82deg thermo and msd fan switch
Hi all,
Just a quick one on this, I've fitted the above and the fan now kicks in when the needle hits "M" but doesn't appear to want to switch off. Haven't gone out for a run in it yet.
When timed (at idle), the fan was on for 10minutes not sure how long they would have continued as I switch the car off. The fan does not kick in when started only once it hits the "M". I know its not a major issue as running RSTs' cool is a rarity, but my concern is will it draw lots of current just being on like that?
anyone else running the switch experience the same?
I will update once ive been on a run
Dave
Dave
rs turbo from Greece...
I fitted mine last week. My fans klicks when tmp gauge hits the ''M'', when the car is at idle. but after 10-20 sec they stop working.. But i have 3 spal fans, 2 blowing beetwen I/C and rad, and one behind the rad shacking...
I think its because the MSD fan switch turns the fans on at a lower temp,so I'd guess your fan will spend alot more time running.I would'nt worry about it,should help stop the car boiling over in traffic.Have you asked MSD at what temp their switch is set to turn on the fan??
i'v got an 82 degree stat and msd fan switch in mine with 2 spal fans on the front of the intercooler, my fans come on at just over 90 degrees and go back off just below 90 without a problem.
rsguy
44
29-09-2015 03:29 PM
wheelwizardrefurbs
18-09-2015 08:59 PM
