buying new pistons, standard or low CR?
Old 27-06-2010, 10:48 PM
andy130
andy130's Avatar
Default buying new pistons, standard or low CR?
mahle pistons by the way, cheers andy
Old 27-06-2010, 10:56 PM
botters
competant bodger
botters's Avatar
standard have been used up to and over 300bhp so i would go for them, low comp will make it feel gutless off boost and due to modern mapping capabilities low comp isnt really needed anymore anyway
Old 28-06-2010, 07:55 AM
crazycage
crazycage's Avatar
as above
Old 28-06-2010, 09:56 AM
Karlos G
Balls Deep!
Karlos G's Avatar
Old 28-06-2010, 02:53 PM
vroooom ptssssh
It Wasnt Me!
vroooom ptssssh's Avatar
I'd go for Low comp. Less chance of detonation, can run more boost safely..and as for it feeling gutless/less responsive, I couldn't dissagree more and I personally think you'll struggle to tell the difference.
Old 28-06-2010, 04:49 PM
Karlos G
Balls Deep!
Karlos G's Avatar
I went from low to high (7.5:1 to 8.5:1) with nothing else changed except for dropping from circa 1700cc to 1600cc (81.5mm to 80mm) and the difference was huge! Much more responsive off boost, and spools at least 500rpm faster
Old 28-06-2010, 05:22 PM
Canada1
Canada1's Avatar
I also agree with Karl.
8.5:1 CR is already low compression.
Unless one want to boost at 2+ bar, super low compression is not required.
And if you are running 2+ bar boost, much better to find a high flow cylinder head and
intake so you don't have to run the boost that high to make decent power.
KW-rscos
11
31-08-2015 01:51 PM
blackbeautyzetec
29-08-2015 02:11 PM
ekjim
17-08-2015 08:57 PM
A.t.p
15-08-2015 11:37 AM
Quick Reply: buying new pistons, standard or low CR?
