2 Escort RS Turbo
- rst holding back on boost pissed of yet another problem
- anyone know of this car?? and help on low comp bottom end
- brakes ? mk4 xr3i same as s2 ?
- ADVISE ON WHAT SHAFTS ARE REQUIRED WHEN FITTING A MTX75 BOX
- How heavy...
- Fuel pump problem
- Sold my rst, well nearly, :-(
- i bought another RST *PICS UP*
- not another !!!!!!
- zvh de-comp bonding stuff?!?!?!
- RS Turbo Crank & Conrods
- got some new goodies for my car what sort of power
- head lights
- back fire
- ariel on a series 1?
- Still over heating!
- rear load valves
- acceleration and traction peoblem, help
- HOW DO U TEST A THROTTLE POSITION SENSER?
- LOOKING FOR RS SHELL
- replacing a heater matrix
- Escort RST Starter
- What oil?
- ERST fuel tanks..
- Help! S2 over heating!
- shades of mercury grey
- Presure actuator
- ANY IDEAS
- soon to be a s2 owner cant wait !insurance????
- Major help needed !
- SERIES 2 LOG ANYONE???
- what year did you get your 1st rst
- Handy tip for all you with rotten sunroofs!!
- My first RS
- RST Doors.
- Help needed with rst van
- form 1.6er to 1.8er cvh turbo
- noise after boost??
- Help! water is pissing out of the head!
- Brakes!
- RS won't start?
- Fiesta turbo Managment
- Ignition leads and spark plugs..
- whats the best 5th injector to run on the escort rs turbo
- paint
- Breather Pics
- Stripping the RS....pics
- How much is my car worth??
- just bought a big valve head uprated cam or standard
- new black s2
- new S2
- cossie 2wd IC in s2
