Log In
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Escort Wishbones
  2. 2.0L zetec crank or block
  3. few parts needed to finish the project off.... ERST
  4. ecos tool kit and owners manuals
  5. boost gauge mount. series 2
  6. Carb for 1.4 CVH - Weber 28/30 DFTM
  7. series 2 interior
  8. Series 1 gearbox mounts
  9. large front brake kit
  10. s1 recaros **PLEASE HELP**
  11. wanted:sapphire cosworth white front bumper and...
  12. Cam cover gasket
  13. 16" Wheels for Escort Cosworth Race/Rally Car
  14. mk1 /2 escort
  15. Granada 24v Radiator
  16. S2 recaro's
  17. frst/xr2i driverside front fog/driving lights
  18. Escort Cosworth fuel pump to fuel filter pipe
  19. 2wd saff parts wanted t38 turbo bd14 inlet cam plenum spacer
  20. In need of S2 RS Turbo parts
  21. -31 actuator
  22. escort cosworth grill
  23. rs2000 or xr3i 130
  24. Wanted S2 RST with engine problems
  25. ABS SENSOR URGENTLY REQUIRED
  26. compression plate and efi zetec turbo bits
  27. mk4 escort o/s front hub in essex/cambridge area URGENT
  28. escort rst rad
  29. £££££ RS Cars Wanted ££££££
  30. Twin 40's
  31. Cosworth Cam
  32. reacro seat winder
  33. mk1 or 2 escort
  34. Alloy rad
  35. rl7 ears speedlines wanted?
  36. Escort Cossie
  37. alloys
  38. cvh-zetec plate
  39. s14 injectors
  40. cosworth petrol flap
  41. cosworth clock!
  42. capri tickford
  43. Elliot 80mm Boost Gauge
  44. FRST Efi Inlet Manifold
  45. series 2 fuel pump
  46. CVH Turbo Oil Drain Pipe.....
  47. IB5 gearbox
  48. S2 Rear Wishbones and ARB
  49. 2wd Cos Clutch associated parts.
  50. sierra saphire ghia or 2000E wanted or escort bonus
  51. o/s front driveshaft for cosworth 4x4?
  52. Ford cd player got one please lock
  53. 1992 K Sapphire Cosworth 4x4 wanted
  54. Gearbox Bracket for Escort S2
  55. WANTED!!!!! HYBRID T3
  56. 3 Door header tank alloy or std and swirlpot
  57. wanted escort mk 6 bumpers
  58. 2wd cos calipers, in VGC
  59. Front RS500 Bumper Wanted + spliter.
  60. T4 TURBO WANTED
  61. 300m rear disk+bell
  62. mallard green escort cosworth
  63. 2wd turbo heath shield {mint}
  64. Sapp 2wd Fuel pressure regulator
  65. 2wd 909 coilover bodies (front)
  66. Mk4 Ford Escort Headlights
  67. L6, L8 OR P8 ECU wanted cash waiting
  68. Carello spots!!!!
  69. Starter motor
  70. RST Gearbox
  71. cosworth alternator heatshield
  72. single 7.5x17, 5 spoke mo (tyre not needed)
  73. Rear jackcovers, Sapphire Cosworth
  74. black saff cossie 4 wheel drive
  75. 4wd cossie con rod needed
  76. A really good spec S2/S1, or 2WD COS
  77. mrk 3 bonus shell wanted
  78. Set of steel rods for RS Turbo
  79. Wanted: Ford Mondeo Diesel
  80. RED escort cossie
  81. cosworth engine
  82. ERST Fuel Pump
  83. SILVER DISKLOK.
  84. t38 turbo wanted
  85. Caymen Blue Fiesta Parts & Other Extras
  86. rs orion drop skirt 1988
  87. management and full running gear
  88. BONNET FOR S2
  89. ecu for 2litre mondeo wanted
  90. 2wd turbo heath shield {mint}
  91. t4
  92. clear cam belt cover for CVH
  93. s2 metering head
  94. P8 ECU - wanted cash waiting!!!
  95. 2wd coilovers
  96. s1 turbo rad
  97. stage 3 chip for l6 2wd
  98. Escort Cosworth/ Possibly 3 Door
  99. parts wanted to repair crashed fiesta
  100. 3 door or good spec 2wd saff
  101. Sorted, please delete
  102. centre console
  103. Cosworth Uprated breather
  104. s1 or s2 200+bhp
  105. 2wd/3dr cosworth suspension
  106. O/S exhaust manifold and rear shocks
  107. Mint S2 white/grey
  108. s2 jacking point covers
  109. quaife 2nd gear wanted for 4x4 cos
  110. Escos tailgate
  111. bare 4x4 head and block
  112. 2wd intercooler wanted
  113. RS1800 or RS Turbo
  114. Fiesta RS Turbo engine
  115. 2.5 bar mapsensor, SORTED, THX !
  116. Uprtated 2wd cosworth rear diff
  117. MINT SAPH COSWORTH BOOT CARPET
  118. WANTED 3DOOR COSWORTH SHELL
  119. wanted: garrett T34 with 0.48 (or 0.50 0.55) for a Sierra
  120. comp mo's
  121. Wanted: Flint Gret / Black Sapphire Cosworth Shell
  122. Sierra Twincam
  123. 1 x 17" momo arrow wanted for Sierra Cosworth
  124. starter and servo
  125. New or nearly new LSD Erst gearbox
  126. mondeo tdci zetec (part x fiesta zetec s 02 plate)
  127. Sapphire Rouse body kit
  128. FIESTA SI 1.6
  129. Series 1 Side decals
  130. cosworth 3door shell in white must be mint
  131. erst s2 rad
  132. S1 Bodykit rivet cover
  133. mk 4 escort bits
  134. Anyone got ECU for FRST EFi?
  135. big front brake setup
  136. mk 4 escort sleeper / bonus
  137. WANTED: FRS Fuel and Water pumps...
  138. cossie 3dr alloy wheels
  139. Mongoose
  140. frst shell
  141. frst shell
  142. s2 turbo bits wanted a.s.a.p please
  143. fuel metering unit for an rs
  144. Magenta rear bumper for Saph wanted...
  145. Cossie / cosworth / Granada / Scoripo / 2.9 v6 L@@K
  146. WANTED - S2 RST
  147. 2wd gear stick-SORTED NOW-
  148. FRST bonnet, front and back bumpers! recaro's!
  149. Clutch for ERST to cope with 250bhp
  150. RS 500 LOWER BOOT SPOILER!!!!
  151. escort rs turbo rear seat mountings
  152. 803's 3 bar map and msd stage 3 chip
  153. WANTED 0.63 Housing - swop or cash etc!!
  154. WANTED - 16" Alloys for Escort Cosworth Race Car
  155. saph cossie
  156. RST Wanted for Breaking!!!!
  157. 3 bar map
  158. Uprated cosworth front diff
  159. Remote ISCV housing for cosworth
  160. focus cobra subframes
  161. steering wheel 3dr cosworth
  162. S1 spotlight brackets & bumper over riders
  163. 8 pot brembos and 380 mm discs
  164. Cheap S2 RS Turbo
  165. off side front drive shaft from a xr 4x4 urgent
  166. green injectors
  167. jack
  168. lite blue injectors
  169. WANTED - 16" Alloy Wheels for Escort Cosworth Race Car
  170. TWO 4x4 Saff intercoolers
  171. 16" Alloys for Escort Cosworth Race Car
  172. RSOC seat covers (black)
  173. fiesta power steering
  174. Saff amber frt indicators
  175. escort cosworth front spliter/ bumber wanted
  176. STANDARD SAFF 2WD STEERING WHEEL
  177. 17 inch alloys multispoke
  178. ***4x4 oil pickup pipe wanted URGENTLY***
  179. RS Turbo Flywheel
  180. s1 spotlight brackets
  181. sierra body kit
  182. wanted 200 block
  183. COSSIE 4*4 FRONT CALIPERS
  184. sierra sapphire bootlid
  185. rear 1/4 s for 3 doors,
  186. Escprt RS Turbo or Fiesta RS Turbo Cam Pulley needed ASAP!
  187. stainless 75mm backbox
  188. mk3 escort lowering springs
  189. mk4 escort non abs brake reservoir..
  190. bucket seats
  191. Raceline RL7's
  192. white 3 door sierra or decent low mileage escort cosworth
  193. Mk3 Fiesta rs accessory rear bumper
  194. 3 door wanted
  195. 3dr cossie shocks
  196. FUEL PUMP
  197. 90 spec rs turbo carpet
  198. focus rs
  199. Cossy front leather seat
  200. t3 turbo
  201. ECU from mondeo !
  202. xr2i
  203. FRST CAM
  204. Clear Front Indicators
  205. new parts want (rs turbo)
  206. delete
  207. Wanted, Escort Cabriolet Interior
  208. still looking for
  209. wanted : rs1800 inlet manifold
  210. S1 or S2 front suspension legs
  211. Rear lower arms
  212. 14'' steelies
  213. 4x4 front calipers & 2wd discs!!!
  214. s1 or s2 front seats any condition wanted
  215. S2 Escort RST...
  216. speed sensor for a frst
  217. .63 Exhaust Housing
  218. TSW alloy Wheel centre nut
  219. mk3 fiz quads needed
  220. sierra roll cage!!!
  221. mk5 escort rollcage
  222. FRST ACT Sensor
  223. 2wd engine wanted
  224. Series 2 Brake reservoir cap
  225. fiesta van!!
  226. cossie idle control valve wanted
  227. alloys
  228. standard wheel nuts for 3dr
  229. rs turbo roll cage...
  230. Hooooj T34 air filter wanted
  231. Sierra Cosworth 4x4 Engine Mounts
  232. WANTED COSSIE
  233. erst front bumper
  234. Erst S2 Sunroof wanted
  235. Escort Cosworthn air box
  236. Good spec 2wd saff
  237. MTX75 Quaife kit fitted
  238. Wanted: ERST exhaust housing & oil/water return pipes fo
  239. turbo damper bolt with the spring on!!
  240. Headlight potectors wanted
  241. MK4 XR3i Cabriolet clear rear lenses
  242. series 2 or fiesta turbo engine
  243. SWAP . stainless cosworth exhaust wanted with centre box
  244. Recirculating Dump Valve for 2WD Cossie
  245. S1 mk3 escort RS alloys wanted
  246. WANTED: ACT Gauge air charge temp lcd
  247. T4 Turbo for Cosworth
  248. 2wd cos standard exh.cam
  249. Escort cosworth fuel line - tank - filter
  250. FOCUS RS FRONT GRILL
