ARP head stud kit
does anyone know the torque settings for bolting the head back down with a studded block?
im assuming they would be the same as using normal headbolts but thought i better check first.
Bananas!
Head Gasket failure.
I was told this to when I fitted to mine, but I didnt have a problems for the 6months the car was on the road with them fitted, only did about 3000miles tho.
To add the Karlos is a very good souse of info!
cheer's lads. wasnt aware of people having headgasket problems with them, the car's been fine up untill now so i'll leave them in and see how it goes.
better to be safe than sorry,using arp bolts always gets a thumbs up from me.Cant remember where i got my torque settings.most probably from here.So just do a search dude.best of luck.
Wye Valley Hardcore
Lol.Should of been fitted correctly then.errors happen.I personally wouldnt want to risk using standard ford ones for peace of mind.im also running cometic head gasket that people say are crap.ten thousand miles down the line with both fitted,they fine.Im just going by my own experience
![Smile](https://passionford.com/forum/images/smilies/icon_smile.gif)
lol.i shit hits the fan.just pure luck or total bad luck.I went down this route due to headgasket failure lol.by the sounds of it,its thd other way round for most which im suprised to hear.Im not running stupid power yet but enough to put things on edge.id personally do my nut if my headbolts didnt do their job.for the price tag!
not oem for me lol.I might learn one day.But far as im aware,they aint made for such stresses such as ford headbolts.Ive heard many times people using them on high power but me think it not worth thd risk.Your probably think it more risk going down my route.
#1 in Spelling Club
Trust me, my OEM gasket/bolts was doing just fine at 350bhp and 171mph.
i do believe u mate.im not exactly going to strip my engine and get ford parts right now lol.Ill see how mine goes.ive done plenty of 150 To 160Mph runs without any fail.I think i remember you posting up your blown headgasket?
Balls Deep!
erm... your head was warped, your fuelling was lean, you were detonating, you didnt lube the head bolts, you didnt skim the block, you didnt clean the threads, your timing was retarded, etc.. etc..
lol
Many many reasons for a HG failure, 99.9% of the time it is not down to the OEM HG
![](https://passionford.com/forum/images/smilies/roi.gif)
The factory stretch bolts are fine for most applications. They do not require re-torquing.
The "stretch" provides enough clamp force after the engine has been through a few heat cycles and the gasket compresses fully.
If one uses ARP studs re-torquing after a few engine heat cycles is necessary.
Head gasket failure will result if one does not follow a re-torque procedure when using the ARP studs. I wish ARP would provide the re-torque recommendation. Most race engine builders re-torque the ARP studs after the initial engine warm up period.
Warm up engine to operating temp. Allow to cool down, and re-torque the ARP studs.
With the CVH 60 ft lbs is used.
Hope this helps.
Hope this helps.
Yes 60 Ft. Lbs. final torque.
The reason the puny Ford Factory stretch head bolts survive is the low power output achieved using a CVH head. The relatively poor head flow limits power production to 80 or 90 hp per cylinder - at best with 2+ bar boost.
For the CVH factory bolts and head gaskets are very adequate.
Differing engine block and cylinder head materials do not matter. The rally Zetec engines
used cast iron blocks and aluminum cylinder heads. Guess what - they didn't use Ford stretch bolts. They used ARP studs.
Actually, it's the poor thermal efficiency of the engine rather than flow that limits the CVH. Evidence seems to suggest that the ARP are suited to engine's with a limited number of heat cycles, ie not road engines.
Rick
Rick
Hello Rick,
Poor thermal efficiency? Every combustion engine has relatively poor thermal efficiency.
Yes the CVH has an inefficient hemi combustion chamber, but the reason for low specific power output is dreadful cylinder head air flow.
What evidence are you referring to regarding limited heat cycles are suited for ARP studs?
Every road racing engine I have ever built ( including Cosworth 3 liter 405 HP NA engines)
have used ARP head studs. These engines were used for several racing seasons. Mainly
10 lap sprint races. My personal experience differs from yours.
jonfoc
16
11-09-2018 05:35 PM
