stupid lights GRRR help please
Old 24-06-2010, 08:29 PM
Tonyt1t
Grey Mk4 Early XR3I
Tonyt1t's Avatar
Default stupid lights GRRR help please
right basically ive had this happen on 2 of my cars but the last one i sold without fixing the problem
the thing is i put the lights on (first turn) sides and tiny amount of dip beam comes on then i put dip beam on and all thats left on is a dim side light yet full beam still works ????
ive changed the bulbs and ive changed the flasher relay and the switch inside the car itself ive checked the fuses and all of them seem fine changed the ones which looked a bit iffy but cant think what else it can be :S can any one help????????
must be a simple solution just me being blind or stupid or both!
any help asap would be great thank yooooooooou
Old 24-06-2010, 08:36 PM
wayne dowling
wayne dowling's Avatar
Got the same problem on my brouthers erst & thats the fuse box hope that helps
Old 24-06-2010, 09:16 PM
zetec-Sam
neeeeeeeeooowmmmm
zetec-Sam's Avatar
our old sierra did something similar, turns out the contacts on the rear light had corroded themselves together, shorting it out. Cleaned them up, and all was good
Old 24-06-2010, 09:17 PM
conor.rst
conor.rst's Avatar
I had the same problem it turned out that one of the wires that leats to the negative terminal on the batt had fallen out and was in the engine bay you couldent even notice it was missing .
Old 24-06-2010, 09:31 PM
botters
competant bodger
botters's Avatar
does sound like a wire short or a bad earth to me
Old 24-06-2010, 10:19 PM
Tonyt1t
Grey Mk4 Early XR3I
Tonyt1t's Avatar
ok thanks guys i guess ill check the earth straps tomoro see if i can sort it and let u guys know
Old 24-06-2010, 10:22 PM
botters
competant bodger
botters's Avatar
i would check all the earths for all the lights mate not just the straps between engine and body if thats what you meant
Old 24-06-2010, 10:30 PM
D4nny8oy
Fixing the bloody car...
D4nny8oy's Avatar
Mine had the exact same problem, and it's common on all mk4's AFAIK- it's a bad connection in the fusebox melting the wiring and dipbeam relay (if you pull the relay out you'll probably see it's burnt from the heat).
I found moving the relay about would restore the connection, but it would keep failing. Only cure was to bypass the affected part with new wiring and relay.
Old 24-06-2010, 10:43 PM
Tonyt1t
Grey Mk4 Early XR3I
Tonyt1t's Avatar
oh right ok :S will look into that to cheers and yes i meant the staps on the lights not just engine earth straps
Old 25-06-2010, 10:11 AM
mr_joe0606
mr_joe0606's Avatar
Only one off my head lights work first turn dip comes on second on the drivers side comd on and full beam works in both any ideas?
Changed bulbs and fuse's.
Cheers joe
Old 25-06-2010, 05:27 PM
Tonyt1t
Grey Mk4 Early XR3I
Tonyt1t's Avatar
that sounds like the little white relays in the fuse box they control individual lights i belive :s
Old 25-06-2010, 06:05 PM
mr_joe0606
mr_joe0606's Avatar
Can some post a pic ov there fuse box so i can compare to mine.
Cheers joe
Old 25-06-2010, 08:19 PM
mk1trb
Boost Junkie
mk1trb's Avatar
check earths on inner wings and the dip beam relay
28-09-2015 10:05 AM
The Enigma
12-09-2015 10:12 PM
fuzzy
04-09-2015 10:11 PM
Quick Reply: stupid lights GRRR help please
