View Full Version : Cars & Parts Wanted.
- leather recaros
- ka wanted
- fiesta rst top intercooler hose with dump valve peice!
- Good spec Escort or fiesta rs turbo wanted
- Chrome Bits
- xr3i/rs1600i Warm Up Regulator
- Recovery truck wanted
- 3dr gearbx mount
- wanted engine crane ....right now for the day,,,bournemouth
- L8 ecu
- wanted speed sensor
- Search Cosworth Bosch 023 Fitting Kit
- S1 Rs Turbo alloys ...................
- 2.0 silver top zetec needed!
- MINT 3dr bonnet....
- Urgent Cosworth k&n Group A Filter(s)
- Mk5 Fiesta 3 door drivers rub stip
- STD 15" S1 turbo/16i Wheels....
- S1 Turbo Parcel shelf....
- Saph Fog/driving Lights
- mk2 xr2 race car
- mk3 fiesta drivers door
- Brembo 4 pot Calipers
- wanted s1 rs.
- mk 5 rs2000 front bumper
- c20let pistons
- 2wd cos T3 downpipe for S2
- escort csworth
- Standard Cossie INNER trailing arm bushes
- fiesta mk 1 one
- Fiesta RS Turbo OFAB MAP Sensor Sepressor Wanted
- big bhp cosworth wanted
- Focus Rs Parts Wanted
- Omex rev limiter and launch control
- Need a 2WD baffled big winged sump
- Flint Grey Saph Bootlid & Drivers Side Rear Door
- large k+n filter for cosworth
- clip to hold front door locks for a 2wd
- PC 7424 Porter Cable polisher!
- Need a non smoking t2 turbo and driver door
- NSF and NSR saff jacking point covers
- escort cosworth crank pully
- Sierra Saphire 2.0i any spec with ABS
- Nintendo Wii
- escort mk3 suspension
- exhsaust
- 205 block needed
- ford ka
- ABS Sensor.
- mk5 rs2000 handbreak cable
- Helped spring
- Helped spring
- Rs1600i Shell
- Wanted 2wd cosworth Race Dampers
- 3 bar map sensor
- FRST exhaust, mongoose, magnex, scorpion
- rs turbo series 1 rear spoiler caps
- wheels
- Rs Steering Wheel Boss
- wrc mirrors
- Escort mk3 rear bumper (XR3/RST)
- big valve crossflow head
- 4x4 saff Mongoose 4" backbox+ Escort cossie gear knob
- 2WD Diff - London/essex area
- PIPER 285T2 CAMSHAFT and/or complete kit with vernier pulley
- 200 block
- saff wanted
- Pectel or Collins monitor
- Cheap 2litre Sierra. ideally lowered/uprated susp
- Escort Cossie shell?
- saff cossie 4x4 pas pump brackets
- OFAC chip
- wanted urgently 4wd aux belt tensioner
- Wanted golf gt tdi or
- saff parts
- series 2 rst carbon fibre bonnet
- Cosworth 4x4 intercooler wanted
- RST CTS gearbox Stage 2 with Quaife diff
- escot rs turbo
- Wanted: Fiesta Rst bonnet/red
- 4X4 rear beam + arms
- need some seat subframes
- Stage 3 chip for L6.
- rs steering wheel boss
- Wanted - S2 90 Spec Front Bumper
- Front driver side indicater for a saf.
- YB Cosworth clutch needed
- koni series 2 shockers wanted!!
- Wanted Asap Efi Loom
- WANTED larger Intercooler for S2 RST
- 1.8 focus gearbox
- Compomotive MO, 17 inch. x1
- decent MK4 RS TURBO shell wanted
- WANTED - S2 90 SPEC Rear SPOILER
- Oil pressure Sender Unit (BT Escort Cossie)
- front hubs for a 2wd cossie
- RS1600i Compression/Tension Struts
- air filter/ hose t34
- small turbo escos std airbox needed
- escos twin headlights
- P8 ecu
- escos amber indicators wanted asap
- MK3 Fiesta Windscreen
- wanted 4x4 tps
- Escort Cosworth T34 P8 standard chip
- wanted mk4 escort boot lock with key
- saph 4x4 crank pulley
- 3 door heat shield
- focus mk2 bits
- Series 1 Shell
- Wanted: Zetec-s Rear Bumper
- Need chrome/polished EFI inlet manifold Banna Bunch one
- Fiesta Mk3 Accsessory Rear Lights
- wanted rear lower spoiler
- escort cosworth morettes
- Inner roof vent
- pair of 3 point harness black/ dark grey
- Escort cosworth Alloys & Tyres
- Escort Cossie 4x4 T34 housing .48 or .63
- 90 Spec Parts Needed!!!
- series 2 sunroof wanted
- rear strut brace for escort
- After a Turbo for S2 Escort RS
- cossie turbo
- RS2000 bottom pulley
- 2wd steering coupling
- wanted l8 ecu
- Mocal oil cooler kit 13row for ZVH 2.0
- mk1 or mk2 fiesta project
- ofac ecu
- Escort/Fiesta Gearbox and 2 x nearsided driveshafts
- i need a bleed valve (anyone)
- 1997 escort gti ECU
- WANTED Escos WRC spoiler, drop links, morettes
- 4x4 big wing sump
- cheap project fiesta
- rs7 diamon cut single alloy
- escos 18"rondells
- Wanted, nice alloy's for a golf mrk4
- escort cosworth front wiper motor
- single hole pillar pod for a saph
- 2wd Gearbox To Engine Dirt Gaurd Spacer Plate
- wanted for a friend!!
- xr4i boot lock
- 2wd saph cossie abs pump
- nat/asp cosworth parts wanted
- Cosworth bits & bobs & Ford Racing Oil Gauge
- Mongoose downpipe
- stack gauge
- any car wanted just for work £200 ish
- Series 2 uncut loom
- mk 1 fiesta
- worn out AP paddle plates
- stack guages
- xr4i parts
- 909 diff mount
- 3 door cosworth wings wanted.? ?
- escos abs sensors
- 2wd crank pulley
- cortina hub and uprights
- 2wd iscv
- Small Turbo T25 Plenum Cover
- s1 front bodykit arch ns wanted
- saff roll cage
- Rear Disc Brake Set up for Escort RS Turbo
- rs 1800 doorcards wanted
- cosworth parts needed a.s.a.p
- 4 x 4 tps
- Fiesta mk3 shell or car
- lattice wheels wanted or some half decent rims
- cosworth fuel pump
- cosworth crankshaft wanted
- Recaro seat cover
- saff bootlid in magenta..?
- Escort Cosworth Tailgate
- Mongoose Backbox wanted..
- Wanted Pick Up Truck
- Wanted: Fiesta SI Bumpers
- S1 sunroof glass must be mint
- s1 sunroof deflector
- inlet manifold.
- urgent (wanted)
- wanted leather recaros.
- lancia delta intergrale injectors wanted
- 3 Door Turbo Headshield and Cam belt cover
- cheap sapphire cosworth wanted
- Erst T3 std Ex Housing
- recovery truck
- Wanted: Rs/xr2i Front bumper/arches/skirts
- 2wd cosworth fuel regulator..?
- Solid Beam Mounts
- exsaust problem
- 3dr Front Hubs and TCA's
- Bailel Breather
- calipers?
- 803 green injectors
- Wanted series 1 rs turbo
- t 35 turbo exsuast pipe
- 4x4 Cossie Hub
- Looking a 4x4 fuel pump cradle
- Rs Steering Wheel
- l8 pectel board
- 3dr bumpers
- Rs500 ID and logbook
- Escort Cosworth Rear anti roll bar
- red s2 open mouth front bumper
- Fiesta T2 Turbo needed!!!
- Escort Cosworth
- Cossie 4x4 Coilovers
- Escort mk3 cvh engine mount and cradle....
- S2 parts
- Group A Steering Rack
- really want one
- mk1 xr2 rear quarter cards
- Throttle Pedal
- iscv ...........3 bar map sensor
- any solid mk3 fiesta turbo xr2i rs1800 etc
- mk4 escort van or combi van wanted
- 2wd sapphire driver side front hub
- series 1 turbo wanted
- RST/Mk 4 Escort panels
- Focus brembo calipers
- rs turbo 4 paddle clutch wanted
- standard Sapphire Cosworth Wanted
- Zetec SE Engine
- 2wd saph cossie doors
- central locking relay
- group a air filter
- white 3 door front grill
- 200yb short motor or complete engine
- Flint grey Saph Cosworth bootlid and spoiler
- Sierra sapphire rear shelf wanted
- Wanted Scorpio/granada Fuel Pump-sender
- 7 spokes
- For Sale : Nokia N96 16gb /N95 8gb/ N82/i877
- wanted new chrome top headlights mk4 escort
- Transit LWB Hi-roof OR Vauxhall Movano LWB Hi-roof WANTED....
- rs turbo manifold with t3
- Sierra Saff Hazards Lense
- saf cos door mouldings
- rs turbo series 2 parts wanted
- T5 box
- Flint grey doors
- rs turbo wanted (show car)
- stainless exhaust for a 3dr?
- Saff Cos Rear Strut Brace.
- 15" steelies
- standard 3 door cossie rear lights
- S1 Spotlamp Brackets & Overiders
- rst roll cage
