View Full Version : Cars & Parts Wanted.
- Mk1 Focus RS May PX 2wd Saff Cosworth
- 2wd trouser section bolt
- 2WD saph pedal box wanted
- mk2 focus ST speedo cluster
- Bladed rollbar wanted 2wd cosworth
- New battery!!!
- White 2WD Saphire sierra cosworth rear bumper
- 3dr steering wheel
- EDIS 4 module wanted... OFAC FIESTA TURBO
- Ford body launguage folder.
- Saff Cosworth grey dash + Carpet & O/S rear Amber light.
- RS500 Lower Rear Spoiler WANTED
- 2wd stainless steel turbo damper
- Mint 90 spec front Recaros wanted.
- frst gearbox speed sensor
- Any escos for sale? >£25k
- MINT cloth trim sapphire cosworth
- wanted: 1 x old style comp m06 17" 8j 4 x 108 pcd
- Saph front bumper Fog Light Wanted
- Standard 2wd header tank and pas tank
- Remove Idle Control Valve
- FRS mk1 A2A
- 2wd cosworth brake pump
- Frs mk1 6pot calipers
- 2wd parts needed
- sierra light
- 4x4 front hub flange
- Zetec turbo t3 manifold
- 3dr Sierra Cosworth carpet wanted
- Wanted - RS Steering wheel centre pad
- Series1 parts needed
- p8 anti lag board
- Wanted big spec rs turbo or mk3/4 cossie
- Cosworth 2wd front crossmember
- Alloy plenum pipe.
- sierra manual sunroof
- Focus RS Uprated Turbo Wanted
- Mint perfect working order cosworth iscv but a genuine 1 not a copy
- Focus rs/St 2.5 manifold wanted
- Fiesta mk1 XR2 or supersport parts
- rs turbo coilovers
- 2wd front hub grease caps wanted
- Focus rs/St 2.5 management ecu
- Breather bottle wanted
- rs turbo rear hubs
- P8 ecu
- Quaife thick wall ATB front diff
- Wanting escort mk4 black bumper and indicator
- WANTED ASAP saph rear bumper in white!
- Bias pedal box Sierra
- Wanted turbo to make 450-500hp
- escort series one recaro seat material.
- Wanted good spec. cosworth engine
- Uprated engine mounts xr4x4 cosworth
- Wanted: T6 for 8 injectors
- MF2 5th Injector & Unlimited Boost ECU, Mk6 Gearbox
- Escort cosworth parts
- Mk4 escort car loom.
- series two backbox
- Ford Sierra bias pedal box
- Fuel cell wanted
- Race technology dash or stack dash, boost gauge water temp gauge wanted
- Standard Cosworth airbox
- series two front koni dampers
- Cosworth xr4 tank in tank sender
- Focus 2.5 injectors 750cc, 500hp turbo
- HO inlet manifold (rs1800)
- 3dr cosworth washer bottle wanted
- 2wd sapphire t5 gearbox mount wanted
- Cossie 4x4 Head Wanted
- Escort cosworth rear bumper mount.
- fiesta rs turbo ofab parts
- Wanted: saph 4x4 turbo oil return/drain pipe.
- WANTED escos BT sequential box
- mk4 escort mercury grey drivers door wanted
- old style compomotive 6 spoke 18/8 et15
- Saff window rubbers URGENTLY REQUIRED!
- Wanted,Cosworth diff prop flange
- Wanted,Old knackered 2wd cosy prop
- Nice Spec T3 Turbo for my Zetec Turbo build
- st170 washer jets inc covers
- L 8 baby board
- 3dr Cosworth standard radio
- Rs turbo rear coilovers
- Cosworth Grp. A or escort WRC
- Sapphire Cosworth wanted
- 2wd Cossie bell housing modded for hydraulic clutch
- Escort cosworth p8 pectel board
- RS500 Airbox
- koni front springs
- 2l pinto head - pref injection head
- escort series one arches or full body kit
- Escort Cosworth Banana Pod Gauges
- Wanted: Siemens 83lb injectors
- Single 8x17 alloy
- delete
- Rover Turbo Inlet or Similar for Zetec Turbo
- Sapphire cossie osf door wiring gaiter...
- Sierra/Granada 2.0ltr power steering pump WANTED!!
- Cosworth .48 exhaust housing
- Escort Cosworth front diff, front hubs and driveshafts
- 4x4 cossie heatshield
- Saph cos fuel pump cradle mounting rubbers
- 1 x 3 Door Original Alloy Centre Cap
- Wanted Sierra nsf inner wing headlight plate
- used wrc breather system wanted
- wanted .63 exhaust housing for cosworth
- Wanted -sapphire RS COSWORTH or series 2 RS
- escort rs turbo downpipe
- 18" reps
- Escort Cosworth
- cosworth top fuel rail wanted
- T5 speedometer plastic gear needed
- Mk4 escort ABS part
- 2.0 Zetec Blacktop Head
- WANTED-sapphire cosworth lattice alloys
- MK4 Escort tailgate strutts and fixings
- WANTED ASAP, ERST Std Piston.
- WANTED Escos PAS pump
- MK4 Escort window mechanisms
- Standard YB bits
- T5 box wanted
- 18inch rims Wanted...comps/Cromodora/Oz etc
- Mk1 Focus RS injectors
- ID1000 Injectors ***SORTED***
- Light blue injectors
- Wanted: Spring for sierra pedal box rod...
- Wanted: Trimmed shell escort or saff
- WANTED Stack boost gauge
- WANTED Stack ST8130P
- mk4 escort cabriolet roof wanted
- escort mk3 dashboard wanted
- wanted 3" 2wd down pipe
- mk3/mk4 escort rear strutt tops
- WANTED twin pod pillar
- cosworth speedo drive
- Comp th2's 17" for rs turbo
- Sierra 4" outrolled lip exhaust back box
- Escort cosworth front pipe mongoose or similar
- Wanted, Saff cossie Morettes
- 2wd rear stubs
- WANTED Focus Rs Mk1 Shell
- various 3" boost hoses
- Sierra saph handbrake lever/mechanism wanted
- WANTED standard escos radio
- sierra 4x4 steering wheel
- Where to get a 3 bar map sensor from ??
- Wanted escos tool kit
- wanted mk3 fiesta rs / xr front bumper.
- WANTED escos WRC Wings
- trim for around sunroof handle
- ST escos phase sensor
- 15mm & 20mm eibach spacers for focus RS wanted
- WANTED ESCOS towing eye
- 4x4 saff front wheel hub needed
- sierra saph caged shell wanted
- WANTED ESCOS A/C switch
- Mk1 focus rs grille
- Sierra rear mudflaps
- Sierra cosworth throttle cable
- saph fuel pump cradle wanted ??
- Wanted - mk3 fiesta smoked rear lights
- cosworth 2wd drive alternator with pulley
- cosworth block turbo oil feed union
- BOA ENGINE WANTED ASAP (24v cosworth)
- Wanted Tilton clutch parts
- **WANTED**Escos special parts
- WANTED Cosworth heating vent
- Escort Cosworth 18" Replica Wheels
- MK1 Escort - parts needed
- Sierra 2.0 dohc sump needed plz
- Cosworth 7.5" rear diff
- Saph cosworth rear ambers.
- Mk1 focus rs
- Mint condition A Pillar trims for mk4 RS turbo (Heated Screen)
- Full leather interior wanted either cosworth or RS turbo
- 2WD Dipstick *SORTED*
- ST170 headlights
- Mk1 focus rs front bumper and side skirts wanted!!
- Type 9 inner synchro hub
- 200 block,crank wanted
- escort mk3/mk4 cabriolet interior
- courtesy light switch
- B&m quickshift escort Rs turbo wanted!!
- needed trim quarter glas 3dr sierra
- RS Fiesta Reverse Charge Pipe Wanted and RS Turbo Cross Over Pipe
- front mount cooler for s2
- 3 Door Roll Cage
- 2wd fuel rail and pressure regulator
- screws for steering column surround/shroud
- Mk2 Mondeo Rear Heated Screen Switch
- cossie powered focus wanted
- rs 500 grills wanted
- January 2015 Fast Ford Magazines
- Stack st200 rev counter switch(st510)
- half or full leather interior wanted
- Clean 90 spec front seats wanted
- Wanted- fiesta rs turbo front mount intercooler, alloy rad
- looking for one of these
- 2wd cosworth diff or just the flanges 108mm
- 3 way tarmac spec coilover (like proflex)
- exhaust housing for a t34.63
- WANTED: Tarcal front strut brace (cosworth)
- Mongoose exhaust system. S2 turbo
- think in need shocks
- Escos steering column
- Standard Escort cosworth cam belt cover
- WANTED T5 reverse fork
- wire amp c420 escort cosworth T35
- WANTED - Roll cage for RS Turbo Escort
- 2WD Coilovers
- Saph 2wd ex manifold+f.pump cradle
- Steering wheel boss for escort mk3/4.
- Cosworth 2wd propshaft
- cosworth 2wd parts wanted, traveling to Gatwick area tomorrow will collect near area
- Wanted 200 block
- Big spec saph wanted
- Cosworth Trailing Arm
- Saphire 4x4 exhaust
- escort cosworth alloys
- zetec rwd turbo engine wanted
- cosworth downpipe t34 boost hoses and ancilary hoses in ble and a baileys breather
- Escort rs turbo water pipe
- please delete
- WANTED: S1 interior or XR3/3i
- Fiesta RS Turbo OFAB Map Sensor
- 4x4 steering coupling
- s1 or s2 cossie powered help
- Bells for 2wd saph and 370mm discs
- Fiesta RST.Air filter box housing
- Diesel escort van ib5 gearbox
- Tow Bar MK3 Orion / MK5 escort.
- RS Turbo LSD and ib5 (ka) gearbox wanted
- Escort combi van wanted
- Escort cosworth o/s inner arch liner
- Mk2 Escort Rs
- Fiesta rs turbo
- Uprated 2wd diff mount
- wanted uprated diff mount, solid beam mounts
- Wanted Stack 80mm 4bar Booost gauge
- Clutch Alignment Tool
- 2.0 zetec
- Saph sharktooth alloys wanted.
- Fiesta interior door handles
- Wonted dead MT75 4x4 gearbox
