PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. S2 RS Turbo bonnet wanted
  2. Car Trailer Hire Wanted in Scotland
  3. WANTED 4'' MONGOOSE SYSTEM FOR S2 rst
  4. Magnetti Marelli 3 bar map sensor
  5. 2wd saff turbo heat shield
  6. duff ABS sensors, ESCOS R.ARB, poly bushes
  7. WANTED: Capri (MK3) LHD Mirror
  8. 7 spoke rs wanted
  9. 4x4 Saff Bonnet
  10. 2wd l6 ecu
  11. frst bottom end or full engine why
  12. 2wd cosworth rear beam
  13. 16's or 17's wanted
  14. sierra cosworth rear spoiler
  15. 2WD cosworth thermostat housing
  16. S1 fuel pump relay
  17. s2 bottom boost hose
  18. FRST working bottom end wanted
  19. AZEV A alloys
  20. fiesta rs turbo shell wanted
  21. 2wd t3 turbo
  22. 3 point black seat harnesses
  23. 2wd Cosworth thermostat housing elbow wanted
  24. T34 0.63
  25. WTB!!!
  26. sierra cosworth t34
  27. Wanted Escort MK4 Spotlight plastic covers
  28. series 2 rst door cards
  29. 2wd motorsport leads and Grp A coil
  30. 4x4 shark tooth alloy
  31. blue compomotive centre caps
  32. set of clocks?
  33. Left Hand mirror for Capri MK3
  34. Esc Cos windscreen wiper arms
  35. XR2 i bits wanted (exhaust, alternator, engine mount, subframe)
  36. comp centre caps
  37. lock set
  38. Wanted Car Towing Dolly
  39. FRST OFAB Loom
  40. MINT rainbow cloth from facelift saph 4x4
  41. fiesta rs turbo shell wanted
  42. electric window motor for mk1 sierra
  43. Saph mudflaps
  44. escort rs trubo swirl pot + oil seperator
  45. 4x4 exhaust manifold wanted..
  46. Escort/Orion EFI loom/fusebox
  47. -34 Actuator and bracket wanted
  48. t3 turbo for escort
  49. exhaust
  50. s1 std airfilter setup and cambelt cover
  51. RS Turbo Pipercross??
  52. copper washers for water pipes on T3 turbo
  53. gt30 turbo
  54. Flat belt pulley for alternator
  55. 200 Block with Nakasil liners
  56. set of 17" Rondell 122's wanted for s1
  57. 3dr bonnet wanted
  58. seat subframe escort cosworth
  59. fiesta turbo tps
  60. 3 dr wanted..
  61. ERST Roll Cage
  62. Escort cosworth wheels
  63. Bailey PAS Tank
  64. CVH Turbo Conversion + Cosworth Alloys + MK6 Cab Parts
  65. Bbs Centre Lock Wheels,or Bits Of,anything??
  66. Big Wing Sump 4x4 Cosworth
  67. 2wd cos iscv wanted
  68. saph help PLEASE
  69. Steering wheel BOSS KIT for Sierra
  70. Trackday car wanted
  71. cossie dump valve needed
  72. 3 door front coil springs.
  73. 17's/18's for my 3 door ??? why
  74. series 1 parts needed
  75. Geniune 500 front bumper
  76. Ofac 195 Superchip+info On Track Preparation
  77. fresh cossie engine wanted
  78. Sapphire Door Window Rubbers
  79. sierra cosworth wheels
  80. 4x4 bonnet and front bumper
  81. Focus RS exhaust manifold
  82. Upratted Rear Beam Etc
  83. Mk4 escort rear quarter glass rubbers.
  84. Series 1 Rear Shock Dust Sleeve
  85. 4x4 konis or bilstine shocks
  86. Escort Cosworth Centre Console LHD
  87. 2040 CD player
  88. erst low comp pistons
  89. T34 Turbo
  90. L8 ECU with standard chip
  91. series one fuel pump relay
  92. Mondeo ST220/TDCi Alloys
  93. turbo return pipe
  94. Turbo
  95. failed ABS sensors, beam exhaust mounts,poly F ARB mounts
  96. standard escos wheels
  97. two battered old steel wheels
  98. Xr3i/RS1600i Warm Up Regulator
  99. Wanted; Rs2000 Mk5
  100. side exit
  101. standard 2wd saff rear lights
  102. MK4 escort underside heat shield WANTED
  103. Drivers side wing mirror for a 3 door
  104. Cosworth Clocks (Speedo)
  105. FRST Green Relay
  106. sapphire cosworth 2wd look a like
  107. 701 Beige Injectors+195 Superchip Ofac Ecu
  108. 4wd Fuel pressure regulator
  109. 4wd Fuel pressure regulator
  110. Pair of Rear Cosworth Dampers for Track car wanted
  111. Carbon hoods Focus and Body kits
  112. Rst Header Tank
  113. 130ps cams or 2.0l cams
  114. Looking fore cars
  115. Wheels
  116. looking for L8 ECU, Sierra Cos 4x4
  117. big wing sump
  118. Uprated Cosworth Parts WANTED LIST
  119. mk1 escort wings
  120. Escort Mk3/4 opening rear quarters
  121. Mongoose Exhaust
  122. Mongoose Exhaust
  123. mk4 escort inner wing o/s
  124. T3 Downpipe
  125. 3dr Icv & Group A K&n
  126. fiesta mk5 zetecs coilovers wanted
  127. 93 EsCos fuel filler trim ring & other misc.
  128. MK4 Escort RS Turbo POLYBUSH KIT
  129. wanted saph cossy body kit
  130. turbo hose
  131. White 3 door cosworth Wanted.........................
  132. Wanted 3dr Rear Seat&parcel Shelf
  133. fiesta rs turbo wanted
  134. Power steering pipe
  135. Any one Got a good working order metering head?
  136. passenger side rear light
  137. 3 bar map
  138. standard map??
  139. full uncut wiring loom s2 rst
  140. 3dr shell wanted in p/x with saph maybe
  141. wanted mint mk3 escort shell for track toy
  142. Turbo damper (rs500)
  143. 1.6 cvh dipstick and tube..
  144. rs turbo/cosworth feul pump
  145. Wanted 4x4 Cossie Coilovers
  146. ignition amplifier sierra 4x4
  147. Anyone got an Escort RS Turbo for sale?
  148. rev counter for a sapphire...
  149. greys injectors
  150. swirl pot
  151. 3 door bumper
  152. 4x4 rear caliper carriers, 2wd belhousing / exhaust manifold
  153. escort mk3/4 window mechanisms
  154. Wanted Cosworth yb engine 2wd or 4wd Birmingham area
  155. Small turbo escort cossie ECU
  156. S1 rear arch clips
  157. Drivers side fog light surround
  158. Need a scorpio td gearbox
  159. ford racing white boost gauge
  160. turbo inlet hose for a frst t3 conversion
  161. Escort Mk3/4 Non-sunroof Headlining.....
  162. WANTED. 1 17x7 OZ Superturismo wheel
  163. Chrome CVH Oil Filler Cap
  164. ahmed 3dr springs
  165. S1 Turbo Bumper Parts / Rear Spoiler
  166. Sierra 2.9 4x4 gearbox wanted,
  167. wanted half cage? for 3door
  168. 88 spec RST header tank
  169. Fiesta RS1800/XR2i/RST Bodykit jacking point covers
  170. escos rear brake splash gaurds
  171. 3oomm rear brakes cosworth
  172. Rs Turbo Wanted
  173. pug 306 s16 ecu
  174. 355mm AP 6 pots
  175. donar erst
  176. 3 door front grill
  177. Sapphire 4x4 Front O/S Hub Carrier
  178. escort rs turbo 0.5 oversize pistons
  179. Red 88 or 90 Spec boot spoiler
  180. S2 engine and g/box
  181. Ford 6 088 981 washer pump
  182. couple of bits
  183. brake alloy bells
  184. Escort Bumper and Spolier
  185. Red S2 rolling shell G or H reg
  186. 8x18 et 15 new comps
  187. escos rear arb
  188. escort Series 2 lsd gear box
  189. Sapphire Cosworth front bumper
  190. 10" spal type fan
  191. MK6 Escort/Cabby/RS2000/Cosworth parts
  192. cosworth head or valves
  193. fiesta turbo bottom end
  194. wanted escort cossie alloys
  195. cossie throttle body
  196. ST170 headlights - swap for quads
  197. Rs Turbo oil cooler
  198. Urgent- Need fiesta Si (mk3.5) Front Hubs
  199. Quick Shift+fuel Pump
  200. steering coupling 2wd cos
  201. escort series 2 fuel pump bracket
  202. mk2 Roll Top Drivers Side
  203. adj front shocks and springs for a mk6 escort
  204. 2WD Sump anyone selling one and going to ford fair i can pick up cheers!!!!
  205. ofac stage 2 chip
  206. wheel hubs
  207. escort cosworth koni shocks
  208. Esort RS Turbo S2 Wiring Loom (Complete)
  209. mondeo mk3 seats wanted
  210. s1 gearbox!!!!!!
  211. Uprated Diff Mount
  212. 1 x 7J MONDEO 5 SPOKE ALLOY 16" WHEEL
  213. Metal Boost Hose's
  214. WANTED Focus Rs Shell
  215. wanted series 1 front anti roll bar and setup n gearbox
  216. One wheel wanted..
  217. 355 x 32 rotors
  218. Cossie bottom pully with 36-1 toothed trigger wheel on?
  219. erst exhaust
  220. fuel tank sender
  221. rs turbo pistons
  222. Need Help!!!! (gti 1.8 Engine)
  223. rad cooling fan
  224. S1 electric window switch
  225. cossie idle air control valve
  226. WAnted FIESTA XR2 PEPPER POTS
  227. s2 rad and gearbox mounts
  228. fiesta turbo wheels
  229. Sierra Quads
  230. Escort mk6 skirts / spats / jacking covers
  231. S1 part needed urgently!!
  232. need good condition t2
  233. Torx bolt that holds TCA balljoint to hub carrier
  234. MK2 Escort
  235. Vernier Pulleys for Escort Cosworth
  236. OZ Super Leggeras
  237. S1 Body Kit
  238. Escort Rs S2 Part Needed
  239. sapphire 4x4 vent wanted
  240. fibreglass/kevlar escort cosworth bonnet
  241. escort cosworth tailgate hinges
  242. T34 or T38
  243. sorted
  244. Need Level 8 Ecu
  245. 3 door cosworth clock surround
  246. S2 Escort RS Turbo Big Front Brakes, 4 pots etc
  247. t3 with erst manifold and elbow
  248. Mk3 Fiesta Tailgate mint no rust etc
  249. need good condition t2
  250. AP 330mm/28 discs grooved
