View Full Version : Cars & Parts Wanted.
- R@D plated diff
- R@D plated diff
- T4 Air box lid
- FIESTA RS TURBO
- magenta spoiler
- standard 2wd cossie heat shield off a sapph
- ZS Engin
- 90 Spec Boot Spoiler and Front Bumper
- Sapphire 2wd/early 4x4 cosworth rims
- wanted
- mk 1 or 11 xr2 wanted
- bonnet vents
- series 1
- cosworth 4x4 stainless exhaust + induction kit wanted
- SAPH CARBON FIBRE BONNET
- S1 ecu
- Maram shaft to fit T34...
- LOOKED EVERYWHERE! RS Turbo WANTED
- large cosworth k&n air filter
- bosch 044 pump(s)
- greys & fitting kit
- S2 rs turbo polished strut brace
- MK1 OR MK2 RS WITH COSSIE POWER WANTED
- Cossie 2wd engine loom
- scort mk6 parts
- s2 cossie management !!!
- standard escort rs exhaust WANTED
- late 2.9 XR4x4 wiring loom needed
- uprated front brake set up for 4x4 saff
- wanted compleate s2 turbo just need running gear loom,engine
- sapphire cosworth 2WD wanted please!cheap!
- intercooler
- 90 spec headrests needed!
- uprated cosworth 2wd diff must be uprated
- metering unit
- items needed
- Sapphire Front bumper, Diamond white not usual shite please
- zetec head
- CARBON WING MIRRORS FOR A ESCORT COSWORTH
- RS Wanted must be standartd and mint
- BDA Engine
- 3 door cossie parts plus cossie wheels
- 4x4 sump
- escort mk4 headlights
- rfx wheels
- Escort Cosworth Parts
- Vernier Pulley
- S2 ERST top boost hose
- COMPOMOTIVES NEEDED!!
- very cheap 2wd saph wanted(running-working only)
- In desperate need of a S2 top hose !!!! and other stuff
- RED SAMCOS
- EEC 4 Small Tubo Cosworth pulleys wanted
- wanted! fan bracket for s2 pace double capacity intercooler
- cossie management
- SERIES 1 LOOM
- Escort Cos. plastic parts
- S2 RST & 3i bits wanted pref in north east
- S1 / S2 Gearbox
- W: 2wd Cosworth oil sump
- Standard Cossie Radio Amp....SORTED NOW
- DUMPVALVE FOR S2ERST
- Various Cosworth bits wanted...
- idle sontrol screw
- 1600 Cylinder head
- T6 2000 36.1 Front crank pulley ....
- some body must hav 1
- BRAIDED BRAKE PIPES FOR FRONT AP 330 KIT.
- need escort/orion 1.6 asap
- rs turbo carpet
- Cologne Tripple Webber Manifold
- WANTED RS W.H.Y
- Decent Boost controller
- Carberuttor air filter
- Integra Type R
- wanted fiesta rs turbo
- s1 or s2 rst damaged?
- ht racing cossie yb into mk2 escort sump
- 3dr rear window trims
- mk4 escort shell can be rotten bet must have good roof and
- MK 3 Escort/old Project (GOT 1) MODS PLEASE DELETE (Thanks)
- 4x4 cossie gearlinkage clip
- escort 1.8 16v 1998 chip wanted
- 3 door uncracked dash!! upto a £1000.
- 90 spec rocker cover s2 turbo
- very good cond s2 inside door handles
- anybody got a rebuilt s2 box for sale?
- 4x4 flywheel!
- s2 rebuilt gearbox
- oil return hose
- ERST standard steering wheel
- Escort Mk4 Glove box with or without lid
- rear diff wanted for 2wd cossie sens price please no shi-
- B&M 2wd quick shift kit or similar
- pink fuel relay 4 xr3i man fuel inj need 1 asap please help
- Adjustable bias pedal box for Sierra
- car trailer
- S2 Head
- oil return pipe from turbo to block
- PF09 TPS
- air filter for cossie management escort rs turbo
- MK6 Escort Front bumper
- EECIV Front Crank Pulley....
- 3 door shell
- series 2 shell wanted
- Roose silicone hoses
- s1 head rests!
- 2wd saff cos wanted!!
- T34 to cope with als
- RS 500 Fog Light grills
- silicone hose required
- Cosworth plenum spacer wanted
- Large cone filter for 3 door/RS500 wanted
- escort rs turbo manifold
- Coil pack set up.
- People who drive Fords>>> Look here. CD Player
- 2wd clutch
- FRST Block Needed
- 4x4 front driveshafts
- RS STEERING WHEEL
- 4x4manifold, fuel pump, pulleys , parts to exchange too
- s1 loom
- Standard 2wd heatshield
- 2wd Cosworth Clutch fork and release bearing
- ESCORT XR3I ALL BLUE CAB
- Spares or Repairs etc Fiesta XR2i or 1.6 Fiesta Si Wanted
- zetec turbo engine wanted
- cosworth rear brake caliper
- s1 rst gearbox must be in good con
- mondeo wheels 2 swap with my diamond cut rs2k's
- pistons
- wanted mint rs turbo s2 white or black
- Cos Fans, fuel pump, fuel swirl pot, WI tank, oil catch tank
- fiesta 2.1 zetek
- T25 Escort "distributor"/phase connector
- RS Turbo and Cossie parts WANTED!
- Carbon fibre heat sheild,splitter,hockey sticks.....
- FRST RED SILICONE BOOST PIPES AND BAILEY OIL BREATHER
- cossie parts
- Cheap S2 recaro's
- ********wanted 3 door cozzie *********
- ERST front rs splitter
- 3DR Roll Cage
- passenger side smoked rear cluster fot mk1-2 orion
- RS 500 FOG LIGHT GRILLS WANTED.
- fiesta rs turbo recaro seats wanted
- Recaro front seat/s
- Mondeo wheels
- ERS Turbo black bonnet
- cossie induction kit
- amal valve wanted
- after rs turbo bonet and bumper
- electronic boost controler
- Sapphire Cosworth Single A Pillar Pod
- cossie cloth front seats
- erst 1 or 2
- escort Si 98, s/steel exhaust, induction kit, etc
- ALS valve
- 2wd Oil Pick Up pipe required for Cossie
- 2.0 dohc sierra saphhire
- Ignition housing wanted for sapph cossie
- Cosworth 2wd rear caliper wanted.OOPS NEED PASSENGER
- RS2000 MK5 SEATS
- gt30 turbo wanted cash waiting
- rs2000 alloys
- 2wd cylinder head
- escort cosworth turbo replica wanted
- ecu and wiring harnes
- white 90 spec front bumper
- Series 2 - Rear Suspension Arms
- CTS rs turbo gearbox
- cossie turbo to cooler pipe
- mk3 s1 parts wanted
- s2 rs turbo ss back box. mongoose or scorpion.
- ecu escort rs turbo
- P8 or S8 ecu
- 2 poster ramp - Wanted
- LSD Gearbox
- Cosworth 3 spoke leather steering wheel
- stereo leads,
- bailey oil breather
- Series 1 gearbox wanted
- Escort cosworth NEW sidelights
- Crank and Rods
- rst boost pipes escort or fez
- stage 3 t3 turbo or cossie t34 wanted
- Escos mud flaps
- mk6 rs2000 front seats
- XR2I CAR LOOM
- Knackered gearbox (with lsd)
- Hybrid t2
- FIA approved bucket seat + harness. CHEAP!
- cosworth cams-standard
- Saph cossie rear bumper towing eye cover
- SIERRA COSWORTH 4X4 DOOR CARDS
- Airbox
- Escort Cosworth
- Red Samco Hoses & Garrett T34 Turbo for 2WD Sapphire
- S2 Ecu Chipped
- wanted...interior door handles for door cards on 3dr cos
- fiesta bits
- anyone got a flamer kit
- Mk2 sedan sierra tail lights
- Escort cos whale tale
- cosworth plug lead !
- Cylinder Head
- Escort Cosworth gearbox
- 90 spec front bumper wanted in black, pm us with details
- Wanted - Cheap Mk.5 Escort (must be 3 door)
- wanted 3dr cos/rs 2000
- s1 arches and skirts wanted.
- Cosworth T5 5th gear.
- rs1600i spares
- Laguna splitter
- actuator rod
- Sapphire Cosworth Door Mouldings
- Saph Cos front bumper
- Aubergine ES COS
- efi inlet manifold, xr3i or similar
- ATTENTION ALL !!!!!!!!!!!!!!!!!!!!!!!!!!!
- ATTENTION ALL!!!!!!!!!!!!!!!!!!!!!!!!!!
- fuel metering unit,water pump
- T34 Turbo Wanted
- 1.8 ztec sump and oil pick up
- Wanted: Shagged/Fcuked S2 Gearbox WITH LSD
- SAFF 4X4 WANTED. LOW MILES AND IN GOOD CONDITION
- Wanted - Boost gauge
- mk 4 escort RS 1900 bumpers
- fiesta rs turbo breaking
- Some bits and bobs needed
- S2 DASH FUEL COMPUTER
- rs turbo mk4 quad lights or morette any couler
- s1 swap with my magenta saph cos
- Escos LHD steering rack
- Escos cntr consul
- mk3 fiesta loom *urgent*
- PERFORMANCE CLUTCH WANTED FOR A S2 RST
- S2 turbo fooked
- escort cosworth shell
- Haynes sierra 4x4 manual
- Fiesta Centre Console
- 7 seater swap for a saxo VTR???
- Fiesta Mk 3 Mechanical ABS Parts wanted
- 16" TSW Evo-R's
- Everything needed to remove ABs on my S2!
- Saff wanted 2wd/4wd (px my rst series 2)
- mk3 escort outer sills
- s2 standred intercooler and front bumper
- 19" OZ SUPERLEGARRA'S FOR ESCOS
