View Full Version : Cars & Parts Wanted.
- 17" Diamond cut RS 7's
- Escort gti interior
- exhaust bracket
- Mint 4 spoke rs steering wheel
- fiesta st alloy wheel cap
- saph bits wanted
- 2wd sump good conditon
- Remote ISCV Housing
- wtb ABS ring to suit 3 door cossie
- 4x4 Cosworth Inlet
- New or nearly new 803 dark greens for cosworth
- Genuine Ford Wind deflectors/headlamp protectors anyone???
- Escort Cabbi bits
- Sapph front leather seat
- focus rs engine
- wanted l8 ecu
- 4X4 Standard grind cos crank needed
- sierra boot solonoid
- 2WD Cosworth Fuel rail
- mk4 sunroof
- Wanted Escort Cosworth Propshaft
- Rst master cylinder
- cheap engine stand and ps3 console.
- mk6 RS2000/mondeo 5 spoke's
- sierra cosworth headlights and
- please delete
- Wanted - Standard 4x4 Sapph header tank.....
- P100 pick up
- #### wanted #### tyres 195 40 16
- Throttle Bodies N/A
- L8 wanted
- small rst parts needed asap
- MK4 Mercury Grey Front Bumper
- S1 gearbox
- Kent vernier pulley
- 18" Monte wheels
- Cabriolet front window seals
- Quaife Cosworth Bell housing wanted
- sorted
- S1 gearbox
- escort turbo downpipe
- Saph leather seat wanted...
- RS Cars wanted anything considerd
- please delete
- 3dr bonnet
- Black silicone boost hoses for s2
- T34 samco hose needed
- WANTED!!! T5 gearbox in perfect working condition
- Bailey or similar turbo damper for 4wd Head and T4
- Subaru Legacy/Impreza Non-Turbo
- S2 interior parts
- wanted ford orion glsi mfi not efi!
- WANTED: Saph rear electric window motors/linkage
- ####~Mondeo Mk2 Bumper in state blue~#####
- Escort RS Turbo low mileage bottom end
- Gearbox 2wd sierra cossie
- KA
- 3 inch mongoose system for 3 door cossie
- ERST Recaros
- Bonnet vents (as let down by member)
- LOOKING FOR CARPET for Mk2 Fiesta
- filter for t4
- 2l Zetec Black-top Head
- 4x4 bottom end
- This Sapphire Front Bumper Part... (FOUND ONE!)
- Wanted 4x4 cosworth amal valve
- s2 bumper inserts and rear seat 88 spec
- complete 3DR inlet and throttle body (Standard)
- t5 bell housing/2wd mongoose s/s system. t34
- Needed urgently
- 2WD down pipe
- Saph 4X4 bonnet vent
- WANTED D/S front window
- Cosworth T5 Gearbox output shaft
- wanted! orion mk4 escort shape.glsi or turbo'd
- 350mm front brake kit!
- Fiesta MK3.5 Subframes
- Orginal front series 2 mudflaps
- Cbr600/gsx600/zzr600 w.h.y?
- Sierra cossy 2wd clutch and engine loom.
- CVH Cam sensor bracket
- escort cosworth center console wanted
- bonnet latch for s2
- 701s
- Escos T35 std air hoses
- standard saph radiator
- cosworth spec - r heat shield
- Escort rs turbo drivers door
- plenum spacer
- siemens 83lbph injectors wanted
- wanted sapphire leather interior
- T34.63 With/without maram shaft
- need a orion, soon as possible
- 17" comps
- Escort Rs Turbo fuel pipe
- bd10 intlet for 4WD
- focus jig
- Few parts needed, urgent !
- Stage 3 setup for 2wd saff...
- used cosworth exhaust gasket
- sapphire cosworth leather interior
- Wanted- 4x4 Sapphire 4" outwardly rolled Mongoose Backbox
- cosworth Alloy radiator
- WANTED: Black door strip for pass. side rear door (saph)
- Escort Rs Turbo Uprated Suspension
- 3 door rear bumper in Moostone Blue wanted
- series 1 stainless exhaust
- Tarmac GpA cosworth Front Anti-Roll bar kit
- springs
- escort cosworth shell
- 2WD full working TB
- focus rs body parts
- T34.63 2wd Cosworth Turbo (pref maram)
- urgent 2wd saff bits needed
- s1 turbo or mec grey 90spec s2 why folks
- xr4i rad and interior
- 17" sticky tyres
- cosworth l8 ecu, amal valve,
- escos rear window rear fixing. drivers side
- 4x4 cosworth bonnet catch & rear seat hinges
- Rs horn push for a 2wd steering wheel
- Sierra 3 door front hubs (or near side only if thats all you have)
- Sierra a-pillar pod
- T34 turbo
- 2wd fuel regulator
- focus rs parts
- toolkit or towing eye
- wanted: Ford focus 1.6 5 door
- K&N T34 Sized trumpet for grp a airfilter
- Escort cosworth propshaft
- s2 rs turbo top rad hose
- 2wd pick up pipe wanted
- !!!!**2wd cosworth Bilstien front coilovers** !!!
- Wanted: RS1600i
- 175 / 50 / 13's
- L8 ECU *Wanted*
- RS500 front bumper Wanted
- Cossie Dash
- Wanted: Std 2 bar map sensor
- fiesta rs , green bumper insert
- fiesta mk3 loom with fuse box
- 2wd cossie saff steering colum
- wanted:cossie bumper indicators&fogs
- .5 pistons
- 2wd thermostat housing & 2wd exhaust manifold wanted
- Escort Rs Turbo Front Coilovers or full Set
- Standard top boost hose for s2
- St170 rocker cover
- Inlet manifold & injectors
- Rs turbo stage 3 turbo
- front konis or front coilovers
- fiesta rs turbo mk3 headlight protectors!
- WANTED: Ford Focus RS or ST170 Rear Caliper Carriers
- rs turbo clocks 88 spec
- escort rs turbo 90 spec fuel tank
- l8 ecu
- 16" alloys
- Siemens Black 83s
- wanted escort rs turbo engine
- Wanted - Diff/LSD for IB5 Gearbox
- Series 1 rs turbo stainless exhaust
- 3dr wanted
- escort cosworth loom
- L8 standard baby board
- A3 lowering springs
- 909 rear diff mount for a 3dr Cossie
- EFI Accelerator Pedal from FRST, XR2i, or XR2i EFI model.
- Escort gti interior & doorcards £40
- Cheap Go Kart
- Wanted Focus RS Nearside Top Rad Hose
- focus rs rods and pistons
- Summer toy Wanted, Kit car, Bike , project etc..
- cossie T3
- 2wd cosworth blue samco hose for a 4x4 expansion tank
- Fancying an S1
- Wanted the bit to turn off the indicators on a sapph
- filter for gt30
- cars wanted
- 3 door clear indicators that fit!!!
- Cosworth 2wd front hubs
- cossie 2wd front crank seal housing
- Old style flat spoke 17inch Mos wanted
- JAM SPORT RS turbo tubular manifold
- 2wd cossie exhaust
- escort -60mm springs
- Pair front struts
- Does anyone have a bottom end for sale
- delete
- 15" alloys (comp mo's??)
- 1.6 cvh efi inlet rs turbo or xr2i
- WANTED: Drivers side (front) Elec window motor and mechanism
- mk5 fiesta zetec s parts wanted .
- saph 4x4 mongoose exhaust
- Wanted:3dr halfshaft bolts
- L 8 ecu needed !!!!!
- 4 new Yb 2wd head bolts and intercooler rubber spacer
- Mk4 Escort trim parts needed.
- Comp 6 spoke MO's or Mint 3dr rims
- s2 koni adjustables
- little flat steel bracket on 3dr headlights
- Saph drivers door
- wheels for my saph
- focus rs lump wanted
- 2wd exhaust manifold with swan neck and bolts.
- actuator adjuster arm please
- cosworth sharktooh alloys
- mk4 escort dash
- 2wd Sierra Sapphire Cosworth...
- 2wd koni setup for Sapphire Cosworth
- **Wanted Blacktop lifters or Zetec Head asap**
- 3dr cosworth
- cossie oil cap
- Series 2 charge carrier
- Suede momo /sparco/Omp Race steering wheel & Sierra Boss
- 4wd heat soak material behind engine on bulkhead
- mercury grey s2 turbo bonnet
- RST injector lines, RS1600i passenger seat, mk3 tape holder
- koni adjuster key
- **Wanted ASAP 16x 2.0 Blacktop Lifters**
- Headlight protectors
- Dump Valve wanted
- FULL Rs turbo loom needed!!!!
- 2wd head bear or full
- std 2wd engine undertray
- mondeo mk2 esate parts
- WANTED ASAP: 2.0 DOHC alternator
- Wrc or branch exhaust manifold for yb?
- mk1/mk2 fezza
- .63 turbo exhaust housing wanted
- cossie 2wd 3" stainless down pipe in good condition
- cossie turbo unit + rst front mount cooler ??
- wanted ap oganic/paddle clutch
- 2WD Cossie Diff (ASAP)
- need a rad today!!
- Escos crystal/diamond morettes
- t2 down pipe
- L8 daughter board
- 044 fuel pump
- SORTED NOW CHEERS! CVH Bottom Pulley
- WANTED: Saph bits...
- level 6 ecu
- RS500 Front Splitter....
- 3dr cosworth side mouldings
- 2wd Head Wanted (Cash Waiting!!!)
- i really really really really need a turbo!
- std escort cosworth fuel pump wanted
- set of alloys like diamond cuts , softlines , azev or comps etc ....
- Engine stand cheap
- please delete.got one.
- Wanted T5 box
