help rear wishbone polybushes
Old 25-06-2010, 10:21 PM
66doug
66doug's Avatar
Default help rear wishbone polybushes
Currently fitting floflex bushes to my S2, front ok but rears not so easy, so if you can help, will be much appreciated.
On the rear wishbones inner, do you need to remove the metal sleeve before you can fit
the 3 part bush and sleeve.
The outer 2 parts of the bush seem to fit with the sleeve fitted but the larger inner is too large
I have searched past posts and cant seem to find a definitive answer.
I have attached a pic
Old 25-06-2010, 10:37 PM
Rob_DOHC
Rob_DOHC's Avatar
Hi there buddy,
I have been doing this today! mine never had the metal sleeve??? But already had poly bushes fitted, so im going to go with, yes, remove the sleeve... however some one who has done this before may say something else.
Rob,
Old 25-06-2010, 10:52 PM
taz1787
Escort Cabriolet Owner
taz1787's Avatar
mine are floflex ones and are 2 peice ones with sleeve and fit test fit correct
Old 25-06-2010, 10:58 PM
66doug
66doug's Avatar
Is the sleeve removed totally i.e both sides and the inner so you are just left with a large hole thru the wishbone?
Old 26-06-2010, 12:43 AM
Puss2
Formerly know as Puss
Puss2's Avatar
Correct
Old 26-06-2010, 09:36 AM
slammedorion
slammedorion's Avatar
Cut the centre out with the grinder, leave a lip each side, then take a big screw driver and a hammer to the left over bits. . . they'll knock out alot easier
Done a couple of cars now, by far the quickest way
Old 26-06-2010, 12:41 PM
66doug
66doug's Avatar
just about sorted it now, what a nightmare!
Seen quite a few reports about Floflex on here and other forums and as far as the fitting goes, they appear to fit quite well apart from the nightmares with the rear wishbones.
As far as handling goes we'll see.
good value for money.
Thanks again for all your help.
155lee
06-09-2016 11:10 AM
S3an
26-09-2015 11:39 PM
The Enigma
12-09-2015 10:12 PM
truffleshuffle
10-09-2015 09:35 PM
cossirob
03-09-2015 09:17 PM
Quick Reply: help rear wishbone polybushes
