ap racing clutch slipping?
Old 21-06-2010, 03:55 PM
essexRSTSouthend
essexRSTSouthend's Avatar
Default ap racing clutch slipping?
Hey everyone.Ive done about 20K miles on 4 paddle ap racing clutch.In the last year or so,the clutch would slip now and again but no enough for me to worry.but.. after getting my rs back on the road saturday,it now slip when hard on boost at 3K.Revs go mad above this.Driving normally it fine of course but then that beats the point of owning a rs.I thought they werent ment to slip! Was fine for first year of being fit.any help be great.Maybe new clutch!
Old 21-06-2010, 04:03 PM
Christian and Beccy
#1 in Spelling Club
Christian and Beccy's Avatar
20k miles?? Buy a new clutch!!
Was the flywheel refaced when it was fitted?
Old 21-06-2010, 04:10 PM
essexRSTSouthend
Yes mate,the flywheel was done.How many miles they spose to last for?
Old 21-06-2010, 04:23 PM
Christian and Beccy
#1 in Spelling Club
Impossible to say. Everyone drives differently and it's driving habits (not engaging/disengaging the clutch properly, hillstarts without using handbrake etc) that are as likely to kill the clutch as pure power.
Old 21-06-2010, 05:25 PM
keldsyke
keldsyke's Avatar
Is the clutch plate contaminated ( e.g oil leak ) As said above there are a lot of factors involved
Old 21-06-2010, 05:50 PM
essexRSTSouthend
car is running at least 212 of torque.As dyno figures were taken with standard head.now runs stage 3 so coule be more.Im sure i read they only took 169 torque but i must of misread or wrong page on ap racing.As far as im aware no leaks.I park in same spot every day and no signs.Had look around in engine to see,but still no leaks.Must be on its last legs.more money! :-p
Old 21-06-2010, 07:33 PM
muz
Wye Valley Hardcore
muz's Avatar
I'd be well chuffed to get 20k out of a 4 paddle running over 200ft/lbs personally.
Old 21-06-2010, 07:51 PM
Rick
Rick's Avatar
paddle clutches don't last on road cars.
Old 21-06-2010, 08:15 PM
Danster76
Danster76's Avatar
My paddle was slipping too. I've just changed It for an Ap2000-35, organic but it's the strongest escort Rs clutch they do. So far so good.
Old 22-06-2010, 08:29 AM
Christian and Beccy
#1 in Spelling Club
The CP2000-35 is better suited to a road car, due to the organic plate. Cerametallic isn't great for every day use.
Old 22-06-2010, 08:42 AM
crazycage
crazycage's Avatar
fuck im happy to get 4-6k from a paddle lol. Just change the plate to the above with your cover! will set you back 90 quid or so.
Old 22-06-2010, 06:49 PM
essexRSTSouthend
So its done me well lol.keep the preasure plate?is it worth the risk lol.thanks for your feedback.I never knew they only lasted short period.doh.
Old 25-06-2010, 07:55 AM
AP Racing
AP Racing's Avatar
Default AP Racing Clutch Slip - Response
The first question is which AP Racing clutch kit # was fitted?
If its part # CP2015-8 then this has a torque capacity of 170lbft (this can be compare to 170 BHP on a turbo). If the installation has more torque then the stronger option is required. Also check on removal to see If the driven plate thickness is worn down to 5.6mm if so consider it worn out , hence slipping the
issue! Also check for wear on pressure plate and flywheel drive faces. Paddle type driven plates are aggressive on drive faces.
http://www.apracing.com/info/products.asp?product=%3Cimg+border%3D%222%22+src%3 D%22http%3A%2F%2Fwww%2Eapracing%2Ecom%2Fpics%2Fpro ductpics%2FFord%5Flogo%2Ejpg%22%2F%3E+Escort%2D+Mk +4+RS+Turbo+%2D+CP2000%2D8+%2D+%3Cbr%3E+Organic+Dr iven+Plate_1446_1408
A better option is clutch kit # CP2000-35
This uses a high clamp pressure plate coupled to an organic driven plate, providing 230 lbft torque, but more user friendly a road application than a paddle type.
http://www.apracing.com/info/products.asp?product=%3Cimg+border%3D%222%22+src%3 D%22http%3A%2F%2Fwww%2Eapracing%2Ecom%2Fpics%2Fpro ductpics%2FFord%5Flogo%2Ejpg%22%2F%3E+Escort%2D+Mk +4+RS+Turbo+%2D+CP2000%2D35+%2D+%3Cbr%3E+Organic+D riven+Plate_1448_1408
This conversion may require the use of the MkV Pedal & Quadrant to achieve adequate release travel. These are Ford parts but see web page for details.
http://www.apracing.com/info/info.asp?section=Escort+Clutch+Pedal+Modifications _9
Any further queries - give us shout on 02476 883318
Pete
AP Racing
Old 25-06-2010, 08:25 AM
Versus_Creations
Ask me a question!
Versus_Creations's Avatar
Pete from AP?
Good to see you on websites with some customer relations. I think this is very imporntant for companys to give feedback and help via forums etc.
Old 25-06-2010, 08:35 AM
XRT_si
XRT_si's Avatar
Originally Posted by Versus_Creations
Pete from AP?
Agreed
arkeye
Ford Focus ST
20-02-2016 01:22 PM
The Youth.
30-09-2015 09:59 PM
Quick Reply: ap racing clutch slipping?
