PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Turbo Needed
  2. Ford Focus RS
  3. Anybody have a crap old 90spec recaro seat???
  4. diamond cut series 2s, decent shocks, show cage and backbox!
  5. st 170 hubs!!
  6. front cover plate 205 2wd cosworth block
  7. XR2I/RS TURBO bodykit
  8. escort rs turbo opening rear quarter glass green
  9. standard crank wanted cozzy
  10. 2wd cosworth dash
  11. rs turbo door cards
  12. Escort Gti
  13. Mondeo heater controls
  14. ST 200 Alloy Wheels or any multi spoke style
  15. bare 4x4 cosworth head
  16. LEATHER 3 DOOR STEERING WHEEL-MINTER
  17. S2 Engine
  18. cossy fuel pump
  19. SERIES 1 RS TURBO WANTED
  20. water temp gauge
  21. series one RST
  22. Various cosworth parts
  23. XR2 turbo
  24. 4x4 escos flywheel
  25. mk3 escort 3door
  26. base model mk3 escort dash
  27. 3 door head lamp
  28. gauges
  29. Radiator for Mk 4 ERST
  30. Escort Cosworth Bonnet with vents..
  31. Genuine escos front and rear bumpers
  32. escos tailgate
  33. Mint 3 door engine bulkhead soundproof pad.
  34. ______Wanted Rs Focus Wheels______
  35. Greens and chip
  36. *****standard focus rs exhaust manifold wanted*****
  37. sierra centre console
  38. wheels
  39. a solid series one
  40. 3'' outrolled backbox....
  41. s1 rs turbo drivers door glass
  42. Wanted - Alloys and s2 bits
  43. RS 1600i FRONT SPOILER WANTED PLEASE!! :)
  44. Focus RS front discs, old, worn, cracked...
  45. cosworth cam covers wanted
  46. s2 turbo gearbox craddle *** needed asap ***
  47. Radiator Wanted
  48. SAPPHIRE COSSIE 4X4 BOOT SEAL+PASS.REAR DOOR OUTER MOULDING
  49. Escort cosworth pillar pod
  50. XR2 CVH Engine wanted
  51. air injector bracket for a 2wd saph cosie
  52. Mondeo ST24 exhaust
  53. i want a fast ford
  54. Urgent(ish) - Mk4 Escort Driver's Side Mirror
  55. K Reg Fiesta RS Turbo in Moondust Silver
  56. 3 bar map sensor, and large foam air filter wanted
  57. Escort Mk3 RS1600i Computer required
  58. Sierra cosworth T3 turbo
  59. **S2 Escort Gearbox NEEDED ASAP**
  60. chipped e c u
  61. Sapphire cosworth 4x4 reverse switch
  62. escort rs turbo fuel pump and an single escort cossy wheel
  63. WANTED BLACK SAPPHIRE RS COSWORTH 90-92
  64. std 3 spoke steering wheel ( cossie)
  65. XR2i 1.8 Radiator
  66. can you help???
  67. MK3 Escort Ignition lock & key wanted
  68. 3Dr side exit exhaust wanted
  69. T3 Turbo wanted to fit ERST
  70. sierra sapphire 4x4 cosworth fuel tank
  71. S2 Safety devices cage wanted..
  72. escort cosworth tail gate
  73. s1 turbo standard radio
  74. std map sensor wanted
  75. sierra cosworth
  76. WANTED: Mk2 RS 2000 or Mexico
  77. needed
  78. Escort Cossy
  79. Mondeo 2.0 silvertop engine with lowish mileage
  80. 2wd sierra wiring loom
  81. CHEAP S2 ESCORT RS TURBO OR POSSIBLY FIESTA
  82. cosworth breather needed
  83. Leather Center console 2wd / 4x4
  84. RST parts....
  85. cards.
  86. 2i/FRST Passenger Side wheel arch (plastic one) or full kit
  87. UT T38 Turbo
  88. High-capacity alternator for sapphire
  89. cheap 4x4 gearbox
  90. std l8 weber babyboard
  91. Flint grey Sapphire drivers front door needed
  92. mint 3door roof lineing
  93. zetec conversion loom and non pats ecu
  94. Pectel engine Monitor
  95. Cosoworth 3 Door Sierra Shell
  96. ___________________COS Private Plate Wanted_________________
  97. SAPH REAR jACKING POINT COVERS
  98. EFI FRST engine
  99. efi flywheel wanted
  100. Compomotive MO 5 spokes.
  101. t4 turbo drop bracket, chrome engine bits wanted
  102. ERST stage1, stage 2 t3 turbo
  103. Mondeo ST
  104. Dare V4 Alloy needed - not made anymore
  105. Pasenger 2wd 4 pot caliper
  106. wanted 205 or a 200 block CASH WAITING
  107. 3 door wanted
  108. Escort S2 T3 Metal Water Pipes
  109. please help rl7 wheels wanted
  110. rl7 wheels
  111. 3door doors open computer thingy
  112. LHD Part
  113. ZETEC TURBO WANTED
  114. 3 bar map sensor and fiesta turbo throttle position switch
  115. door cards
  116. wanted rs1600i wiring loom
  117. fiesta rs turbo gearbox wanted
  118. frst/xr2i ns/r arch cover
  119. erst turbo parts......standard or aftermarket
  120. s2 loom
  121. * ESC COS & MOMO ARROW'S CENTRE CAPS.
  122. Cosworth Engine Cam Belt Cover
  123. ofab ecu wanted
  124. frst green bumper inserts
  125. Bailey Mirror Image breather tank
  126. Mk 6 Escort front Bumper?
  127. T3 Hybrid or T35 Hybrid Turbo
  128. brakes
  129. saff front bumper wanted
  130. STARTER MOTOR
  131. old style comps,or rondells
  132. standard turbo
  133. AP 330 FULL BRAKE KIT ,FOR ESCORT COS FRONT
  134. Urgent help!!!!!! Cosworth tdc sensor needed
  135. smashed or rotten 1.3 with HCS engine please
  136. 1.3 HCS engine please
  137. * GTI OR MK6 RS2000 REAR BUMPER.
  138. New Rondells
  139. I don't know what it's called, but I need one......
  140. mk3 fiesta xr2i/frst sidskirts and arches
  141. S2 bumper inserts/mouldins
  142. Working RS turbo alternator
  143. MK3 mondeo rims
  144. cossied capri or escort mk1/2 wanted
  145. Fiesta rs exhaust or backbox
  146. FRST Inlet Manifold
  147. 3dr sierra rooflinning
  148. s2 red rs turbo
  149. VAN WANTED
  150. half show cage, erst steering wheel, dials and...clock/light
  151. ESCORT MK2 RS200 sump DAMAGED ONES CONSIDERED
  152. Im after a series 2 car cover.
  153. ERST S2 ECU
  154. Wanted: Pectel T6 or T6 2000
  155. rs2000 engine
  156. Series 2 RST 90 Spec Front Bumper
  157. Cheapest run about going
  158. Rear Bilstein top section
  159. SECS ECU monitor
  160. Escos-small front under tray
  161. half shafts or complete axles for mk 1 or 2 escort
  162. rs 17" 7 spoke (softspoke)
  163. 306 S16 rear beam
  164. ERST cross over pipe
  165. 4X4 FRONT CALLIPERS AND DISCS
  166. 2x Compomotive MO 5 Spoke 17x8
  167. 2wd cossy rad wanted
  168. Cosworth Turbohanger f/2wd
  169. Engine parts needed
  170. need xr3i cabby brake parts!!!!!!!
  171. a good rs turbo lsd gearbox
  172. escort mk4
  173. escos sideskirts
  174. 215/40/17 Goodyear eagle F1 tyre wanted
  175. Fiesta RS Turbo Flywheel
  176. CHEAP (as poss) 1.6 CVH
  177. s2 rs dash and 90 spec headlining
  178. In need of rear axal
  179. Recaro cloth (Escort Cosworth)
  180. Cossie T3 or T34 0.48 exh housing, or complete 4wd t3.
  181. MINT 4x4 Saph / Escort Cos
  182. Need Manual Window Regulators for a XR4Ti
  183. -31 actuator
  184. Sierra Cosworth 4x4 engine mounts
  185. Alloy actuator
  186. rs turbo mongoose exhaust wanted
  187. s1 servo pipe
  188. t2 manifold
  189. ADJUSTABLE TCA's 2wd Cosworth / any upgraded suspension item
  190. BIG BRAKES WANTED! 2wd Cosworth 3dr/RS500 etc..
  191. Cosworth Solid rear beam Group A etc...
  192. cosworth exhaust system
  193. rs turbo engine wanted
  194. wanted mk4 3 door escort sleeper
  195. RS TURBO PART URGENTLY NEEDED.
  196. 4x4 Mongoose backbox wanted- 4" tailpipe outwardly roll
  197. Brake Callipers
  198. Series 1 Escort RS Turbo project found ..
  199. E cossie front grill
  200. Uprated engine mounts for 4x4 saph
  201. SPEEDO METER CABLE for LHD
  202. Wanted Spec R Turbo Heat Shield
  203. Mint Rear Cosworth Sapph Bumper
  204. I need a set of small turbo Escort Cossie....
  205. 4x4 bonnet
  206. I fancy something old skool.......
  207. wanted mint 3 dr cosworth
  208. half shafts or axles
  209. ofab ecu wanted
  210. RS SERIES 2 ALLOYS, INTERIOR, SHOW CAGE........wanted!!
  211. silver disclok
  212. t3 needed
  213. Sapphire 4X4 Cosworth Alternator required
  214. Mint 3 door/esc cos wanted to px My Focus RS
  215. Sierra Sapphire Cosworth 2wd or 4wd
  216. a few rs turbo bits
  217. three door cosworth door cards
  218. Series 1/2/fiesta rs1800 wanted
  219. rs rear bumper
  220. Decompression Plate for Zetec Turbo
  221. erst s2 rad!!
  222. 3dr front bumper
  223. COSSIE WANTED
  224. RS2000 MkV
  225. GT 25 compressor housing
  226. RST Exhaust, Rad Fan and top Turbo Coolant Pipe
  227. Wanted - white 4x4 Sapphire sub 80k miles
  228. Cossie head
  229. Fiesta charge carrier
  230. standard t3 turbo for 2wd saf cosworth,
  231. Steering wheel boss
  232. radio connectors for ford amp and cd player
  233. mk5 rs2000 alloys
  234. Wanted 2.0ltr zvh pistons!
  235. MK2 fiesta XR2/Ghia front bumper wanted
  236. COSSIE WANTED PX FOR SUBARU IMPREZA TURBO
  237. st 170 front brake set up needed
  238. Focus Rs Grill - inbetween the lights...
  239. 2wd cossie gearknob needed
  240. cosworth air con pump
  241. wanted
  242. rs turbo part wanted urgently.
  243. cosworth 35pin crank wheel
  244. cosworth stereo working thae one that fits with amp
  245. WANTED Escos shell
  246. 3 door parts required 2wd
  247. RS500 intercooler
  248. wanted door moulding strip's for a 4x4 saph cossie
  249. escort rs tubo series 1 parcel shelf
  250. Mk2 RS2000 interior
