View Full Version : Cars & Parts Wanted.
- body damaged 2wd cossie wanted
- single Revolution 7x13, or pair of 8x13 inch Revos/Revoloite
- sapphire cosworth rubbing strips
- fiesta swap with rs turbo?me pay ££ also...
- pectel monitor
- s1 or s2 drivers seat
- GREDDY PROFEC B SPEC II
- Escort Cosworth front splitter + spoiler wanted
- Black S2 RST Tailgate...
- S2 RST Koni's...
- Mk4 Escort Van
- cambeltcover carbon...
- sierra fuel computer
- rs 7 spokes
- escort rs turbo radiator
- fiesta 1.1 15k minter swap to a rs turbo and£££...
- 2WD Diff....
- Fiesta RST/XR2i Flywheel.....or any EFi CVH Flywheel
- fiesta rs turbo bailey breather wanted- fully working
- complete powersteeringsystem XR2i
- wanted trader for ffd gearbox
- 5th injector
- ST 24 Mondeo with less than 80k
- FRST CHIP NEEDED
- 2WD COSWORTH TURBO DAMPER AND SPRING (Pics Added)
- Passenger Rear Quarter for Escort RS
- SMALL TURBO ECOSS ROCKER COVER
- rs 7 17 inch diamond cut alloys
- 2wd Alternator Bracket
- 4wd cos Thermostat housing & Water pump
- 4x4 wiring loom
- rear spoiler 3,door
- ST24 Drivers side fog light surround. White if poss.
- 4x4 xhaust manifold wanted
- Mondeo Mark 2 (1997) Front O/S Wing in pepper red
- escort cosworth?
- Help !
- s1 bumper overriders
- wolf rear spoiler for escort cosworth
- 3 door cossie bits
- S2 sunroof and nuts and bolts etc ...........
- Wanted XR2 Rear Seatbelts
- New Cosworth bushes, Diff mount, and pressure regulator
- 3door cossie wheels
- 4x4 coss front caliper carriers
- steel crank for 1600 cvh
- ACT GAUGE WITH CONTROLLER
- escort xr3i (efi) loom needed
- cheap TD in scotland
- escort rs turbo wheels
- escort mk6 headlight(s)
- 4wd cosworth Head wanted
- 1.6 steal RS turbo bottom end
- series 1 non custom headlining
- New Chip needed
- RS500 Carbon Fibre Lower Rear Spoiler
- Cosworth head complete including cam cover
- 1.3 HCS Head
- Bluefin chip
- E36 BMW DIFFERENTIAL
- rs turbo series 2 doors?
- rs turbo escort series 2 turbo unit
- face lift gear lever / window switch surround
- XR2i nearside brake calliper (or pair)
- 3DR COSWORTH FRONT SPRINGS
- OZ Superleggera's 19" (Focus RS fitment)
- 2wd cossie for px with my s1 turbo
- all rs turbo fiesta running gear wanted
- Cheap 2 wheel drive Sapphire cossie wanted
- zetec s rear bumper
- Mk5 (93) xr3i 1.8Cabriolet Fuse box with or with out relays
- 200 block
- Fiesta XR2 MKII Parts
- RST engine needed!!
- Pectel board
- cosworth rocker cover with breather adaptor
- breaking sapphire
- SIERRA 4x4 Estate PLEASE
- Escos shell wanted
- WANTED Es Cos parts.................
- ERST Seat Subframe
- Peugeot 205 1.9/Mi16
- 4X4 SAPH COSSIE LOWERING SPRINGS???
- GGR COSWORTH DUMP VALVE
- Sapphire Cosworth Parts
- KEI Racing force 10's
- Focus RS GGR Gen 2 airbox/induction system
- Escort Coss - Got one now thanks.
- WANTED Mk2 RS2000, MEXICO. PLEASE REMOVE THIS POST
- 2wd shocks
- wanted four wheel nuts for orig 2wd saph cosworth wheels
- need full set of saph cosworth jack point covers
- rs 17/16 diamond cut alloys
- 7.5" 3.9 ratio CWP
- wanted R6
- S1 RST REQUIRED
- new s2 headlights and new orange indicators
- s2 samco boost and water hoses
- s2 mint 90 spec carpet + doorcards
- new ap organic clutch ! for s2 turbo +new lightened flywheel
- White fiesta rs/xr bodykit
- LOOKING FOR 4X4 COSSIE BLOWN OR NO RUNNING GEAR
- mondeo parts wanted.
- 2wd parts needed.
- 225 /40/ 18
- escort cosworth wrc
- mk3/4 escort cage
- s1 turbo servo pipe
- wanted frst engine
- Cosworth Cone filter
- ZVH water pump adapter plate
- wanted escort cosworth cloth hex seats door cards
- Kenwood car stereo
- outer drive shaft 2wd sapp
- ap paddle clutch kit wanted
- ap racing heavy duty cover, 4 paddle plate & bearing
- Axle for Escort mk.2......
- head gasket
- FIESTA mk 1 , 2 , or 3
- sleeper, or a mk4 1.3
- Cossie downpipe...
- RST T3....
- Sapphire Cosworth
- 5 spoke comp mo's wanted
- secs monitor and p8 managment
- not bothering now
- TWIN CARB CVH INLET
- Series one Bodykit
- 17" Rondell 122
- Coolant Hose
- escort mk4 bonus/popular 1.1/1.3
- focus tdci sport lowering springs 2004 plate.
- Mongoose 2wd Front pipe
- front lsd cosworth
- Escort Cosworth engine bay fuse/relay holder
- 17" 5 Spoke Compomotive Motorsport Alloys wanted.???
- Four 225/40.18 tyres
- Fiesta OFAC Superchip (165 chip, stage 1 chip)
- .....................got one...........
- Stage 2 or 3 CVH Head
- Rear whale tail spoiler
- Poorly T3 / Escort Turbo Unit
- Looking for a pair of tyre warmers for the car? Where from?
- Rear Diff Rubber Doughnut for Cosworth 2wd
- 4x4 inlet needed
- mk3 escort estate rear bumper
- Saph cossie
- fluorolined 16mm blue samco hose
- S2 metal plate that bolts to the under side of the bonnet
- fuel cell
- fiesta rst standard exhaust- genuine ford- kent area
- 7 x 13' revolutions for my MK2 escort
- Escos side lights
- 2wd Idle air control valve cossie L6
- frst front hub
- series 1 turbo parcel shelf speaker covers
- 3" Bore, 4"Rolled out mongoose back box
- Searching a dashboard cover
- bailey breather
- focus rs gearbox
- Granada 5 bolt hubs wanted - top money paid
- Standard 2wd Cosworth alloys
- Escort Cosworth oilpressure sender/switch
- blue cosworth rocker cover
- s2 rst mercury grey bonnet
- brembo brake kit for 2.0 zetec (focus)
- escort s2 uprated clutch for 220bhp
- s2 90 spec carpet and drivers door card wanted
- stainless part x
- escort rs turbos2 wanted cheap
- Escort Cosworth Wheels...
- sierra cosworth petrol tank (sorted now)
- Turbo Cooler for 2wd Cossie
- escort cosworth rear arb
- ANYONE FANCE A SWAP?
- BOOST GAUGE
- pectel ALS
- s2 rear door cards wanted
- 4X4 cosworth turbo unit
- cheap 2wd
- mk4 drivers side morrete headlight / cover
- Fiesta Mk2/3 XR2, XR2i or reasonable base model?
- power hood relay
- tyres
- n/a 1.6 cvh carb engine
- Good condition T2
- S2 boost hose
- T3 standard or hybid
- Electronic ignition for Mk2 RS2000
- S1 distributor wanted
- boost gauge
- eec 4 or 4x4 inlet and L8 ecu needed!!!!!
- WANTED MK2 RS2000, MEXICO, HARRIER. ( GOT ONE )
- WW's
- MOMO BOSS KIT FOR SAPPHIRE COS WANTED !
- mk4 escort front coilovers or uprated springs/shocks
- RS FOCUS ROCKER COVER
- RS1800 Wanted
- 90 spec 3i, or nice mk3 xr3/3i....
- Bottom crank pulley required urgent!!!!!!!!!!!!!!!!
- S2 ERST Engine Parts Required!
- WOLF REAR SPOILER WANTED FOR MY ESCORT COSWORTH
- Mazda 6 MPS breaking
- sierra 2wd front pad retaining kit
- Wheels for ESCOSS 18" or 19" with tyres must be go
- escort cossy rims
- hens teeth - 500 cossy block
- blown up cossie turbo
- wanted 3dr cozzy shell with id
- exhaust housing
- Downpipe
- Surge tank
- Cosworth group A K&N air filter
- S1 metering head
- Mis Magnesium Inlet Manifold Wanted
- 40mm series 2 springs wanted
- 3.9 Ratio 7'5 rear diff
- powerflex rear bushes for cosworth(SORTED NOW)
- fiesta RST oil return push connector + oil feed bolt
- Mk4 efi escort/orion engne loom
- Cosworth Idle Speed Control Valve
- st24 or 24v saff in swap for my s2
- mk2 xr2 clear drivers side indicator
- flint grey sapphire bonnet
- Escort MK6 RS2000 Interior or maybe GTI
- mega mint s2 turbo 90 spec drivers door card wanted
- for S2, mounts, gear linkage
- escort s2 rs turbo
- Pre Engaged Starter Motor For 1986 MKII XR2 1600 CVH
- Series 1 or 3dr rolling shell wanted
- ported 2wd
- s1 or s2 shell wanted
- s1 or s2 rst shell wanted
- s2 89 spec front bumper with over bumper or just over bumper
- series 1 black relay wanted asap
- STILL NEEDED.......XR3i door card MINT as possinble
- frst wheels
- cos number plate wanted must be g or older
- mk 4 escort brake light switch
- Got it !! Escort Cosworth - ABS impuls sender !!!CLOSE!!!
- mk6 engine
- WANTED - Focus RS interior
- Focus ST170 calipers and carriers ?
- T38 0r mibi .63 T34
- Best Price for new 2wd Engine Mounts ???
- escort RS turbo brake lines
- MK5 RS2000 HUB
- 15" ford rs seven spoke alloy,
- fuel/co2 adjusty thing on S2 metering head needed!
