Anyone whos fitted/adjusted Newman Solid Lifters
Wye Valley Hardcore
I fitted my cam last night and just want to make sure its all right. I tried to adjust them but couldn't set the lifters low enough. Basically, couldn't get two spanners on them to tighted the lock nut as they were so low, making the nuts close to each other with only 2-3 mm of space between the two. So I have doubled up the rocker shims, 2 rather than 1 and have now set them to 10-12 thou but on the lifters I now have about 12mm of thread showing. Just wondering if anyone else has had this problem?
Balls Deep!
No mate that totally wrong!
The exhaust has the bigger clearence as they get hotter and expand more for a start.....
If you look at the Newmans site it says In 0.008 and Ex 0.010..... sorry!
http://www.newman-cams.com/pdf/ford.pdf
as karlos said they are 8 thou and 10 thou, gota do mine again the weekend, all good fun.
how are you lot setting yours? i'v been doing mine rocking them, so rock the 4th and set the 1st, rock the 3rd and set the 2nd, rock the 2nd and set the 3rd, rock the 1st and set the 4th.
Balls Deep!
Wye Valley Hardcore
I just leave them all out, then rotate the cam so the lobe is pointing up, then rotate 180degrees so it is pointing down, drop in lifter, fit arm meassure gap, adjust whilst in situ (bit fiddley but saves some time), remove, lock off, refit and check, remove, adjust, repeat...
It always helps people understand why they have to re-check when they understand why they are re-checking!
It's the human nature of "can't be arsed" that kicks in, until a valve burns out and then someone explains why they should have re-checked!
Apprentices are the worst. If you don't explain why you are doing something and why you have to do something they either A/ ask loads and loads of stupid questions or B/ don't do whay you've told them and fuck it up!
SMILER258
28-09-2015 09:04 AM
