- Bosh 803 green injectors
- saph coz jacking cover
- Wanted ! Tremec tko 600 6 speed box??
- Good Spec Rs Turbo Wanted
- L8 stage 3 chip wanted
- stage 2 turbo for escort rst s2
- good 044 pump
- Siemens 55 blacks
- alloys for a mk 2 golf
- camshaft from a 1997 1.1 saxo
- s1 or s2 hybrid turbo unit
- Sierra 2wd Mats
- 2wd sapph steering column cowling
- Escort Cosworth
- Comp MO's 17" 5 spoke (pair)
- t2 turbo
- fiesta rs turbo shocks
- Boost Gauge and 2wd dash surround
- Couple of saff parts wanted if anyone can help
- Wanted 17" Momo Arrows with tyres
- escort cosworth wiper motor and rack
- 3 door roof lining, carpet and sun visors wanted
- 2wd saff gear knob
- WANTED - Rear quarter interior panel off a Esc Cosworth
- mk2 xr2 kit
- mfi loom wanted !
- Series 1 dashboard
- rs turbo bottom end
- Wanted Transit 16" Alloys
- lowering springs to fit 4x4 saph.
- 3 Door Cosworth rear Fin & Front Bumper WANTED
- fiesta mk2 twin head lights !!!!!!!
- 2wd cossie diff
- idle speed control valve???
- fiesta turbo top boost hose
- Transit Connect or similar!!
- L8 ecu with pectel board
- Rs Turbo chrome engine bits
- s2 front mount
- IGNORETHIS THREAD, THANKS! S2 LSD Gearbox
- cosworth paddle clutch and pistons
- full escort rs turbo interior 88 spec
- Auxillary belt tensioner for 4wd Cossie
- rs500..
- 4x4 dash tray
- cossie boot spoiiler
- Small Turbo Escos Fuel Pressure Regulater
- wanted mk2 mondeo bumpers
- T5 Speedo/Worm Drive
- Wanted Snap-on scanner
- t3 turbo
- zetec bits
- 9"x18" MOs
- Focus rs bottom end
- saff 2wd Idle speed control valve
- 1 x Fiesta ST alloy wanted
- sapph cossie bumper
- rs turbo pistons. and escos grill
- Ford split rims wanted
- Boost Gauge
- LHD Cossie Parts - where from
- 3" outrolled scorpion backbox (pref series 1 rst)
- focus rs rods and pistons
- st170 gearbox bits
- bucket seats and harness's
- wanted rs7spoke softspoke/softlines SWAP for 5 escos rims
- floor carpet
- Adaptater for hose on a T34 with restrictor
- 3dr 2wd standard parts
- frst drum back plates
- 3 door Cosworth parts needed
- P8 ECU
- 16inch mondeo wheels
- WANTED - 08 model Focus TDCI in black
- WANTED: Cheapie Sierra Sapphire
- series 2 centre dash holder and pillar
- New PF01 throttle position sensor wanted.
- bmw x5 auto gearbox
- Escort cage
- Wheels + Tyres for my RS Turbo
- Saph shell required
- 3.9 diffs and saph boot carpet mat
- mint 2wd parcel shelf
- has anyone got !!!
- Wanted sapphire lights please
- new shape st focus shell
- RS Turbo engine
- 3 Door Roll Cage
- T34 48 Housing in Good working order
- mint series 2 sunroof
- RS turbo pistons
- Aquamist water injection kit
- 2wd fuel reg bracket
- t34 turbo
- Turbo Water Metal Return Pipe 4x4
- 3 Door cos grill
- 2 wd crank pulley
- ford 1.8 tddi head, poss engine
- mondeo gearbox
- mondeo st24 drivers seat
- OZ rally 8x17 wheels (same as Monte)
- Sapphire cosworth switchs
- fse power boost valve
- escort cosworth gear stick
- Saph headlight protectors
- CVH Cam Belt BOTTOM pulley
- Escort mk6/mk5b tailgate
- Cosworth Saph parts wanted
- rs2000 s/s exhaust 2wd wanted
- s2 headlights[brand new]
- corsa b redtop conversion kit!
- fiesta rs turbo pop out windows needed
- 2wd Saff interior & boot carpets Black.
- s2 front mount
- 3dr cosworth wheels
- ap 4 pot 2wd saff front brake kit
- Wanted: Genuine RS500 Front Bumper
- New 90 amp alt
- sold sold
- Standard Cosworth Rear Brakes
- 17 inch RL7's saph fitment
- Part worn tyres wanted.
- LHD electric mirror interior plate
- Cross Over Pipe with side exit D/V Outlet
- 2wd saph fuel cap
- sierra 3 door shell
- Part worns.
- escort rs turbo front shocks+rear shocks
- st170 headlights and spotlights
- escort s2 full interior
- Standard rs turbo alloys
- OSF sapph fog light
- S2 front mount[pro alloy]
- rs turbo heat shield
- 3 door grille
- rs turbo cage
- escort rs turbo vented bonnet and ofac ecu wanted in essex
- 5th Gear Puller RS Turbo Box
- series 1 recaros
- Wanted Genuine Escos rear spoilers and airbag wheel
- 18" Raceline RL7's
- Cosworth Front Splitter
- MK4 Escort Shell or MK2 XR2 Shell
- mk3 escort RWD shell wanted
- Vauxhall people
- s1 turbo shell wanted
- mondeo st24 2.5 v6 front exhaust pipe
- 16 or 17" alloys for mk6 fiesta
- FRST ecu chip
- 60mm springs for s2
- sierra rear window switch
- Mk4 boot ASAP
- 42" lcd tv broken
- RWD Glove Box Lid
- Escort cosworth rear bumper
- o/s 3 door wing
- Ford Escort GTI Black
- series2 lsd box
- fiesta rs1800 Gearbox
- Cosworth. 2wd or 4x4. Saf, 3dr, Esc cos.
- Series 2 RS turbo gearbox
- nsf jack point cover fo sapph ***GOT ONE***
- nice set 5 stud alloys
- Cossie T3 Exhaust housing
- nice saff wanted
- azev a wanted
- vibra technics 2wd engine mounts wanted.
- fiesta rs turbo engine mount
- Escort Cosworth Front ABS Sensor
- mk4 sunroof
- Ford 6000 cd/radio
- power boost valve for zetec
- watend: small turbo EsCos High Flow Oil Pump
- cosworth pistons
- ERST 88 spec chrome rocker cover
- FRST chip
- Cosworth h/d Clutch cover
- RS 2000 MK5/6 alloy wheels
- cosworth parts needed
- Dunlop D4's
- rs turbo series one oil breather ,header tank or swirl pot
- Focus RS alloy
- big break set up for 2wd cosworth
- sold sold
- 2wd subframe
- mk5 rs2000 fusebox
- STD 4WD pistons asap
- 17 / 7 silver comps
- zetec bits
- zetec bits
- 3dr cossie wheels
- wanted saph cossy front bumper
- wanted ap 6 pot callipers
- escort 1.8 zetec mk6 1997 exhaust backbox
- escort cossie or mk5 rs2000
- Possibly wanting a l8 ecu with standard baby board
- S1 turbo exhaust, clear indicators
- standard 88 spec orion or escort bumper
- cosworth 2wd dipstick
- sapph front bumper
- rs turbo center caps
- fuel pressure gauge
- mk4 escort any type inc orion wanted scotland
- Escort rs turbo lsd gearbox
- Looking for mk3/mk4 escos shell????
- Cheap set of 15" alloys to fit an Orion
- T3 for erst wanted s2
- 17 inch rs 7 spoke alloys
- 13 x 7's for Mk1 Fiesta
- Wanted: 18" 5 Stud Mondeo 10 Spoke Alloys
- rs turbo cvh head and all the gubbins for an efi conversion
- 3 door locks
- anyone got a damaged 3dr or escos front bumper
- white hood
- injectors
- ap 4 paddle clutch
- grs s2 intercooler and fan
- Wanted: SECS monitor
- wanted 3dr bonnet vents
- cosworth 63 turbo exhaust housing
- CVH Block
- 3 door escort bonus mk4 or mk3
- 3 dr/rs500
- Black top zetec block
- S1 parts
- Mongoose exhaust Sierra Cosworth 4x4
- sunroof and mech for a mk1 sierra
- 4x4 cosworth big wing sump
- mk2 escort boot spoiler
- New Loom
- vr6 splitter
- chrome fiesta rs turbo
- Roll cage cosworth saphire
- EDIS, Coil pack and Crank Sensor wanted for Megasquirt install.
- wanted mk3/mk4 3dr escort shell
- roll-cage
- Escort Cosworth Shell
- -31 actuator
- Cosworth 4x4 T34 63 turbo wanted
- Wide alloys to fill x pack arches
- -31 actuator
- 3dr cossie bumpers
- Escort cossie alloys
- wanted cossie brakes for my s2
- S2 bonnet vents
- Cosworth clutch pivot post
- 2wd cossie, oil pump + pick up pipe wanted
