MTX75/ST170 6 Speeder?
Decided im going to fit one of the following to my zetec turbo.
Anyone fited them? Need some info on them etc...Pics would be good!
In terms of shafts i know Jano and Sitech make customs one for both boxes, but has anyone made any? If so have you and pics sizes lengths etc??
Matt
Matt
So how would it be done? I know you'd need to grind a bit of the block on the Silvertop as the starter fouls on the edge, and on the Blacktop the sump has pickup points for the gearbox itself. Then I am assuming that you'd need to make a custom bracket up to enable the use of the equal length driveshafts on the silvertop block?
Failing that I'd love to be able to fit the 6 speeder into my Mk1 - but using the same bolt holes/front starter as a BC box as then I can mount it on a bearer and not have to faff with custom mounts.
Possible to weld a BC bellhousing to a 6 speeder?
how manny time's do i have to tell you this ? the focus rs is a mtx!! it is the same as any focus mtx .but not the same as the old stity mtx from a rs2k and only one bolt hole on the top mount different from the mondeo mtx.
I do apologise! Forgot about that thread! Thanks for all the info though, im just trying to get my head round what to go for and what i need to get for it lol!
gear stick and cables from a focus (but must be from one that has a mtx fitted)
clutch and flywheel (any 2.0l zetec flywheel and a focus rs clutch)
custom top mount for box (i can sort this if you want)
focus rear gearbox mount
and a set of shafts
then you just need to sort the hydraulic clutch ( i do a kit that bolts in)
box from a focus (you can pick up the rs when you find one)
and a set of shafts
and a set of shafts
Thanks mate thats very helpful!
I may need the mount and hydraulic clutch kit off you. Pm me prices
well for 1500 you can drop the car off and in 2 weeks pick it back up again all done and fitted including the focus rs clutch (with normal mtx box unless customer has the frs box then the cost of our box is taken away) only thing that would need doing is the new mounts colour coding as we leave then seem sealed and primed for customer to have that sorted at a later time
you could get a addaptor plate made from ally easy tho.
I'll look further into it.
BLACKCOS
21
20-11-2008 07:01 PM
