big turbo on zetec
big turbo on zetec
hi just came across quite a big turbo .84 twin scroll turbine housing and .60 comp how much lag would i get if i put it on to a 2l zetec. i have no idea what its off or know nothing about it. just wondering thats all
not sure what its off i got it for comp housing but just wondered what it would be like. usual spec big fmic 470cc injectors low comp pistons ect.
twin scroll turbo? so you will need a twin scroll manifold also if to use it,sounds slightly to big tbh mate.unless youve got dry sump and 9k rev limit lol
Dreamer
Surely it is just the same amount of gas just as a higher velocity due to how hard the engine is reving the displacement doesn't change the more rpm you are doing.
Provided you could get a Zetec 2 liter to rev to 9000 with any sort of power at that level.
Duratec head is so far ahead of any Zetec head, and even those require a fair level of
modification to flow enough air for a 9,000 rpm 2 liter.
pity the blocks don't lend themselves to big power!
They are an alloy blocked engine, which is great for high revving N/A but they don't like the cylinder pressures a turbo engine puts into them. There are some specialist Mazda racing blocks knocking around but you wouldn't waste your money putting them into an RS.
Rick
Rick
Matt Baxter
16-09-2015 08:30 PM
Escortdriver1
31-07-2015 02:36 PM
