PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 2wd Cossie water pump to radiator hose
  2. Wanted: BMW E36 323i Sports Touring
  3. Amplifier Wanted
  4. Wanted... Escort RST Series 2 Alloy Rad
  5. Wanted Escort Cosworth Engine Loom (BT)
  6. Sierra sapphire fuel cap
  7. Esc Cos Side lights
  8. WTD - 18" Revolution Milleniums - ET35ish
  9. mk1 fiesta panels
  10. Escort RS Turbo brake kit wanted
  11. flint grey bumper
  12. frst mounts
  13. How much can you get som comps for?!
  14. Sierra/Granada rear diff open/welded ASAP
  15. Wanted:Focus rs stainless steel exhaust
  16. Wanted 90 spec passenger side spotlight bracket
  17. land discovery 2 es v8 auto wanted
  18. wanted 17inch 5 spoke comps or revolution's in white
  19. escort mk3 dash
  20. Wanted .63 housing for a t34
  21. 1.8 Pickup pipe and flywheel please?
  22. WANTED Escort MK2 RS2000 in any condition
  23. Wanted MK2 Escort RS2000 in any condition
  24. Saff cos interior 4x4 cam belt cover
  25. 5 x 100 alloys wanted
  26. a set of wheels must be ford fitment 15inch or bigger
  27. WANTED... xr3i spotlight 90 spec
  28. fiesta rs turbo bonnet
  29. cosworth 4x4 front sub frame complete
  30. mk1 and mk2 fiesta bits
  31. ERST suspension wanted
  32. Focus rs mk1 bits wanted
  33. airtec slim line fans
  34. Cheap escos wheels without tyres
  35. 18" 4x4 tyres, 255/55 x 18" Range Rover,discovery size etc..
  36. RS Turbo Alloy Rad
  37. STD exhaust cam *urgent*
  38. S2 bits and bobs
  39. MT75 Gearbox casing
  40. VW VAG Help -Mk5 Golf 1.6 FSI ABS Pump Required
  41. Cosworth 16" Alloys, Mondeo 16's or RS7 17's
  42. escos leather door cards wanted
  43. Saff Cossie Bonnet Vents
  44. xr2i/3i engine wanted, near Dorking Surrey
  45. Mk3 bonnet wanted - must be VGC
  46. Fiesta bits
  47. cheap winter hack car/van
  48. Zetec Turbo Parts Wanted
  49. OZ Racing Wheels Wanted
  50. S1 Arches and Skirts
  51. saph headlight wipers
  52. Discovery series 2 bits & wheels wanted
  53. Fiesta bits
  54. 1.6 se engine
  55. wanted bailey mirror image breather tank
  56. 4x4 cosworth gearstick
  57. 4wd ally/billet fuel rail
  58. Wanted s2 90 spec or 88 spec front bumper
  59. anyone got a scrap cossie exhaust?
  60. adjustable TCA's and comp struts wanted
  61. scooby centre decat pipe.
  62. cosworth YB head
  63. sapphire n/s rear quarter
  64. S2 Front Mount
  65. 88 spec cabby rear seat back
  66. 44mm external wastegate, black mk3 esc carpet, mk3 front panel
  67. Black powder coated cosworth breather
  68. 4x4 rear arms .hubs/carries
  69. WANTED 4x4 head
  70. wanted Engine mounts for V8 Capri
  71. Escort cossie doors wanted , mk5 escort doors
  72. ST170 Standard Springs
  73. Wanted- Scrap cossie head and block
  74. 16" 5 Spoke Comp MO
  75. RS/COSWORTH Track car wanted upto £5k
  76. Mk6 fiesta facelift front and rear lights
  77. GT30 turbo (Internal Gated)
  78. mk V escort fuse box
  79. Focus RS MK1 bumper vents
  80. Red n/s rear jacking point cover mk6 rs2000 gti
  81. Peugeot 106 1.1 Gearbox
  82. 60mm lowering springs
  83. anyone breaking a mk4 escort ??
  84. Resolved.
  85. Cheap 52mm boost gauge needed w u got
  86. 3dr Cosworth Bonnet
  87. race technology,stack etc
  88. big cossie cone filter
  89. 4x4 inlet
  90. escort rs turbo parts needed asap please help!
  91. shark tooth center cap
  92. 4x4 sharktooths
  93. wanted escort cosworth original stereos
  94. BMW E46 330d - Up to £4000
  95. 3 Door Cosworth - Door Card Pocket wanted
  96. Piston ring need URGENT
  97. Escort S2 Bits Wanted
  98. MK6 Escort rear seat backs with headrests
  99. steel wheels
  100. Fiesta rs turbo charge carrier
  101. 4x4cossi alloy mounts
  102. Needed ASAP fuse box
  103. Cosworth specification plate
  104. ***3Dr Cosworth header tank water Level sensor***
  105. DISKLOK
  106. 3 Dr/ RS500 Standard Ride Height Springs
  107. Open or already welded rear diff for 2wd cos
  108. Cosworth screw in oil cap
  109. deleted
  110. Cosworth 4x4 Running Gear
  111. rs turbo paddle clutch
  112. Escort mk 2 rear lenses propper rubber gasket
  113. xr4x4 front driveshafts
  114. OFAB loom
  115. Escort rs turbo bottom boost hose
  116. 35/38mm external wastegate
  117. cheap 2wd cossie rear diff
  118. 50mm gpA Bilstein strut bodies wanted
  119. Wanted EFI parts....
  120. Fiesta RS1800 heatshield
  121. 90 spec bumper
  122. 4x4 cosworth sump
  123. Mk3 Fiesta Outdoor Cover
  124. Mondeo V6/Cougar 280mm brakes
  125. 5th injector set up rs turbo
  126. Esc cos wrc wing mirrors please.
  127. 3 door grille
  128. GT30 63mm turbo hose and black vernier pulleys wanted
  129. rs1600i parts!
  130. Sierra cosworth battery tray
  131. focus mirror in grey
  132. level 6 ecu
  133. white 3 door cosworth wanted!!
  134. rs turbo door card
  135. Cosworth Intake Manifold
  136. MK6 Fiesta Wing Mirror covers
  137. 2wd Cosworth coilovers and big wing sump
  138. Wanted - Emerald ECU
  139. Wanted (1)rondell 18" bmw stud pattern 5x120
  140. mk3 fiesta
  141. 2wd Saff Boost pipe
  142. 1.8 zetec flywheel asap
  143. anyone got sea fishing multiplier for sale
  144. WANTED : YB intake manifold...
  145. 215/35/18
  146. Sierra cosworth leather front seats or centre pads wanted Desperately
  147. Big Spec Rs Turbo Wanted
  148. MK1 Focus RS alloys
  149. ford racing puma parts
  150. carcoon wanted
  151. sierra saphire lowering springs or kit?
  152. Comp Mo's
  153. 172/182 Clio Sport Coilovers
  154. Megane 1.9 dci
  155. 3dr Sierra for project (Still looking...)
  156. off roader 4x4
  157. Wanted-Escort Cosworth
  158. Wanted-Escort Cosworth
  159. 2.8 cologne Thermostat housing!! URGENT!!
  160. Cosworth YB crank toothed pulley
  161. Rs turbo fan switch-plug
  162. t 35 turbo oil return
  163. 16i bits
  164. mk3 escort carpet in black
  165. Ford Focus 115ps TDCI
  166. mk1 focus rs mats please
  167. 4x4 cosworth turbo manifold
  168. fiesta mk 3.5 bits needed sasp
  169. RS Turbo Bottom End efi
  170. Escort MK4 Standard Interior & 1.3 Engine
  171. .63 housing for t34 - wanted
  172. escort rs turbo spotlights
  173. A car!
  174. loads of sapphire cosworth paarts wanted
  175. 3 door mk3 escort shell, must be solid
  176. Zvh bottom end
  177. New style 17 inch comp mo's for a saph
  178. Wanted, few sapphire bits please!
  179. A car!
  180. 3 door alloys
  181. xr4i rear drive shafts
  182. 3 door wiring loom (in car not engine)
  183. 2wd Cosworth AP 4 pots wanted
  184. Mondeo MK3 Wheels...Alloys or Steels just for winter
  185. wanted 3 port ggr breather
  186. 2 new or very good compomotive blue centre's
  187. Wanted-Laguna Splitter
  188. zetec wiring loom and non pats 2ltr ecu
  189. wanted escort cosworth leather interior
  190. Cossie 2WD Inlet Manifold
  191. Nissan pulsar plenum cover, OEM or Aftermarket
  192. ford fiesta rs turbo coil pack/bracket
  193. focus rs grill
  194. 1.8 zetec fly! frst charge carrier!
  195. Rear Bumper wanted for mk6 escort van ....
  196. urgentley needed cash waiting
  197. 4 paddle clutch
  198. 2wd cossie downpipe
  199. over size pistons
  200. escort cos 500 intercooler
  201. Siemens 83Ib injectors
  202. GT2860rs turbo
  203. 4x4 cossie front coilovers
  204. WANTED granada 5 stud hub flanges
  205. S1 pop out windows and rubbers
  206. Ka Dashboard, black.
  207. 2wd driveshafts
  208. wanted saff cosworth cloth trim
  209. rs turbo lsd
  210. saff outdoor carcover
  211. stat housing
  212. 4x4 bonnet
  213. WANTED: rs7 softline, brum
  214. 2wd Sierra Cosworth Parts...
  215. A long Shot, lol
  216. 2wd crank pulley wanted
  217. 3dr cosworth (sierra) door pockets
  218. Rs turbo van
  219. Crosman Airgun Wanted ASAP
  220. Sharktooth alloy
  221. Cosworth 4x4 oil modine securing bolt/adaptor
  222. cosworth rear housing
  223. white erst s2 shell
  224. Braided hoses
  225. zetec s front bumper
  226. Mondeo zetec centre caps
  227. mk4 xr3i perol tank wanted please....
  228. rs500 lower spoiler wanted
  229. anyone in the process scrapping a mk 4 escort ??
  230. WANTED: Cosworth Replica
  231. ignore
  232. Urgently wanted 3 Door Recaro Seat
  233. missed the boat?? rs 1600i
  234. cossworth exhaust
  235. 3 Door Recaro Seat
  236. YB crank wanted
  237. 4x4 Exhaust Manifold/Std 3dr rear box
  238. Sierra Sapphire bits.
  239. Mk4 shocks & springs
  240. S2 Warm up regulator + other bits
  241. Tired Cosworth TCAs, spares for parts
  242. Does anyone know where i can get a chassis tag for 2wd sierra cosworth
  243. not a ford iknow but im after a r5 gtt
  244. P8 ECU Bracket..........
  245. escort rs turbo
  246. RL7's and/or MO's
  247. escort mk4 xr3i
  248. Indicator lights for Sierra RS Cosworth
  249. s2 erst roll over spit
  250. white erst s2 shell
