View Full Version : Cars & Parts Wanted.
- Cossie management setup for zetec turbo
- sierra cossie fuel pump
- wanted exhuast for my saph 4x4
- wanted 17's for my saph
- Series 1 wanted
- escort cosworth lambda
- MK3 or MK4 Escort Van.
- 3 door parts required
- rs turbo/ xr3i part
- Wanted - Escort Cosworth vent and centre console blank
- s2 rs turbo shell
- looking for a rs2000
- rear wishbone/hub etc for mk4 escort
- S2 wiring loom
- rs500
- ERST water feed pipes pleeeeeeeeease
- Series 1 Rubbers that go between the wing and slam panel
- .63 housing for T34
- xr2 manifold and carb
- S2 Top Hose
- frst parts needed (ofac ecu etc)
- WANTED some alloys for a zetec s fiesta
- Saph 4x4 Throttle Position Sensor
- s2 samco boost hoses in blue
- management
- stuff I need for Project "Marshall"
- Stolen parts needing to be replaced ASAP
- **wanted 2wd or 4wd saph**px s1 turbo..
- Small turbo escos inlet.
- series 1 wiring loom wanted
- ford ecu
- bucket seats
- set of lowering springs for s2 rst
- ..............sorted thanks to PF
- under bonnet bling wanted!!!!!!!!!!!!!!!!!!
- 16" Compomotive TH2 fwd
- 7x15 or 8x15 superlie/minilite alloys
- Compomotive 18"
- ESCORT MK 3 OR 4 , 2DR DRIVERS ELEC WINDOW MECH
- Escort Cosworth Black Rubber Boot Seal
- Escort Cosworth Rear Parcel shelf in Black
- 4 spoke wheel boss
- mk 6 RS 2000 front seats
- Sunroof
- frst ofab map sensor
- bubble shape fiesta
- looking for erst inlet connector and distributor!!
- Red escort cossie wanted
- RS500 bumper, headlamps, grill
- s2 bonnet vents
- fiesta !!!!!!!!!!!!
- rat cossie wanted condition not important
- FRONTMOUNT ERST
- rs turbo or cabriolet shell needed
- Turbo needed
- RST Gearbox.....
- air box saff cossie
- stainless with a 4" tail and blowers center vent unit ?
- boost pipe
- Red series 2 RST bonnet
- Fiesta MK3 Double A-Pillar Pod!
- Wanted merc grey passenger front wing for S2
- Bits and bobs wanted
- mk5 escort wiper&light stork
- RL7 raceline/evolution Escort Cosworth
- Looking for looked after Racing Puma
- stage 3 chip
- Replica RS/xr2i/xr3i
- Diesel Car
- ofac ecu / fuel pressure regulator / speed sensor frst
- mk4 escort door cards
- NEW escos cambelt cover
- SIERRA 3 DOOR COSWORTH WANTED (Got one)
- 2WD intercooler
- wanted amal valve and chip frst
- Wanted urgently T3 Turbo water pipes
- 2wd Running gear wanted
- 2WD Cossie head needed..Suitable for N/A application
- ST170 Front Brakes
- Rs turbo bonnet vents
- Ford Capri 1.6
- fiest si (1.4 or 1.6)
- Cheap dumpvalve
- MK4 escort windscreen rubber
- cv joints
- 2wd cossie / s1 turbo / gti-r
- Rad for S2
- ESCORT MK5 RS2000 REAR BUMPER WITH SPLITTER
- cosworth stage 3 parts wanted
- LH Pillar pods for 2wd sapp for two gauges wanted
- square beam arms
- sierra/escort cos throttle pedal
- RS500 REPLICA SPLITTER
- sapphire cossie wanted upto £3500
- Esc Cosworth Front Right Drive shaft
- 3 dr tailgate
- Anyone selling a cheap diesel?
- Fiesta,3door,1.4/1.6-SI **Wanted**
- stage 3 2wd cossie cash waiting on my desk
- 4X4 COSSIE LOWERING SPRINGS
- 4x4 cossie throttle body
- 3dr rear bumper
- RS1800 CDL MOTOR
- t3 turbo needed for my escort rs
- RS1600i oil cap and escort MK3 spotlightbrackets
- 1600i front spoiler& seat badge
- MT75 4WD PART
- SS exhaust for small turbo escos
- mk5a escort cabriolet wheel arch extensions/flares
- Escort td
- SERIES 1 RAD ANYONE?????
- Carpet
- 3 liter capri
- sierra spares
- 2wd exhaust to turbo..
- T2/25/28 TURBO
- Hockey Sticks
- 4X4 Saff Turbo heatshield bracket needed
- silly 2wd cossie bits
- Cosworth 4X4 MT 75 Lay shaft
- wanted sierra bits
- cosworth turbo
- T2
- Cosworth ECU cover
- Saff towing eye cover?
- ap brakes for a 2wd cossie
- wanted escort cosworth wheel.
- Escort Rs Turbo S2 Cambelt Tensioner
- mk3 escort 5door
- SAPPHIRE 2WD WANTED CASH WAITING !!!!!
- s2 chrome rocker cover
- SW Autodesign Splitter
- FRST
- looking for a focus to swap
- XR2/XR2i
- big disk conversion for series 2
- mk1 escort big gearbox tunnel (any other uprated parts?)
- wanted rst pipes
- I'm searching...
- rs500 bonnet vents
- Wanted dizzy for s1
- Series 2 top hose
- Front left and right driveshafts for cos 4*4
- i got a sapph cossie and want a deal with a 4x4 jeep or sell
- fordfair!!!
- couple of 4wd cos bits stupid things
- Mk2 XR2 wanted
- fiesta rst with blown engine
- HELP!im looking for a s2 shell, preferably white!
- Escort Cosworth 4x4 Shell
- escort recaros
- RS turbo engine bits needed.
- Sapph Cos 4x4 Cam Belt Cover ??
- Escort Cosworth Late type TPS connector wanted
- Wanted T3 turbo
- rs option sideskirts
- 1992 4x4 Cossie wanted
- erst aux water hoses
- swop wanted for evo 3 for mint condition rs turbo s2.....
- plastic type dash for mk 3 escort / orion
- XR3i fuse box
- esc cos intercoolerwith built in charge cooler
- cosworth small turbo escort inlet manifold
- Cossie block
- gear surround
- springs
- Cosworth Engine sensors
- Saph drivers leather seat
- quaif big tooth gear parts
- Mk5 rs2000 escort Mongoose exhaust
- wanted escort cosworth red or grey,big turbo,low miles
- s1 interior
- rs 500 rear spoiler and front bumper
- Mongoose down pipe for S1 RST
- Something interesting like a mk1 escort etc......
- Wanted RS1800 Fiesta
- Series 2 Starter motor.
- 2WD oil switch and turbo oil feed adapter
- wanted sapphire cosworth
- FRST OFAC Map sensor
- SERIES 2 DISTRIBUTOR
- wanted saf cosworth shell
- mecurary grey 90 spec front bumper
- Mondeo 2.0 block for ZVH Conversion
- Performance Cam
- Fiesta Turbo Exhaust Manifold needed
- Escort spot lamp / lamps needed
- DIA CUT RS 7 SPOKES WIT TYRES AND SUSP KIT MK4 ESC CAB
- escort rs2000 facelift passenger side sidelight
- S1 FRONT VALANCE BODYKIT
- S1 Seats front and back
- Grp A style manually adjustable clutch cable for 4x4 Saff
- ford motorsport ht leads in blue
- oil seperator/catch tank series 2
- blue samco water hoses
- Arrr back to RS ownership!!!
- [Home-based job] Branch Delivery / Shipment Agent
- Focus-3 Door, Black, Preferably Zetec spec. with 1.8 engine
- rs 1600 i wanted
- roll cage
- Wanted EFI CVH head for fiesta turbo urgent...
- cossie turbo required urgently
- ofac loom
- mondeo zetec 16" 5 spoke alloys wanted
- mk2 escort rs2000 lights
- Escort Turbo 90 Spec Trim!!! Red Rs Turbo Bonnet
- ofac or ofab frst ecu etc
- Ka 5.08 final drive
- RS1600i Fiberglass front spoiler
- Escort rst exhaust
- efi parts
- Cosworth Verniers
- BITS
- WANTED: From a mk3 Escort XR3i/mk1 Orion 1.6i Ghia.......
- got 1
- s2 rs turbo wanted
- SEREIS 1 BITS NEEDED
- Escort Cosworth Gearbox mount. (standard)
- YBP Plenum cover or the whole inlet
- YBP oil squirt jets
- Mk3 Escort/Orion bits needed.
- 3 door parcel shelf
- Wanted Scotland RS Turbo!!!!!!
- fiesta turbo bits needed
- Leather or black recaros - Black fiesta mk3 body kit
- 3 door top half of dash
- RS PISTONS OVERSIZE
- 18" Sierra Sapphire
- FORD 6000 STEREO FOR FOCUS
- Sierra 4x4 Wanted
- WANTED ! Ford motorsport ht leads sierra cossworth rwd
- Sierra 4x4 Wanted
- wiper motor
- t35 compressor housing wanted.
- S2 Alloy Rad
- s1 brake bar that connects to servo
- RS500 Intercooler
- T2 TURBO
- beige injectors
- rs tub wanted!!!!!!!!!!!!
- I need RS Cars NOW !!!!!!!!
- Cossie fuel pump....
- 22mm master cylinder
- s1 headlight scoop
- escort t3 turbo help
- escort turbo top of inlet manifold?
- 90 spec white RS Turbo wanted
- xr2i 8v 4-2-1 manifold
- water pump and rad needed
