PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 4x4 exhaust wanted must be 3"
  2. 4x4 bits
  3. focus rs body panels wanted
  4. Pace or similar intercooler for s1 wanted
  5. Centre console screw covers! PLEASE!
  6. RS cars WANTED £££££££££££ WAITING
  7. mahle 0.5 pistons new
  8. 2wd parts
  9. 3dr wanted, swap for a 2001 e39 m5 facelift
  10. Wanted, mk4 petrol cap
  11. Mint Cosworth Air Filter Wanted???
  12. Steering column outer tube thing for a s2 rst
  13. escos rolling shell
  14. 2wd Engine and bits
  15. WANTED: MK3/4 Escort Estate 5dr rear quarter panels
  16. 17" diamond cut rims
  17. 5 door saph boot open cable set up
  18. 2wd cosworth ht leads (wanted) cash waiting
  19. 2wd cosworth ht leads (wanted) cash waiting
  20. saph centre vent 2 gauge holder
  21. S1 bodykit
  22. wanted standard fiesta zetec s allys and brakes
  23. Series 1 sunroof
  24. 17" comps
  25. cosworth 4x4 sump and cross shaft etc
  26. cosworth 4x4 front hub carriers and hub flanges
  27. rs turbo engine 'T' peice thing...
  28. Help i need a woodruf key ASAP
  29. t3 housing
  30. Few cossie things
  31. sapphire cosworth headlight wiper drivers side
  32. focus rs grill
  33. Wanted** FIESTA RS TURBO CHARGE CARRIER **
  34. Series 1 sunroof
  35. two small parts needed guys.help
  36. S2 master cylinder must be new or mint!!!!
  37. 2wd plug leads[red would be nice]
  38. 044 fuel pump
  39. Gauges, rev, oil pressure, oil temp
  40. Saff Cosworth front bumper bracket
  41. clear rear lights for mk4 escort convertible
  42. tps
  43. decent suspension for my mk2 fiesta
  44. thanks guys.got one:)
  45. 4 spoke rs wheel and saff s/wheel centre
  46. Sierra Cosworth PAS Cooling Coil
  47. Ford Racing Boost Gauge
  48. 60mm boost gauge
  49. s2 front heated screen, green tint
  50. polly carbon windows/must be sliders
  51. Anyone got buckets seats and harnesses for sale
  52. focus rs grill
  53. Cheap as possible 2.0 Zetec Bottom End
  54. comp mo's or escos alloys
  55. escort cosworth wheels
  56. WANTED: Brakes!!!!
  57. escort cos/3dr mk 5 door seals
  58. Fiesta or Escort Turbo engine
  59. Sapphire Sideskirt Reinforcement Strips (ANYONE?)
  60. stupid small s1 parts needed
  61. Abs Pump
  62. Bucket seats and harnesses
  63. WANTED: center cap for MK6 RS2000 alloy wheel
  64. Escort cosworth shafts hubs flanges prop etc
  65. ST170 Brake Upgrade
  66. Ford Focus RS Aftermarket Manifold
  67. rs turbo kent cvh35 cam
  68. softspokes
  69. sapphire headlining
  70. Saph front mudflaps
  71. escort rs turbo t3 WANTED
  72. cosworth ecu cover
  73. delete found one
  74. cosworth 044 pump wanted
  75. Granada cosworth wanted
  76. Mk4 Escort Suspension parts....
  77. vauxhall nova 2 door saloon
  78. 2 wd intercooler needed
  79. Compomotive Silver Centre Caps
  80. turbo housing
  81. 2 bolts to fix timing belt cover to rocker cover on cosworth
  82. Cosworht parts needed
  83. cosworth 2 wd t34 actuator mounting bracket.
  84. S1 Fuel pump bracket
  85. stainless servo cover??
  86. 2 bolts wanted please
  87. found thank you again
  88. need a 2wd saffy bottom end !(found one thanks !!)
  89. S2 Petrol cap.
  90. momo boss with horn push
  91. erst 2 mounts
  92. frs manifold
  93. Wanted focus st2
  94. Need 2wd cosworth crankshaft pulley & auxillary plate
  95. MK4 Escort Cab Clear Rears! WANTED!!
  96. wheels for FRST and spoiler
  97. Cosworth crank front casing WANTED
  98. 6 deg rear beam
  99. s2 rs turbo lowering springs
  100. 2wd intercooler wanted
  101. 3dr bonnet with gen vent and good body shop!
  102. Focus Rs
  103. t3 turbo found one
  104. focus rs manifold
  105. wanted good spec saph or 3 door
  106. .
  107. group a t34 with maram shaft
  108. Escort Mk4 Shock Boots
  109. #
  110. Parcel shelf for S2
  111. Wanted: VW Golf GT TDi 130/150
  112. wanted a 2.1 zetec turbo engine
  113. pug 205 head.....
  114. Escos Steering Wheel
  115. 4x4 cossie front disks
  116. 2wd cosworth Oil cooler kit , take off ,pipes etc..
  117. ford escort rs turbo series 1 rs1600i bumper overiders!
  118. 4x4 Sapph petrol tank wanted
  119. Escort combi van
  120. escort mk4 wind deflectors s2 rs turbo
  121. fiesta RST parts needed
  122. rs2k mk5 engine loom
  123. rear chassis legs...
  124. Transit connect bits
  125. steering wheel boss
  126. air injectors
  127. s2 rs turbo
  128. saff bits needed..
  129. Saff front splitter & 4x4 Cam belt cover
  130. z16xe vauxhall engine needed
  131. mk4 escort efi throttle pedel and cable
  132. Zetec supercharger
  133. wanted! 3door sierra bootlid,genuine front wings and rear bumper for 3 door cosworth
  134. Pectel T6
  135. Sorted
  136. fiesta rs turbo gearbox
  137. cosworth turbo oil return pipe..?
  138. zetec turbo manifold...
  139. Oil Pressure gauge
  140. Ap 4 or 6 pots
  141. wanted s2 rs turbo scorpion back box
  142. Morrete twin headlights - Diamond Optics
  143. Wanted ST200 Estate
  144. Cheap 3 door mk6 escort
  145. Power steering Pipe
  146. Dash ECU cover
  147. Mk 4 door handles for elec windows,also genny fuel cap
  148. Escos cambelt cover (BT)
  149. cosworth manifold studs x16[new]
  150. brake line clips wanted for cossie:protect
  151. saph car cover wanted
  152. ap or helix 4 paddle
  153. Wanted Gear Box for a S2 RST ''Near Nottingham''
  154. Bilstein spring top caps required ,Witches hats !
  155. Mint Sapphire Scuttle Panel (Found one!!!)
  156. 3 Door Parts
  157. 4x4 cam belt cover and bolts
  158. fiesta 5 door runabout
  159. cylinder head
  160. Frst complete engine or bottom end.
  161. ford fiesta mk3/mk5 cash waiting
  162. RS1600i lower fogs
  163. Offside rear ABS sensor / wire needed
  164. 2wd turbo heatshield
  165. ET35 Wheel
  166. cylinder head
  167. power steering pipe [sapp 2wd]
  168. escort cos carpet
  169. e rs turbo roof sunroof
  170. bucket seat
  171. RS Turbo coilovers
  172. t3 with manifold
  173. ERST bonnet , bumper , slam panel and radiator
  174. Mk1 focus rear tailgate spoiler
  175. Evo 8 MR Fq340 Gun metal grey WANTED
  176. Cosworth Dizzy Cap Clip
  177. WANTED:cossie heated screen timer relay(with pic)
  178. Cosworth turbo water pipes
  179. 2wd Complete Rear Beam
  180. urgently required flametrap kidnex box before ford fair
  181. air injectors
  182. hose t piece/ longer samco/ dump valve
  183. Sierra Power Steering Pipe
  184. Sierra Sapphire cosworth foglight surrounds
  185. 18"escort wheels
  186. sierra underlay/sound deadening
  187. cossie alternater
  188. focus st170 wanted
  189. koni adjuster knob/key
  190. morretts for a saff needed
  191. 3dr seat brackets
  192. 2WD Throttle Position Sensor
  193. headlight wiper clips from arm to wiper
  194. Rear quater for escort cabriolet
  195. Damaged 4x4 cos bonnet
  196. s2 bonnet latch
  197. mondeo e.c.u
  198. Good quality boost gauge
  199. steel bottom end cvh
  200. Escort Turbo Scorpion 4" rolled out exhaust
  201. S2 90 Spec front Recaros
  202. 3 Door Sunroof
  203. Fuel Gauge Sender Unit
  204. focus st 2, 3" catback exhaust wanted
  205. magenta 4x4 cosworth bonnet
  206. saph hazard warning switch
  207. few 2wd cosworth bits wanted
  208. Sapphire Cosworth Darkish Grey Floor Carpet
  209. Sapphire Interior Fixing Screws/Bolts/Nuts
  210. Sorted
  211. whats my s2 worth
  212. standard intercoolers!
  213. 4x4 cosworth boot badges
  214. pro comp 5" monster tacho+boost gauge
  215. Escort RS Radiator
  216. S2 rear lowering springs
  217. 2wd saph cos fuel pressure regulator
  218. wing mirror covers........
  219. defi gauges
  220. Dead engine parts wanted please
  221. MK1 Focus RS
  222. saphire cosworth wanted
  223. MK4 Cabriolet rear quater panels
  224. ST170 injectors and fuel rail
  225. k-series parts wanted
  226. s1 turbo arches and kit
  227. mk5 facelift escort clock with alarm led
  228. Rear laden valve - mk3 fiesta
  229. Wanted mk1 3 door focus os qtr panel
  230. 2wd header tank
  231. Wanted (Before Ford Fair) - 24v BOA Cossie Engine
  232. Mk4 xr3i EFI complete Loom OR complete car!!
  233. Wanted full leather interior
  234. ford racing gauges
  235. escort rs outer door handles and connecting rods
  236. 1 x Cosworth Dark Green Injector
  237. wanted rs front skirt/bib for orion/escort
  238. 9"x18" ET15 or less, X 2 any condition
  239. wanted escort rs turbo mk4 shell
  240. car transporter trailer
  241. type 9 5 speed box?
  242. Wanted mint 4x4 Saph
  243. Alloy RS 500 Intercooler wanted , 3" outlets .
  244. rst gearbox
  245. WANTED:Heated screen relay from passeneger footwell 2WD
  246. .48 turbo exhaust housing for 4WD
  247. Recaros
  248. anyone got a old scrap dash loom plug for saff cossie?
  249. Cheap Cosworth Oil Breather
  250. Airbox and rubber seal
