me new RSturbo
is that a pace interwarmer? if so i'd turn the boost down to atleast 14psi
Looks a ruddy nice car mate
every one ses about the act's being to high running over 14psi on a standard intercooler yet my self and other people on here have run this kind of boost and not blown an engine up so whats the problem its not like were bull shitting when i have seen it with my own eyes on my boost guage running above 14psi o s/i.and i sold the car and is still going strong running more boost than i was and its a 1.8 cvh with a high comp bottem end and an rs head ,running that kind of boost i would of thought that it would of blown a long time ago but it hasent and know putting the same engine and set up (s/i included)in an xr2 to take up the pod .!
14psi is NOT 19psi
If you had bothered to look, you will see i actually said
so
Originally Posted by James Raby
I ran 16psi on a std cooler, 17 will be fine on a Pace double size
That boost is pefectly fine for the intercooler. Runninf 19psi on a std intercooler, is however, silly.
Big boost and poor cooling is fine for short bursts in the lower gears, but hold it for any length of time, and this is where u are likely to run into problems. You are unlikely that she'll melt if the igntion has been set accordingly, but you WILL lose peformance. For example, a track car using a std turbo and cooler, should be set to 11psi max for best peformance, with as much advance as possible.
First mod on an RST should be a good intercooler and breather system
what bout gettin a -34?? what does this do bin told i need one could be why when i boost it gets to 17 -18 and drops loads and doesnt seem that rapid at the mo ????????????
so
sorry mate not having a go just stateing that people on here say u cant run boost over 14psi on a standard intercooler when u can as i have and not fooked nothing and i know im not the only one
it may not be that safe and would not advise some one to do this but my car my choice and it was fine
so
Rs Baz
11
24-03-2005 09:48 AM
