- 2wd abs sensor REAR WANTED
- 1600CVH Turbo block
- 3 door cossie wheel locks
- mk5 escort heater panel
- 4wd 200 block
- Black FRST Bonnet
- s2 rsturbo window seals
- SIZE 9 OR 10 BAUER TURBO ROLLER SKATES WITH SIMS
- 90 spec windscreen washer bottle
- 90 spec front bumper in white
- s1 rst wanted anywere!
- 3 BAR MAP SENSOR
- mk3 fiesta heater matrix ne scotland
- Alloy Wheels
- WANTED RS TURBO OR COSSIE
- Wanted: Spec R Group A Oil Breather kit new or used
- wanted 4 branch manifold for mk4 xr3i
- jenvy throttle bodies, AP brakes
- lowering springs and blocks needed for my vreg 55 d van
- mk4 escort
- Eibach Sierra Cosworth 4x4 Lowering Springs 25 Or 30 mm
- GTI Side Skirt's
- ap brake kit
- esc cos opening rear 1/4 windows
- rst rad and 194-45-16 tyres
- mk4 escort rear tie-bar
- 90 spec s2 rear spoiler
- EsCoss Speedo cable
- hybrid t38 or maybe t4 wanted
- escort cos front towing eye wanted
- 90spec half leather
- saph nearside amber back light
- mk3 escort smoked rear lights
- no longer need
- 3 DOOR STD HOSES *& MINT STD EXPANSION BOTTLE
- Escort MK4 Horn Wiring
- new wheels
- rs1600i rocker cover
- 3 bar map sensor
- Escort MK4 exterior door handles
- MK4 Escort stereo/ash tray surround
- Few parts wanted
- S1 RS Turbo Wanted
- Momo Arrow 1x center cap
- FRST/XR2i flywheel
- * Escort Cosworth Small Turbo Uprated Turbo *
- ESCORT S2 - CAM KIT
- FRST radiator...
- 3 door cam belt cover top mounts
- Do you want a quick sale before Xmas of your car
- s2 wire loom
- S1 RST Coolant Level Sensor
- t34 for cosworrth 2wd
- s1 chipped ecu and other bits and bobs
- series one running gear!!!
- standard 90 spec front bumper for s2.Will be getting painted
- Front Mount Intercooler esc turbo series 2
- sapphire cosworth 4x4 wanted
- Cosworth turbo heat shield
- Need Superchip Fiesta RS Turbo
- Escort RST Clutch Cable
- SAPPHIRE COSWORTH PANELS & GEARBOX
- 90 spec/fiesta turbo chrome rocker coer
- S1 RST, S2 RST (90 Spec only), Feista RST, 2wd Saph
- sierra cosworth morette headlights
- ESCORT COS BONNET WANTED
- 17" 5 spoke comp mo's
- escortcosworth wanted
- escortcosworths
- Second hand Bailey header tank 2wd or 4x4 Cosworth Sierra
- Black Or Chrome Sierra Cosworth 4x4 Rocker Cover
- very cheap car
- 63 REAR HOUSING wanted !!!
- laguna splitter
- Ford Focus RS Carbon Centre Console
- Cossie bits
- EscCos monte carlo wheel centre cap WANTED
- HELP NEEDED PLEASE !!!!!!!!!!!!!!!!!!
- focus 17" mp3 alloys and tyres wanted.
- Sapphire vents
- escort cosworth front calipers and pads
- Mk1 XR2 Front End Panels (Genuine) needed
- stage 3 chip for 2wd cossie ecu to run greens
- Ford racing boost guage
- N/S electric mirror for T reg Mondeo wanted.
- Sapph Cos, possibly for ST200
- 2wd cossie head
- ESC COS ALLOYS WITH TYRES WANTED FOR SWAP WITH MK 4 ESC !
- 16 in escort cosworth wheels
- scumball '07 car prep.
- Mk 3 Mondeo Black Leather Interior
- Restoration project wanted
- Alloys
- Cossie front bumper
- escort s2 parts wanted
- RS500 Lower boot spoiler
- rs 17,16 diamond cut 7 spoke rims
- cossie bits
- Zetec flywheel
- lowering springs needed (in essex)
- 7" r&d front diff required
- Mk4 Cabriolet doors
- xr3i 90's spce sill cover
- escort cab roof mk4
- escort cosworth replica wanted
- XR2 Steel wheel/wheels
- Cheap cossie/ Px swap high spec RST
- Mk 4 escort master brake cylinder (non abs)
- Escos Nomad rear lights
- Escort MK5 3DR Drivers Door.
- s1 or s2 rs turbo
- NO LONGER NEEDED
- rs turbo wanted any condition considered
- zf diff output shafts
- 90's spec crossover pipe
- S2 throttle body......
- 3dr shell
- Esc Cos / 4x4 Caliper Carriers
- S1 parts & group A alloys wanted!"
- MARK 2 XR2 ROLL CAGE
- Black s2 rs turbo 90 spec spoiler
- MK1 Orion Boot Popper Wiring Loom
- Wanted Scorpion back box/exhaust
- Bells for AP 355 mm
- Mk4 escort ford front wings and front panel
- rs turbo s2 90 spec splitter
- ERST Braided front brake lines
- wanted rear bumper for saf
- adjustable tca (escort mk4)
- auxillary air valve
- Sierra Cosworth 4x4 Exhaust valves
- Fiesta mark 3 - 5
- Centre Cap for 15" GTi Alloy - asap thanks
- Wideband controller - Lambda 02 sensor
- cosworth Exhaust surround
- S1 turbo frontmount intercooler.
- T4 Wanted
- s1 rsturbo grs large intercooler wanted and alloy radiator
- 330mm discs/bells 4x4 cos
- shapire rolling shell wanted
- escort estate mk 3 or 4 WANTED!!!!
- The one who has an ecu 90
- Escort Series 2 Parts Wanted - Mechanicle / Heated Windscre
- WANTED MK1 ESCORT any model
- Origional black speedo clocks and heater controls series 2
- turbo cooler for my three door
- WANTED NOW
- SMALL TURBO ESCORT COSSIE ROCKER COVER
- cheap cosworth ECU
- cosworth inlet manifold
- Tachometer
- S2 90 spec front bumper
- s1 bits and bobs
- s1 rear lights
- xr2 mk2 dizzy
- xr2 exhaust
- escort cosworth radio and cd player
- Escort Cossy Fuel rail piping
- grays for cosworth
- escort RS pillar pod??
- XR2 Turbo
- ESCORT RS TURBO WANTED WHAT HAVE YOU GOT?HIGH SPEC PREF
- escort cosworth - dash top panel with guages
- cosworth to swap for my tt supra
- Erst wheel bolts
- 3 door gearbox cradle
- wanted r&d front diff
- 15 x 8 Compomotive ML's
- Big Spec RS Turbo
- rs turbo uprated injectors
- gear stick gater
- T34
- Escort RS Turbo Loom
- looking for MK2, MK3 fiesta
- 3dR PARTS
- Escort Cosworth suspension springs
- Mk3 XR3/XR3i
- Drivers side 2wd brake caliper front
- bigger brakes 2wd cossy. complete
- Please delete
- idle speed control valve
- Chrome Soft Spoke RS 7's
- rs2000 or gti swap for rs turbo
- cosworth parts wanted
- escort cosworth interior carpet etc
- Cosworth alloy water pump pulley
- wanted escort cosworth replica
- cosworth gearknob
- Series 2 Shell
- erst/frst scotland
- 3 Door Cosworth boot decals
- need T34 .63
- 3 DOOR TURBO HEATSHIELD
- 4wd cos Thermostat housing to Water pump Silicone hose
- External Fuel pump
- beige 701's
- XR2i 8v driveshaft?
- 2ltr mondeo zetec ECU
- rs wheels wanted
- Fiesta XR2i 16V or Early RS1800 Door cards
- xr2i
- rubber boots for tca ball joint (cosworth)
- 4x4 cos adjustable tca's
- T3 turbo wanted
- cone filter for 2wd cossy
- RWD Project - need box and front suspension n steering items
- 18`s to a Sapp
- wanted 3 door cosworth
- performance fords wanted
- 2wd cossie exhaust
- trottle body Focus 2.0
- Mk3 or Mk4 Escort
- si mods
- Wanted mk1 Escort RS turbo for a project anything ????
- cosworth engine management loom (racing)
- RS500 foglight grills wanted
- ERST Starter Motor
- RS Cars wanted wanted ££££££££££££ waiting
- ESC COS / MK5 RS2000 SIDELIGHTS (BRAND NEW) EITHER SIDE
- saff cosworth foglight surrounds
- wanted escort or fiesta rs turbo
- cosworth plenum & throttle body gasket
- Small Turbo Escos Cam Cover Gasket
- ROUSE REAR SPOLIER FOR 4X4 SAPPHIRE
- series 2 turbo about £2300 to spend
- WANTED MK2 XR2
- S1 spotlight lens required
- Mk3 Escort 3 door window seals
- mk3 escort pair of front indicators needed (in essex)
- FUEL FILLER NECK ON S1
- alloys
- 4x4 front quaife diff
- sierra xr4x4 2.9i throttle position senor and airflow metres
- 4X4 Saph gear box surround
- Sapphire Cosworth Spoiler
- Standard Vauxhall CD Player!
- 3 door roll cage
- escos grpa door cards
- frst/erst for around £1500 [NE scotland]
- mondeo st24 wheels
- FIESTA REAR SHOCKS
- cos parts needed
- 3dr bumper indicator clips
- erst/mfi fuel flow sensor
- pre 90 saff back lights wanted
- Cheap S1
- grp a wheel nuts
- need some fiesta si etc mk3.5 subframes..
- 2ltr pinto wanted
