PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 [77] 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. mk5 rs 2000 throttle body
  2. paddleclutch and standed/lightend flywheel to fit 4x4 saff
  3. S1 gen bonnet
  4. Wanted
  5. CD6000 ford single cd player with code.
  6. wanted raven sapphire cosworth dash.
  7. crank pulley
  8. Cosworth 4x4 Front Driveshafts.
  9. Spax Rear shock for FRST
  10. Alloy Collins or Forge Actuators Wanted!
  11. 2WD T3 Actuator bracket
  12. gauges?boost.oil,water etc
  13. black mk4 escort bonnet.
  14. Escort cosworth header tank URGENTLY
  15. a sensible car to PX with my not-so-sensible!
  16. T3 Turbo wanted ERST
  17. top end stuff
  18. MK4 XR3i rear window seals
  19. Mk2 Fiesta roll cage and bucket seats wanted
  20. rs500 wanted!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!
  21. sierra cosworth bonnet vents, arches/skirts, rs front bumper
  22. urgent turbo help needed please
  23. mongoose middle box
  24. RS Engine build with a difference PARTS NEEDED
  25. S2 RST 90 spec interior parts wanted.
  26. Fuel pump for series 1 turbo
  27. Ford Puma 1.4, 1.6 or Fiesta Zetec 1.6
  28. water pump
  29. Looking for mint series 2 turbo for p/x with my car
  30. Cosworth Alloy Rad
  31. Escort Mk1/2 Mexico or Rs2000
  32. sapphy 4x4 gearbox wanted!
  33. mk 4 escort van wanted
  34. s1 loom
  35. ***WANTED MINT MK1 XR2***
  36. 1.6 Zetec-s / 1.7 Puma Engines
  37. Series 2 Fuel Pump!
  38. cosworth 4x4 coilovers wanted
  39. Bottom end for a RST
  40. swirl pot and coolant samcos for 4x4 saph cossie
  41. mk 4/5 fiesta zetec s rear bumper.....
  42. urgently needed,PLEASE,PRETTY PLEASE
  43. RS2000 Rear calliper
  44. wanted scrap sierra with or without engine must be rolling
  45. some bits needed for mk4 escort
  46. Fuel presure regulator
  47. RS2000 GEAR SELECTOR FROM GEAR STICK TO GEARBOX
  48. RS2000 IDLE SPEED CONTROL VALVE WANTED
  49. SERIES 1 SHELL / CAR NEEDING WORK
  50. RS 7 Soft Spokes wanted, mint
  51. Fiesta / Escort RS Unfinished projects, salvage, rusty etc..
  52. focus RS exhuast manifold
  53. 3dr
  54. oz mag rim
  55. cosworth shell
  56. 3 Door rad fans wanted
  57. Stainless Cam belt Cover - Cosworth
  58. Sapphire Cosworth Leather rear bench & Fez RS1800 Doorca
  59. escort gti or si estate in good condition
  60. T2 OR T3 TURBO
  61. fiesta rs1800, escort xr3i (130 bhp), or orion si...
  62. Cheap van
  63. 3dr cossie wheels
  64. RS 500 intercooler........... and bailey oil breather.......
  65. centre cap
  66. Steering bush for escort series 2 turbo
  67. mk 2 orion rs rear splitter
  68. Escos side lights
  69. OFAB Loom
  70. .48 exhaust housing for t3 rs turbo
  71. wanted, 6paddle clutch plate
  72. Escort Cossie rims
  73. Escort Cosworth PARTS Wanted
  74. 3dr Cosworth Front bumper genuine/replica
  75. Escort Cossie ABS Sensors Wanted!
  76. saff cos 2 or 4 wheel drive wanted....
  77. ford transit parts
  78. front recaros
  79. sapphire passenger side front skirt
  80. center cap,monte alloys!!
  81. 3dr rear qtr window seal
  82. cossy crank
  83. 3 dr cosworth
  84. OFAB chip
  85. Fiesta RST
  86. rs2000 back box mk7 or full stainless
  87. rs2000 mk7 front seats
  88. Complete s2 RST Bottom End
  89. good condition 90 spec series 2 door cards
  90. .48 or .55 exhaust housing **mods remove got one now**
  91. VERY cheap/free, running bangers, Essex
  92. starter motor for cos wanted
  93. Chip for Sierra 4x4 L8 ECU
  94. 4X4 COS CALLIPER CARRIERS
  95. !mk4 escort drivers side front footwell metal speaker mount!
  96. Saph Cossie or RS Turbo
  97. 1 arp head stud needed
  98. fuel hose
  99. BD10 or BD 14 cosworth cams
  100. turbo
  101. xr2 turbo wanted
  102. zetec turbo manifold...takes turbo over gearbox
  103. Fiesta Turbo Main Crank Sproket
  104. 325i cabriolet for swap with 2wd cossie PICS INSIDE! LOOK!
  105. sorted now thanks for the reply`s
  106. Standard 2WD L6 Chip
  107. oil breather RST fitment
  108. anything over 2.0 for £300-350.
  109. fst 195 bhp chip wanted
  110. Rs Mudflaps.....
  111. Cossie Mongoose s/s downpipe
  112. Wanted RS Van
  113. J OR K REG FIESTA TURBO.
  114. Sierra 3 Door Cosworth D' Reg Hub
  115. wanted gray injectors
  116. COSSIE GROUP A FUEL PUMP
  117. KONI FRONT STRUTS FOR RS TURBO
  118. Wanted anyone selling a -COSSIE 2 BAR MAP SENSOR
  119. Cosworth 2 Bar Map Sensor *GOT ONE NOW CHEERS*
  120. XR2I Superchip
  121. E30 BMW 325i Sport
  122. SAFF 4X4 GEARBOX
  123. sapphire hubs
  124. Escort Cosworth Aircon compressor
  125. xr2i
  126. FRST Engine
  127. fuel pressure regulator
  128. left hand drive cosworth wanted.
  129. SERIES 2 MUDFLAPS & BOOST GAUGE
  130. grp a anti-roll bar blades
  131. S2 Gear Linkage
  132. Series 1 RS Turbo or MK3 Escort Drivers Seatbelt Wanted Plz
  133. 2wd saff cos
  134. saff cos wheels, 17 inch, in black or grey etc, WHY ?
  135. Fiesta RS turbo or Escort RS turbo
  136. recover tuck wanted
  137. xr4x4 or 2.9 estate for towing
  138. Wanted - Mint or new Escort Cosworth centre console
  139. 2wd saff stainless exhaust
  140. KA Sport SE
  141. ST170 Discs
  142. Frst rad and fuel pump
  143. cosworth fuel pressure regulator wanted
  144. 90 spec front bumper in red
  145. pistons
  146. SORTED *****
  147. Flywheel
  148. Standard size piston rings for Escort RST.
  149. s1 radiator and fan
  150. 4x4 Thermostat housing and water pump
  151. s1/mk3 bits,sunroof,grill
  152. 4x4 rear calipers
  153. escort s1 fuel filler neck pipe and sunroof plastic seal
  154. Wanted good 4x4 for £1k to tow
  155. Wanted!Urgent! stage 3 T3
  156. smoked side lites 4 escort cosworth
  157. RST Bottom end...
  158. Possible Swap - ??
  159. 2wd Saff wanted, just spent an hour in for sale section...
  160. Mk2 harrier please!!!
  161. Series 1 RS T Charge cooler
  162. xr4x4 engine mounts
  163. RS 1600i seats
  164. 2WD T3
  165. k&N Filter (group A)
  166. urgent
  167. set of rear 90 spec tinted lights pls like the pic inside...
  168. Escort RS Cosworth
  169. sierra rs cosworth 4x4 wanted
  170. WANTED: t4 exhaust housing
  171. t4 cos exhaust
  172. Escort Cosworth Amal/Lectron air pipes
  173. 4x4 drive shaft
  174. S2 Headlight duct thingy..
  175. Uprated Clutch for S2 RST ( Got one )
  176. fiesta turbo bits
  177. 2.0 zetec bottom end
  178. Esc Cos Alloys
  179. sierra sapphire cossie back doors glass
  180. RS TURBO SHELL / MK2 xr2/ MK4 3-DOOR ESCORT under £300
  181. S2 RST RADIATOR!
  182. NEED ESCORT S2 RST BOOT WITH SPOILER, AND FRONT BUMPER!
  183. fiesta rs1800 indicator stalks
  184. Broken Catalytic Converters
  185. RS 500 Bailey 4x4 type Turbo damper wanted !
  186. Mk1/2 Esc estate/van, or any old skool rwd.
  187. mk3 escort parcel shelf
  188. bumper mountings 1986 sierra cosworth
  189. cortina mk1 front wings
  190. Small, Cheap Runabout
  191. escort rs turbo rear disk conversion mounting plates
  192. Focus RS parts
  193. pinto dizzy needed
  194. cosworth 7.5" 3.9ratio rear diff wanted
  195. electric window switch and boot release
  196. Black 2wd saph, preferably stage 3 etc
  197. 4x4 cossie turbo manifold
  198. 2WD intercooler
  199. Mk2 XR2
  200. any1 got a set of 701 beige injectors?
  201. any1 got a set of 701 beige injectors?
  202. 1.8cvh alternator tension arm
  203. kenlowe or slim fan
  204. escort cosworth wrc frontbumper and grill wanted!!enyone??
  205. 19"
  206. wanted 15x8 minilites
  207. ST 24 / ST 200 ENGINE
  208. S1 bonnet and grill
  209. Knackered cossie bits/casings wanted...
  210. rs turbo van wanted
  211. Cosworth fuel pump wanted--Must be a good standard one
  212. rs 4 spoke stering wheel and boss
  213. a few ofac parts and xr3i part
  214. New -34 Actuator needed for T34
  215. Pinto parts or engine
  216. Now sorted!
  217. Focus RS Seats and doorcards
  218. wanted mk3/4 esc cabby drivers door
  219. Sapphire cossie bootlid
  220. mk3 fiesta van any engine or blown up dead engined1.25 mk4/5
  221. mk2 escort rs2000 wings
  222. escort mk4 dash bit above steering wheel
  223. THROTTLE CABLE CLIP
  224. after a "escort rs" chrome badge ??
  225. granada 1992 bonnet
  226. saff morettes,but just the lights!!!
  227. Wanted mountney, momo steering wheel...
  228. 4x4 cosworth thermostat housing..
  229. crashed escort cosworth
  230. Saph cossie Rear bumper in White needed
  231. Escort cos heat sheild + drivers side front shaft
  232. moondust fiesta turbo...
  233. escort bailey dump valve wanted pls and white dials MK4 !!!
  234. couple of saff cossie bits
  235. Escos Standard Orange Front Indicators.
  236. bits needed asap!!
  237. ESCORT RS TURBO BRAKES
  238. 3 door cosworth alloys for spares ,please read
  239. KONI SHOCKS
  240. 195 OFAC CHIP
  241. Escort MK4 Estate or 3door
  242. Wanted Rouse Sport side kirts for sapph cossie
  243. Fao Anyone who PMd About Saff For Sale.....
  244. injector..or injector and pipe
  245. 2ltr silver top zetec block
  246. rs turbo mk4 master cylinder
  247. vernier pulley
  248. 6 spoke comp mo's 17s Anyone???? STILL WANTED
  249. needed, injectors for mondeo 2.5 v6 or ST200, anyone ???
  250. cosworth fuel pump
