View Full Version : Ford Escort RS Turbo
- setting up rs turbo mixture
- rebuild question
- Four pot brakes
- Possible air leak ?
- what plugs is eveyone using?
- former owners of series 1 B70EEW
- Opening rear windows
- silly question but whats the diffrence between 88 and 90 spec
- oil for s2 escort
- 10W60
- handbreak light
- rs turbo running probs:(((
- FAO ZVH Owners
- Basic Zetec Conversion
- Cold Starting Issues
- K&N panel filter
- blowing wiper fuse
- cossie management
- What do i need to use to get rid of the abs???
- Rebuild
- fuel pump?
- rs wont run right HELP!!!!!!
- Major backfire!?!
- Various problems!
- oil change now white smoke???
- what power out of 1800cvh turbo
- MFi full power enrichment
- rs turbo juddering
- Rover turbo inlet on a zetec turbo
- Area six inlet/tubi manifold gains....
- MTX75/ST170 6 Speeder?
- Fiesta RST and Escort RST Engine mounts different?
- Rs turbo metering unit
- fogot what s2 ownership was like lol
- Electronic fuel pressure adjustment?
- Name that part
- good strong 200bhp/Torque cvh
- Perspex windows
- can not belive my eyes
- Rs Turbo Fluids
- s2 clocks in combi van
- whats the part called.speed cable goes into it
- FAO Twins...
- Cutting out.!
- Fuel pipe still available?
- Driveshaft Seal - anyone got one?
- HELP... S2 knock sensor
- GOTECH
- mk3 and mk4 escort sunroof
- my new engine
- removing superglue
- For anyone interested in Ka Sport IB5 Gearbox fitting...
- zvh --- zetec , which head --- update - process begins
- Emissions ?
- help cap under dizzy leaking coolant
- Wing, Scuttle, A pillar gap rubbers
- Dropping a gearbox the lazy way
- 5th gear selector arm removal IB5
- Floflex bushes - any good ?
- need help pricing parts
- coolant gauge temp sender!
- missing sensor ?
- what do think? RST brakes, no abs, no prop valves and what master/servo
- Fuel Pump!!!???
- must be escort day today
- Zetec turbo gearbox?
- dials
- I need 6 CVH rocker seat shims/rectangular washers ASAP!
- will rs turbo suspension fit on rs16i
- ofac and ofab
- I miss the d4 300bhp thread.....
- whos used N/A block an built it to turbo spec?
- Saftey devices cage
- Grey fuel pump relay
- Oil Return
- chudder
- mk1 focus rs master cylinder and servo into escort mk4.......
- Going EFi and ZVH - need advice
- koni shock leaking
- Using oil
- set up after new cam ??
- 1989 ERST to EFI FRST? Help...
- Dropped a valve!
- bigger valve cut outs?
- rst s2 master brake cylinder
- bit of help with choices
- Is it running to hot?
- No fuel to injectors
- is it possible to a single samco hose
- Airtec large front mount & Spotlights, possible?
- Southend meet this Wednesday?
- tyre sizes
- brake fluid
- Zetec turbo just bought
- Carbon fibre bits
- Rebuild question.
- cooling!!!!!!!!!!!
- 82deg thermo and msd fan switch
- why P8 over L8?
- Really dumb bottom end rebuild question
- Standard con rods and largish power???
- compression on low-comp pistons
- Compression Test
- Toad alarm Drivers Door asleep
- Inlet manifold gaskets... where from ?
- Escort RS turbo.... help needed!!
- escort rs turbo tuning
- s2 idle speed adjustment
- fu**ing car
- Inlet manifold help....
- no boost hellppppp
- another cylinder head...
- S1 Front ARB setup onto S2?
- RS option Steering Wheel
- actuator
- any tips on boost leak
- ERST fuel and speedo sensor.......
- are these dials any good?
- ARP head stud kit
- Anyone whos fitted/adjusted Newman Solid Lifters
- focus rs mk1 alloys on a s2
- just after a little advice please
- Need some FRST bits
- a few more before and afters
- Quickie about setups
- s2 rs ruff idle / missfire
- running 191.9 bhp s2 mfi, whats next?
- Oil Cooler Kit
- Is the world going mad ???????????
- Rad's
- big turbo on zetec
- Engine wiring plugs... what colours ???
- adjusting fuel pressure and afr monitoring
- engine rebuild
- abs again
- were do you find your rs turbos forsale?
- t3 turbo
- series 1 wont fire!, after alternator fitted! help
- Bottom End Gaskets
- Hose size from turbo to airfilter
- blue smoke
- EFI flywheel
- my rs wont boost ?
- rs turbo clocks
- Diesel Gear Box
- -31 actuator
- My engine is too lean! how can i get more fuel from the mfi?
- cam
- first rs turbo.few questions
- Windscreen Rubber
- Removing boot lock
- brakes from s2
- coughigng and spluttering
- what should go here?? Pict Attached
- ***FIXED*** Really need some help with the rear suspension, pics too
- blowing fuses
- buying new pistons, standard or low CR?
- are airtec rads any good?
- abs
- why wont my rs turbo start!!? (fires on wd40 though)
- RS2000 mk6 -Power mods+ possible projects
- cvh efi flywheel ??
- oil cooler
- complete standard look or clears on front and red & tinted lights on the back?
- megasquirt msq anyone ???
- Engine won't start after fitting MF2
- Good advise wanted please!
- S2 brake problems
- £100 to whoever can help me get my car running..
- cutting abs off ?
- s1 centre console and tape deck surround
- Is it impossible to find proper clear indicators for S2 RST?
- help rear wishbone polybushes
- ZVH temp
- CNC heads
- MF2
- Rebuilding Gearbox....and conrod question
- Where to buy an AP Racing clutch?
- stupid lights GRRR help please
- My new Zetec Turbo Project...Few questions!!!
- Boost hose size - Crossover?
- IB5, what from???
- possible actuator problem
- rs turbo info needed pls
- water leak!
- cvh engine
- stupid question ?
- starter motor prob(i know again)
- Stud Conversion
- Oil Pressure Gauge
- will this cam fit a cvh?
- alternative replacement Ford alloy wheels
- First rs turbo
- escort rst clutch
- help with EFI misfireing
- Red glowing manifold.
- S2 Brake Upgrade
- ap racing clutch slipping?
- Cold Start Injector
- FAO - zetec turbo people - how much spent/spec
- Brake bias problems
- boost question
- Chipped ECU wanted!
- 380cc Injectors for std engine??
- my escort rs turbo
- got the back end dropped
- before and after ...what you think?
- Oz wheel pic request
- Get hot on high speed runs
- best place for custom manifolds please
- TCA Set up
- quick shift
- Fuel metering unit again...
- 2.1 zetec cvh head
- Nomad 3 gauge vent holder
- negative boost wtf??
- Con Rod Bolts etc.....
- lowering arm issue please help
- has anyone had to sell a car they loved
- Thinking about running S1 arches on my ERST. Thoughts?
- RS TURBO Over Boosting
- cam shaft
- new turbo
- Tailgate latch
- removing 5th gear?
- Arch and Skirt fixings
- Charging problems on RST
- Air box
- Engine is coughing @ 4krpm
- rs turbo s2 battery
- Fuel relay problem
- BARGAIN!!!!!!!!!!!!!
- V4 /megasquirt or gotech . Which is best
- s1 radiator fit a s2
- zetec engine help
- who's running megasquirt?
- Fuel Tank
- any1 know any companies/ garages in or near b'ham that set up rs turbo's?
- uprated brakes????
- zvh engine
- Gearbox in a S2 RST
- mymk3 escort
- bleeding brakes
- 1.8 cvh + extras power output?
- Got my exchange alternator today and...
- whats your view?
- turbo trouble
- Are you serious??!!?? (title modified)
- what speeds have you had your RS to?
- lowering springs,which brand
