View Full Version : Cars & Parts Wanted.
- 3dr fibreglass rear bumper
- Rear Saff Bumper in Mercury grey.
- Kenwood amps
- 4x4 sharktooths
- 4x4 head wanted
- mk. 5/6 escort zetec engine mount bracket
- Wanted Magnesuim Grp A front hub
- morettes escort
- Dashboard washers needed
- Rs turbo s2 Genuine scuttle panel
- MFI RS Turbo engine wanted
- Glove box lock wanted
- Cosworth 4x4 dipstick
- Silver top engine package
- Silver top Zetec 2.0 - bottom end or entire engine
- Cosworth crank sensor plug bracket
- Rs500 bumper grills wanted
- Fiesta st front bumper and side skirts
- Cosworth 200 block
- Cosworth breather set up for big power, spec r, ggr etc
- Orion ghia/escort mk4 van parts needed
- fiesta mk3 parts wanted
- Escort Cosworth headlights, RS 500 fog light grills
- Seat belts
- Sierra Sapphire Radiator Wanted
- 2x new Beru ignition leads WTD.
- Series 2 rs turbo drivers door
- Wanted Cosworth 2wd front shocks
- Modified Series 1 Rs Turbo
- cosworth Drivers Wing mirror
- Sierra cosworth original mongoose exhaust
- weather strip
- 4x4 front suspension uprights
- Looking for few Escos parts
- Wanted escort cosworth /rs2000/mk5 xr3i sidelights
- Anyone breaking a 3dr or have parts
- HELP....Panel clips
- 2.0 zetec bottom end engine wanted
- wanted injectors transity connect
- 3dr fog light grills and other stuff
- 4wd yb stock turbo oil drain and water pipes wanted
- wanted - saff cosworth exhaust
- WANTED RS steering wheel boss COSWORTH
- XR2 MK2 breakers or full car considered
- looking for an escort cosworth
- Small washer yb head bolts wanted
- Wanted: Supra Diff in 3.9 Ratio
- Cosworth yb 4wd exhaust manifold wanted
- r134a
- 3dr cosworth replica
- WANTED 3dr track or rally car
- Cosworth 4x4 shark tooth alloys
- Wanted MK1 Escort RS2000
- Sapphire Fuel Pipe Wanted
- WANTED SAPPHIRE indicator stalk
- Wanted sapphire rear parcel shelf.
- Sapphire Cosworth door cards wanted
- Mk3 fiesta bits needed
- Fuel Injectors 2.0 DOHC Wanted
- Cosworth Amal valve
- standard frst airbox
- Recaro round, black seat adj. wheel??
- Escort cosworth turbo heatshield
- YB Pectel P8 Board
- 3dr cosworth rear arches
- fiesta rs turbo brake calipers
- Ffrst or xr2i front bumper
- Escort cosworth big turbo loom
- Focus MK1 Gear Cable Bracket
- No longer needed please delete
- Cosworth 4x4 front brake caliper n/s
- Saff 4x4 T3
- Xr4x4 running gear
- Sapphire Drivers and Passenger Door Wanted
- Anyone breaking Mk5 or 6 escort
- Series 2 Escort Rs Turbo bonnet/ vents
- Escort cosworth grill
- All sorted
- Escort cosworth seat runners and seat belt clips
- Mk4 Escort/ Mk2 Orion n/s driveshaft wanted
- Wanted; Cosworth front bumper & hubs
- S2 rs turbo headlight covers wonted
- Alternator h/sheild for 2wd sapp cossie
- Sapp Cossie h/lamp wiper arm d/side required
- Rs500 t4 compressor housing
- WANTED 89 Sapphire locking petrol cap
- mk1 fiesta strut brace
- Wanted 5 pin intermittent wiper relay
- Wanted Sapphire cosworth Shell
- DOHC 8v piston/rod
- Escort cosworth heater knobs
- 4x108, 16"/17", et40ish, track wheels/tyres
- 4" backbox for Sierra
- Xr4i bits
- Focus 2.0 driveshaft intermediate bearing bracket
- T34 turbo
- Escort Mk4/6 sunroof.
- WANTED 2wd or 4wd cosworth rear axle complete
- WANTED - Escort Cosworth Alloys
- Mk3 fiesta rear window rubbers
- Fiesta rs turbo air temp plug/injector loom
- Green bumper mouldings(again)
- Wanted 3 door Cosworth seats
- *wanted* sierra cosworth standard diff mount
- Wanted Cosworth 4x4 or big escos turbo oil return pipe
- Cambelt cover
- Series 2 90spec rear spoiler wonted
- frst 3 spoke wheel centres
- mk1 fiesta xr2 parts
- Diesel Sierra Sapphire
- Escort cosworth A pillar twin gauge pod wanted
- t5 gearbox parts
- One Sharktooth ppease
- 3 spoke RS steering wheel
- Grp A cosworth cone filter
- 2wd Front Shocks / Coilovers wanted any condition
- Escort cosworth parts wanted
- Sharktooths
- Cossie fuel hose to fuel pressure reg clip
- 2wd Throttle Cable bracket(not cable)
- 17" Rondells
- Escort cosworth st dump valve
- Saph 2wd parts needed
- Cortina mk3/4/5 uprights
- Cosworth 4x4 bonnet
- 3door Brake servo/master cylinder unit ASAP
- Escort mk4 wings please
- Sapphire fnt bumper
- Ford 6006 radio
- Sapphire front wing
- 2wd turbo heatshield- Massive favour needed!
- Small Turbo cossie inlet
- Mk4 Mondeo sports body kit
- Bailey DV30 rer-circ valve (polished) in mint condition
- EFi XR2i or late XR3i Engine
- ERST window mechanism
- RS Turbo Pistons for EFI
- Saph cosworth 4x4 magnex
- Mrk 4 RS turbo head light
- Wanted: E36 Coupe
- ERST Twin Piston Dump Valve
- W: 4wd Cosworth thermostat housing
- ERST Series 2 Steering Wheel
- Mk1 RS focus
- Sierra cosworth vgc rocker cover wanted
- Rs turbo series front anti rollbar
- new yellow coolant tank cap (YB)
- sierra cosworth rear coilovers wanted!
- Mk5 escort rollcage
- Airbox for Sierra sapp cosworth
- Original 3 spoke steering wheel for 2wd sapp cossie
- Bailey or Pro Alloy swirl pot for Sierra Cosworth
- Sierra Cosworth engine lifting eyes
- Sierra Cosworth 2wd Fuel pressure regulator
- wanted power plug for ford 2040 cd player
- Rubber flexi from car to door for cables (3 door)
- XR2i/XR3i HO Inlet and other parts wanted.
- Lsd
- Fiesta mk3 quarter rear window rubbers
- Saff rear bumper
- 2 wd rear beams
- 3dr anti roll bar washers
- D Reg Series 2 Handbrake Light Switch
- ERST Series 2 Rear Seat Belt Covers and Front Speaker Covers
- Mk1 Orion seat base
- 4x4 Cam Belt Cover
- List of parts needed ***UPDATED***
- Cosworth L8 Super 8 Ecu
- Cosworth PCV/breather valve needed please! :)
- Cosworth Updated ap clutch cover
- Standard cosworth 4x4 flywheel
- ERST Series 2 D Reg Brake Fluid Cap
- Sharktooth wheel centres
- Fiesta RS Turbo bumper & side mouldings wanted!
- 4" outward rolled back box for Sierra
- MK4 Escort 1.3 thermostat housing
- MK4 rear seat
- Looking for another 3dr soon.
- MK2 Focus RS Recaro's/Sportsters
- Escort Cosworth
- Cosworth clutch peddle
- Sierra rear diff mount
- Big brake kit for 2wd Cosworth
- Wanted: .63 exh housing for T34
- Rs turbo green tint glass
- Sierra cosworth 2wd driveshaft stub,left hand thread
- t5 gearbox parts
- MK5 Escort 3dr Door Cards
- Escort RS Turbo Rear Seatbelts
- Wanting series1 escort rs turbo dash screws
- Ford Escort Mk4 CARELLO H4 Passenger side headlight
- Wanted Fiesta ST150 standard exhaust as new wanted
- Cosworth lattice alloys !
- S2 brake linkage parts
- Escort RS Turbo S2 Boot Struts
- 2.0 Sierra Sapphire Wanted
- 2wd SAPHIRE COSWORTH WANTED
- wanted a single 15x7 oz mag et 35
- WANTED!
- Ford Racing Gauges
- Odd S2 Bits
- Escort RS Turbo Standard Alloys
- mk5/6 escort Cosworth body kit
- Genuine Focus RS Mk1 Head
- MT75 RWD Hybrid Gearbox
- Wanted focus rs mk1 very clean mats and rs wallet
- Mk4 or Mk6 Escort Sunroof
- Sapphire Cosworth front bumper wanted
- 17" Comps Wanted
- 15x7 wheels. Any considered in 4x108
- mk5 escort RS sidelights
- escort Cosworth morettes
- Escort RST S2 radiator fan
- S2 tubalur manifold wonted
- s2 rs turbo stage 3 turbo wanted
- Sierra Sapphire Rear Coilovers
- braided brake hoses
- S2 rs front strut brace wonted
- Escort cosworth BT 4x4 fuel rail and regulator
- Ecos indicators
- Ford sierra cosworth lattice wheel center caps
- Series 1 kit
- Rs turbo rear strut brace
- sierra sapphire new genuine amber ford rear light
- *** Wanted - Front Recaro Seats for S2 RS Turbo ***
- Wanting series1 servo pipe
- 3dr Front Hubs Wanted
- Tial BOV
- *** Wanted - 1987 Escort RS Turbo Heater Blower Cover ***
- *** Wanted - Parcel Shelf for 1987 S2 Escort RS Turbo ***
- *** Wanted - Interior Seats for my 1887 Escort RS Turbo ***
- Cosworth breather pipes water hoses
- Rondell 122 Centre caps.
- Rs turbo s2 wonted mongoose exhaust
- Swedish plenum throttle cable bracket
- Compomotive/Rota/OZ Racing Wheels 17" for Saph Cossie
- Series One RS Turbo
- alloy pas tank
- Chrome strut tops
- sierra bits and more
- Sierra cosworth front bumper
- Complete mint 2wd sapphire cosworth 170 mph cluster
- decent 90 spec spoiler and bumper wanted
- Series 1 RS Turbo Standard alloys
- MK4 XR3i Doner car
- Mk4 bonnet sound deadining fixings
- Wanted cvh crank sensor bush
- escort cosworth 4x4 gearbox
- List of Cosworth parts needed... T38, Greys, AB07 cam
