PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 [9] 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. PF01 Throttle position sensor wanted
  2. Wanted
  3. Anyone got any centre locks they want to part with?
  4. 2wd cosworth stub shafts
  5. Group a airbox lid
  6. mk4 fiesta parts wanted....!!
  7. MK5 Escort Rear Seats
  8. MK4 Central locking motor
  9. mk1 focus rs gear selector/cables/knob
  10. S2 side skirt fixing strips
  11. Focus ST170 gear selector cable
  12. 4x4 cosworth exhaust manifold
  13. Escos Airbox Fuel rail, siemens
  14. Delete please
  15. brake servo
  16. Mk1 front spoiler/splitter
  17. s2 bits needed
  18. Escos fuel tank ASAP
  19. Escos fuel sender ASAP
  20. wanted. full set of 16 ghia wheel bolts (for cossie style rims)
  21. Mk1 escort parts wanted
  22. Escort mk4 parts wanted
  23. Sapphire spoiler bungs
  24. 8x18 comp's wanted
  25. PF09 TPS
  26. Please delete
  27. sierra limited slip diff wanted
  28. Zetec flywheel.
  29. 2wd adjustable lower arms
  30. Please remove
  31. Vernier pulleys
  32. Fiesta TDCI Zetec S 2006 onwards
  33. MK4 Fiesta / Puma Coilovers
  34. 4x4 Saph gearstick surround wanted
  35. Scooby parts
  36. Please remove
  37. WANTED!! MK 4 Escort Heated Front Windscreen
  38. Cosworth oil breather tank
  39. S1/S2 -25mm springs
  40. 200 Block
  41. Wanted Mk2 RS2000/Mexico
  42. Wanted orion rear n/s door
  43. Saff cosworth air box
  44. RS3/RS5 Shuttle wanted
  45. R1600i mk 3 boot
  46. Complete 3 door sunroof
  47. Cam Cover
  48. 18 inch Focus or Mondeo alloys
  49. GT30 Wanted GT3076
  50. 3dr cosworth boot lock
  51. Anyone got one of these?
  52. koni's/ blue hoses
  53. 88 spec RECARO seats ERST
  54. 3dr Cossie Parts
  55. mk5 Fiesta rear view mirror & 15" track tyres wanted
  56. sapphire cosworth 4x4
  57. 3 door cosworth wheels and tyres wanted
  58. Mot failure/cheap Puma
  59. 2wd Trouser section
  60. fiesta mk3 fuel neck & cap
  61. Full lock set for a 2wd cosworth (one key)
  62. Wanted,MK7 Transit bonnet vent ...
  63. Mk 3 fiesta lock set
  64. wheels wanted!
  65. fiesta turbo tps
  66. Stage 3 t3 or stage 2 t3 wanted asap
  67. regulating valves s2
  68. Parts Wanted - Fiesta ST Mk6.5
  69. T5 bell housing
  70. Megasquirt ecu
  71. S2 rs turbo parts
  72. 215/40-17 tyres
  73. T3 turbo
  74. S2 Wiring Loom
  75. Escort Cosworth boot plastic
  76. fiesta rs turbo mk3 hubs and rear suspension
  77. Wanted T5 Gearbox Bell housing
  78. 2wd parts
  79. RS500 bumper
  80. Sapph bits needed ASAP!!!
  81. Escort cosworth gear lever
  82. 3 door arch screw clips
  83. MK1 Sierra fog Retaining Plastic Clips
  84. series 2 rs turbo alloys
  85. 2wd saph cos rear calipers
  86. 205 45 16s needed
  87. Tyres
  88. After a set of rubber floor mats for a mk3 escort, genuine ford Rs
  89. Anyone got one of these please
  90. 300mm brake up grade
  91. Cosworth cam cover wanted
  92. 4x4 cam cover
  93. Cosworth Flame Trap Required......
  94. Cossie Cam Belt Cover Peg/Post
  95. idle valve
  96. XR3 or XR2 Engine needed URGENT!
  97. Sierra xr4i/xr4x4 2.8 thermo time switch wanted
  98. Cossie throttle body
  99. Sapph boot and spoiler
  100. Aeroquip/torques/goodridge etc
  101. escort rs turbo wanted
  102. Mk3 escort cvh alternator bracket
  103. Escos parcel sheld & ST airbox w breather pipes & elbows
  104. speedo drive casing ?? see pic inside
  105. Fitting kit for greys
  106. 2wd rear boot badge
  107. Mk4 escort 5 door interior plastics.
  108. Cosworth 2WD Front Drive Flanges
  109. Rondell badges needed ASAP " are they domed or just stickers????
  110. hi spec saph cos wanted cash waitng .
  111. Warm up regulator wanted for 2.8 xr4x4
  112. 205 45 16 tyre
  113. Odds And Sods
  114. 3dr cosworth wheel lock
  115. Need a purple fuel relay for a 2.8 xr4x4
  116. Mk4 escort carbon roof skin
  117. Rondell centre caps
  118. Small turbo escos and big turbo yb cam cover must be cheap
  119. Escos 18" wheels needed buy or swap my 16"x8" genuine standards
  120. Escos fuel pump sender, pump and securing ring needed help!
  121. Parts needed for my Saph TRADERS PLEASE
  122. Amber side repeaters and front indicators for a sapph!!!!
  123. Amber side repeaters and front indicators for a sapph!!!!
  124. 3dr front bumper wanted
  125. Mk4 Drivers door in diamond white
  126. Rs turbo .48 rear housing and elbow
  127. Downpipe cosworth turbo on rs turbo
  128. Single mk1 focus RS alloy wheel
  129. petrol turbo engine and parts for mk4 van
  130. mk1 sierra wing
  131. Escort Cosworth Gear Stick Surround
  132. 4x4 Parts (Traders Welcome)
  133. drivers side mk 1 focus wing mirror
  134. Couple of saph trim pieces
  135. Anyone got a FRST window switch laying about?
  136. blacktop head
  137. 2wd hubs
  138. Bolt for throttle cable
  139. early 4x4 cosworth alternator
  140. Wanted 3dr front bumper or rs500
  141. Wanted 3dr original front wings
  142. 4x4 oil pick up (strainer)
  143. Wanted - Mondeo ST TDCi
  144. rad hose
  145. Looking for a track toy. Anything considered.
  146. Mondeo lowering springs
  147. rs turbo parts
  148. Wanted 90 spec clocks
  149. Mk5 rs2000 loom
  150. Zetec engine and ecu
  151. cvh efi flywheel wanted
  152. 2wd saff front abs sensor
  153. Mint 90's spec erst recaros
  154. Garret GT3071r **wanted**
  155. 2x 205 40 17
  156. Rs turbo stage 3 hybrid
  157. Zetec/focus rs gearbox bolts
  158. 2wd front hubs
  159. Wanted mk4 escort coilovers
  160. Wanted: 3 door sierra base model
  161. Mondeo 5 spokes 16"
  162. wanted magnex 2wd exhaust
  163. WANTED 88 or 90 spec mk4 Escort Recaros
  164. Mk4 escort 1.6 exhaust manifold
  165. Escort reverse light switch plug
  166. st170 upgrade parts
  167. Cosworth 3dr wale tail caps
  168. Zetec turbo injectors
  169. Bolt needed
  170. Anyone selling a turbo?
  171. wanted mk5 escort stainles steel exhaust
  172. cosworth cambelt cover mounting nuts
  173. t5 2wd gearbox
  174. 3dr cosworth hubs
  175. 2wd cossie throttle body modded for als
  176. diesel car wanted
  177. x2 harness suspension wheels brakes etc!!!
  178. Compomotives
  179. Wanted ford split rims for mk2 escort
  180. 215-45-17 track tyres ?
  181. Fiesta XR2 I G plate - Does any one have a radiator for sale
  182. sierra hatchback roll cage
  183. Focus RS turbo
  184. 2wd/4wd Cosworth downpipe and standartd 4x4 actuator
  185. Loom clips
  186. 3 Door rear strutbrace
  187. 2wd YB Oil Pick Up Pipe
  188. defender 90 wanted
  189. Cvh cosworth management
  190. mk5 dash wanted
  191. 2wd turbo heatsheild wanted
  192. Zvh wanted
  193. 3 dr cossie door strips/ protectors
  194. Wanted fiesta turbo parts
  195. .48 turbine housing cosworth
  196. Wanted - Focus RS mk1 :)
  197. 3dr header tank and washer bottle wanted
  198. Wanted Ap 330mm discs and 2wd koni suspension kit
  199. Cosworth 4x4 vent covers wanted ASAP
  200. various mk3 s1 rs turbo parts
  201. cosworth crankshaft wanted
  202. 108mm cosworth stub axle
  203. Door handle and lock
  204. 2wd cosworth abs sensors (front)
  205. Rs turbo non abs reservoir
  206. Saff bulkhead brake pipe clips
  207. Sierra 1.8 drive shaft
  208. Sierra 3 door rear quarter window trim clips ?
  209. Mk5 fiesta door handle
  210. 2WD Cosworth Sump
  211. wanted AP 6 pot or 4pot kit
  212. anyone got a chromed compomotive centre cap for sale?
  213. mk 5 escort side lights needed
  214. rst turbocharger t3 or above
  215. 3dr cosworth car loom
  216. pf09 tps 4wd engine loomand blue boost hoses
  217. 3dr/escort front ambers and fog light grills
  218. Small Turbo Escos cam cover
  219. wanted azev a or borbet a for MK5 cortina
  220. Fiesta rs fuel rail.
  221. Adjustable fan relay kit
  222. cosworth throttle position sensor
  223. Wanted gaz coilovers for xr4i
  224. WTD: Saph Cos 4x4 18mm ARB
  225. ERST drivers side driveshaft
  226. 3dr cossie
  227. Ford sierra or xr4i koni adjustables
  228. 3dr front bumper and grill
  229. Vibratechnic engine mounts
  230. Red S2 bonnet and S2 alloys
  231. Escort GTI inlet hose
  232. Erst s2 body kit
  233. Saff Cossie rear window triangles
  234. Dipstick and tube 1.8 zetec from escort
  235. t3
  236. Genuine ford cvh oil pump
  237. Cosworth cambelt cover fixing mounts/ 2wd turbo damper
  238. ggr 3 port breather
  239. Bailey oil breather for escort rst
  240. wanted escort rs1600i interior
  241. Cosworth Headbolts New or used
  242. Series 1 Arches, skirts and rear spoiler
  243. MK4 Escort Roll cage
  244. MK5 Escort Clutch Pedal
  245. Looking for pair of mondeo mk3 callipers!
  246. Sierra cossie airbox lid clips
  247. Wanted, standard 4x4 sierra cosworth exhaust
  248. 2wd cossie speedo cable
  249. Series 2 coilovers and rear strut brace!!
  250. green bumper moldings!!
