PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Collection front bumper Focus Mk1.5 (facelift)
  2. Mondeo ST24 front spring.
  3. cosworth power steering pipe urgently required!!
  4. 2wd sump
  5. Mondeo ST TDCi Back box
  6. wanted. 3 dr grille white
  7. Mk6 fiesta bonnet
  8. Stack AFR Gauge
  9. Wanted White Escort Cosworth BT
  10. Wanted White Escort Cosworth BT
  11. WANTED: excellent condition front 4x4 hubs
  12. Cosworth headlight wiper arm
  13. A-pillar
  14. 17inch ET35 Wheel
  15. frst/xr2i bumpers and arches wanted
  16. Wanted: Mint timing belt cover, Cosworth 2wd
  17. wanted bd 12 and bd 14 cams
  18. Boost hose
  19. RS parts Braking bits
  20. 4x4 thermostat housing and bulkhead sound deadening
  21. escort mk6 gti estate
  22. FRST induction kit
  23. Need 2.0 flywheel urgent
  24. st220,s4 estate. e36 m3 3.0 coupe
  25. 2wd Thermostat Housing
  26. Complete 2wd Cosworth suspension kit (not coilover)
  27. saphire mirrors..
  28. wanted passenger side front jacking point cover
  29. 7.5 inch diff..
  30. Silver Top Zetec Sump
  31. bulkhead heat shield
  32. Genuine Ford Sierra sapphire mudflaps
  33. cosworth 205 block
  34. 205 40 16 tyers
  35. K&N Air Filter Group A or 57i induction kit
  36. 4x4 Saph rear towing eye cover
  37. 1x's 17" th2
  38. Pectel T6 ecu wanted urgently cash waiting
  39. cosworth grey injectors
  40. drivers door handle saph cosworth
  41. p8 anti-lag pectel board mtc or btc....
  42. 4x4 fuel reg
  43. 4x4 fuel reg
  44. Passenger side morette cover for mk4 escort??
  45. Rs Turbo uprated (bailey) breather.
  46. n/s/f leather door card for sapphire cosworth
  47. focus springs
  48. st170 3 door trim bits
  49. anyone breaking a 1.9 scenic ??
  50. Cosworth Jacking Point Cover
  51. wanted
  52. Carbon door handles or skins.
  53. 2wd 4" backbox
  54. quaife or gripper 7.5 inch cosworth diff..
  55. FRST Top Engine Mount
  56. mk3 bumpers, bits
  57. Cheap 4x4 saph wanted
  58. car spin turnover flip jig
  59. Cosworth 4wd fuel rail needed asap
  60. Urgently Wanted: RST Metering unit
  61. Wanted t34/t35 turbo
  62. 1 x 205/40/16 tyre?
  63. Snap on personality keys
  64. xr2i rear springs
  65. Cosworth front headlight side lights
  66. 2.8 TYPE 9 5spd GEARBOX FLYWHEEL AND CLUTCH WANTED
  67. Cosworth silicone hoses wanted
  68. mk1 fiesta
  69. 2 2l zetec engines
  70. s1 erst boost hose
  71. Good or rubbish 2wd gear knob
  72. Focus RS Mk1 Gearbox
  73. Fiesta XR2 Mk2
  74. fiesta mk4.5 cd player head unit
  75. Wanted efi mk4 escort clocks
  76. mfi turbo
  77. Bosch 803 Green Injectors
  78. Turbo parts needed
  79. Breather hose anyone?
  80. kenlowe 10" slim line
  81. Apexi 2.5 Boost Gauge Sensor
  82. 3dr rear quater glass and sunroof
  83. Wanted front mount intercooler for a series 2
  84. saff std rim and cloth passenger bolster cloth
  85. dump valve
  86. T3 oil feed union
  87. Vauxhall vivaro or Renault trafic WANTED
  88. Coolant Temp Sensor
  89. recovery truck
  90. CTEK Battery maintainer/charger
  91. 1.8 or 2.0 Zetec Silvertop wanted
  92. cosworth FUEL RAIL
  93. Thermo Time Switch
  94. Scopion Exhaust
  95. Saff Cossie Boot Lid
  96. fiesta rear lowering springs mk3
  97. TomTom XXL or XL
  98. xr2 donar car
  99. mk1 mondeo rear bumper & RS overskin
  100. escort cosworth fuel rail (with or without regulator)
  101. rs1600i modified rocker cover for turbo conversion
  102. sierra 4WD fuel pressure regulator
  103. Little metal Horseshoe clips for plugging in Series 1 loom
  104. Wanted CTS Stage 2+ Gearbox please!
  105. Escort Mk6 Front Bumper
  106. rs 7 spoke
  107. Amber Indicator lens for a sapphy
  108. s2 tailgate in vgc
  109. t3 actuator, bracket and bolts
  110. Merc Sprinter Engine wanted !
  111. Escort rs turbo coilovers
  112. Wanted genuine ford coworth rear trailg arm bushes
  113. Sapphire Cosworth Lattice Centre Caps Wtd
  114. fiesta rs turbo engine loom
  115. Ford sportka front bumper wanted
  116. anyone breaking a late spec xr4x4
  117. Wanted ES COS BT Airbox
  118. saph cos less running gear..
  119. granada cosworth 2.9 boa injection relay
  120. Ford sportka front bumper wanted
  121. S2 80 Spec door cards
  122. S2 Radiator and Fan
  123. ST170 Inlet manifold
  124. samco boost hose
  125. Escos Rear ARB
  126. Cosworth T5 bellhousing wanted
  127. Right then.. Who knows where I can find a scrap Granada 24v going cheap?
  128. saff 2wd Boot lock
  129. Old style rear view mirrow poss capri
  130. 'T' Pull Cable Handle
  131. escort mk4 bonus front bumper
  132. Facelift saph cos clocks surround
  133. saf rear light
  134. 3 door cossie fog light
  135. crystal clear morette outer lamps
  136. wanted 3 bar map sensor
  137. escos tow eye
  138. 17 inch th2s
  139. 2WD Saff
  140. s2 parts needed fast thanks
  141. 17" Ford Softcuts. Wanting info :)
  142. Bosch 803 dark green injectors wanted
  143. s2 rs turbo n/s rear window seal or green tinted opening 1/4 windows
  144. wanted
  145. s1 shell wanted
  146. Rear strut brace wanted
  147. Pectel T2 Software and laptop cable
  148. s2 throttle position sensor
  149. l6 chip, .55 & scorpian backbox
  150. Amal valve jet (plastic undrilled)
  151. Saph Heavy Duty Car Cover Needed
  152. s2 mercury grey bonnet wanted
  153. Saph cossie arch liners
  154. series 2 bits
  155. 2wd cosworth t5 gearbox wanted
  156. 3 door cosworth please
  157. focus parts
  158. wanted rs2000 mk6 engine
  159. s2 cold start injector plug with wiring
  160. stack egt and water temp gauges
  161. xr4x4 gearbox 2.9 wanted
  162. still wanting a rs2000 mk6 engine
  163. 4wd or 2wd diff wanted
  164. rs500 fibreglass front bumper
  165. 3 door/sierra front indicator bulb holders
  166. l6 chip and 55lbs injectors
  167. 17/18 inch comp's
  168. s2 rs turbo
  169. 2wd saph rear caliper carrier(slider)
  170. Rear jacking cover
  171. wanted 5ft wide trailer.
  172. fiesta van panels
  173. 3 door/escos smoked front indicators
  174. MK1 FRS rod or rods
  175. Ford KA
  176. recaro headrests
  177. Engine Rebuilding Stuff
  178. wanted 206 rear axle
  179. Headlamps, fender for Sierra 3 doors
  180. mk3 escort shell or full car
  181. fiesta rs turbo drivers door moulding
  182. Focus RS
  183. saff cossie roll cage
  184. esc cos bonnet sound deadening
  185. 3 dr sierra cossie Front ABS sensor WANTED
  186. Post content deleted
  187. ERST inlet sandwich plate
  188. Scorpion Exhaust
  189. 1/18 model Cossie
  190. eec4 block
  191. Escort RST LSD box
  192. 2WD heatshield
  193. cosworth L6 chip
  194. 2wd centre section / back box
  195. Wanted decent specced saff
  196. 3 door front indicators
  197. 2wd t5 5th gear needed
  198. 4x4 Engine backing plate required
  199. gti bumper
  200. Quad bike 250cc +
  201. o/s/f window
  202. Any one breaking a sierra
  203. harnesses wanted
  204. Rs500 throttle body or eeciv throttle body required
  205. Rs500 inlet required
  206. S2 ERST silicon hoses + other bits
  207. WANTED 17" Compomotive / Revolution Alloys
  208. cosworth 4x4 ported and polished head
  209. A few 2wd items
  210. Found some... PLEASE DELETE!
  211. eec4
  212. WANTED : Snap On middle box...
  213. Pectel T6 Ecu wanted
  214. 3dr dashboard lower section
  215. 18" Rondells or RL7's
  216. 2WD Rear brake dust shields
  217. mk1 escort bits needed...everything!!!
  218. t5 cosworth clutch fork, scopion centre box exhaust 3inch
  219. Snap on tools
  220. Bracket for clifford siren
  221. Scorpion Exhaust
  222. Wanted urgent Pectel T6 ecu
  223. Escort RS Turbo Parts Wanted
  224. Escort Cosworth Rear Anti Roll Bar
  225. Intercooler plate, sapphire Cosworth
  226. speed sensor and cable s2
  227. T3 turbo (hybrid)
  228. Series2 RST ARB mounting
  229. Series2 RST LSD gearbox
  230. Escort rs turbo gas tailgate struts
  231. apexi avcr (fiesta rs turbo)
  232. wanted
  233. 80mm boost gauge..
  234. wanted koni or similar rear suspension
  235. Puma springs wanted
  236. rs turbo expansion tank cap
  237. FIESTA MK6/7 PARTS NEEDED 06 reg
  238. X2 215/45R17 tyres asap
  239. speedo cable
  240. S2 Metering head, mirror trims
  241. 90 spec
  242. 3 door boot carpet
  243. zetec sump
  244. T34 in good condition
  245. ERST Coilovers
  246. 2wd cosworth
  247. ALS valve or iscv
  248. Standard Series 2 RS Parts
  249. rs turbo .5 pistons wanted
  250. 4x4 fuel reg
