PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 [5] 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. Cosworth downpipe
  2. Fiesta RS Turbo top inlet pipe
  3. mk4 escort lock set
  4. Wanted- standard T34
  5. Mk4 escort non rs parts wanted
  6. Cossie power steering pump and alternator
  7. 3 door front arch liners
  8. Opening Rear quarter windows
  9. escort mk4 bits and pieces
  10. EFI Conversion Parts
  11. rollover spit wanted
  12. ebay sierra xr4i
  13. softlines or diamond cut alloys
  14. pinto turbo engine
  15. xr4i seats wanted
  16. Any Saph Cossies coming up for sale? Cash waiting for the right car
  17. mk1 focus rs gt25 turbo wanted
  18. Gt30 turbo compressor housing
  19. ...................................
  20. .................................................. ...
  21. sierra xr4i wanted
  22. front bumper
  23. 24v BOA or BOB engine wanted
  24. focus chrome rear handle
  25. 2.0 zetec for a mk4 escort
  26. Wanted-Fiesta Mk3.5 Mirrors
  27. 4x4 cosworth steering wheel
  28. Escort Turbo LSD or Quaife LSD for IB5
  29. mk3 fiesta door
  30. escort efi servo to inlet pipe
  31. S2 90spec Spoiler
  32. Bosh 403 Grey Injectors
  33. Cosworth 2wd suspension
  34. Escort Cosworth fuel pump wiring connector
  35. granada 4x4 5 stud hub flanges
  36. Turbo Technics 2.8 V6 parts wanted
  37. Escort Cosworth or Sierra Cosworth 4x4 metal front hub grease seals or possibly hubs
  38. parts
  39. 18" Rondell/Engel 122's wanted, escos fitment
  40. Morette headlights for saph wanted
  41. PF 09 and 3 bar Map
  42. Cheap saph cossie wanted, complete car
  43. Straight cut dogbox for sierra cosworth 2wd
  44. Mongoose for sierra cosworth 2wd??
  45. Sapphire cosworth parts wanted
  46. 17" softline alloys wanted
  47. 3 door sierra cosworth
  48. WRC-Maxi F2 wings/arches
  49. Cosworth Throttle Cable
  50. 1990 Sierra Sapphire bits wanted
  51. 2wd Cosworth Kent cam pulleys
  52. Wanted - Escos throttle cable bracket
  53. Series 2 RST passenger A pillar seal
  54. Heated Washer Jets Sapphire
  55. mongoose 3" or 4" exhaust
  56. Rs500 front/rear screen rubbers
  57. Sierra cosworth 2wd mongoose and oil breather/separator tank
  58. mondeo st200/24 uprated suspension
  59. Mk5 escort boot lock
  60. WANTED Spec-R turbo damper bracket and RS500 damper
  61. WANTED escort PAS pipe
  62. escos alloy wheel
  63. Cosworth cylinder head
  64. Wanted Sapphire cosworth T5 Gearbox
  65. escort mk3 or mk4 3 door shell
  66. 3 door cosworth parts required
  67. efi turbo engine or block
  68. t.
  69. cosworth 4x4 rear caliper carriers
  70. 3dr cosworth parts wanted
  71. brake pipe brackets
  72. escos rear rollbar clamps wanted please
  73. 17's / 18's wanted sierra cosworth
  74. wanted - uprated MT75 box + diff parts
  75. Rs turbo wanted
  76. Std focus rs mk1 turbo
  77. 200 block please
  78. YB 4x4 dipstick
  79. 2wd Cosworth yb throttle body
  80. 2wd coilovers
  81. saph rad fan switch,rs boss,
  82. RS500 lower boot spoiler
  83. WANTED escos steering column
  84. 4x4 Crank & Aux Pulleys ***SORTED***
  85. Mk1 Focus RS wheels
  86. deleted ty
  87. Wanted small turbo escos phase plug
  88. cosworth crank wanted, std, std
  89. zzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzz
  90. Mk1 escort 2 door pins
  91. Mk2 focus rs wanted
  92. Mk1 xr2 driveshafts
  93. Water pipe
  94. cosworth 4x4 3.9 drop gears
  95. escos id
  96. Escort cosworth rear bumper mountings
  97. 1.6 fwd crossflow engine!
  98. Wanted: Tarox RS4x4 front bells and caliper mounting brackets
  99. 3dr sierra shell wanted
  100. WANTED rear caliper braided brake pipes escos
  101. Mk1 fiesta parts wanted
  102. Mf2 5th injector setup wanted
  103. knackered sapphire cosworth front bumper
  104. 3dr cosworth interior
  105. WANTED Carcoon's
  106. ANYONE BREAKING A S2 ERST? I'm Only in the UK till the 23rd & need parts for my car!
  107. WANTED 18" Rondell's
  108. 4x4 throttle body,distributor
  109. turbo hanger
  110. 3dr front and rear bumpers
  111. Wanted 3door or 2wd saff
  112. S2 rs turbo wheels & tyres wanted or xr3i wheels
  113. Stack digital speedometer
  114. good spec cosworth wanted
  115. Escort Mk5 rear lights
  116. lower rear quarter repair panels
  117. Heater motor cover escos
  118. Mk4 escort Cvh top engine mount
  119. knackered 2wd Diff and Cos 4x4 Box
  120. genuine Escos Lambda sensor
  121. Mk1 focus rs front bumper
  122. Wanted 1xM05 wheel
  123. Wanted cheap ford puma
  124. 0.63 exhaust houseing
  125. Wanted RS Turbo bonnet and Bumper. Electric windows
  126. WANTED Escos 4x4 starter motor
  127. Fiesta RS Turbo WANTED
  128. WANTED escos carbon fibre strut tops
  129. escort cos down pipe wanted mongoose etc
  130. Genuine ford mudflaps
  131. Mk1 focus rs bumpers and wings.
  132. Wanted rs 7 16 diamond cut alloys
  133. WANTED Escos rear N/S outer cv joint
  134. Is anyone breaking a mk4 escort estate parts wanted
  135. mk4 escort estate rear bumper
  136. Escort Mk1 race GRP4 parts wanted
  137. WANTED escos power steering pipe
  138. RS2000 wanted mk6
  139. WANTED escort 4x4 centre push clutch conversion
  140. mk6 escort - lowering springs
  141. escort mk4 wings wanted
  142. 3DR Grill Panel
  143. Wanted air con parts escos
  144. Wanting series1 escort rs full loom
  145. S1 aerial bracket
  146. cosworth project
  147. 2wd standard front brakes
  148. Wanted: Cosworth T5 bell housing
  149. Wanting escort mk4 parts
  150. Boa engine WANTED!!!!
  151. Escort RS Turbo 90spec spoiler caps.
  152. WANTED escos 6 degree rear beam
  153. cosworth cylinder head
  154. Cosworth t34 turbo and injectors
  155. escort cosworth front driveshafts wanted
  156. 2WD diff
  157. Focus st170 for sale 90k miles
  158. 3door front grille NEEDED.!
  159. few 3 door parts wanted
  160. Wanted ford racing gauges!!!
  161. WANTED Escort cosworth banana pod screw cap cover
  162. 4x4 rear diff got to be perfect
  163. mk4 escort efi fuel tank wanted with pump aswell if poss
  164. mk4 escort RS bumper skirts wanted
  165. WANTED Black bailey header tank + power steering tank
  166. Mk6 escort sunroof cowling
  167. wanted sierra sapphire or estate
  168. mk4 escort estate parts wanted
  169. cosworth cylinder head
  170. 3 door cosworth gearnob and steering wheel
  171. Rs turbo exhaust manifold and turbo
  172. Nomads for escort rs2000 mk5
  173. escort s2 rs turbo bonnet & cosworth alloys
  174. wanted kit afr
  175. Escort Cosworth & 2wd Parts needed! Fuel Tank, Radiator, Intercooler etc
  176. Sierra Dash vent (Large one)
  177. focus st170 rear caliper carriers
  178. WANTED Escort CosworthPower steering pump & pipes Escort/sierra Cosworth BT
  179. WANTED Escort Cosworth Alternator bracket Escort/sierra Cosworth BT
  180. WANTED Escort Cosworth spare wheel/space saver
  181. WANTED ESCORT COSWORTH tool kit
  182. wanted mk3 fiesta front panel
  183. Escort Cosworth
  184. Cosworth P8
  185. Mk1 Focus RS
  186. S2 shell wanted
  187. Fiesta Rs turbo coil pack / bracket.
  188. Wanted 32x355mm 9inch PCD 12 bolt rotors
  189. 2wd cossie thermostat housing!
  190. WANTED Escort cosworth parts
  191. RS500 lower boot spoiler and splitter etc.
  192. Bucket seat side mounts
  193. A long shot - Saph Cos wanted
  194. wanted t34 or t3 stage 3 for my 4x4 saff
  195. WANTED Escos AIRCON pipes
  196. WANTED Escort Cosworth 7" Rear Diff Quaife ATB/Gripper
  197. Anyone breaking an escort cosworth
  198. Anyone got a 2wd cosworth prop for sale in the essex area?
  199. Cossie 2wd heat shield
  200. few escort cossie parts
  201. WANTED escort cosworth heater control panel **aircon model**
  202. 3 door front bumper
  203. Any one stripping a mk 5 escort need a part
  204. sapphire fogs and surrounds
  205. Wanted standard NSF Wing for Mk1 Escort 2 door
  206. New 4x4 thermostat thermostat housing wanted..
  207. Standard T5 gear knob
  208. Saph cos outer fuse box casing wanted.
  209. Wanted escort cosworth
  210. Some bits wanted for my Rouse
  211. Black Series 2 RS Turbo
  212. sierra electric sunroof
  213. Escos armrest and steering column
  214. Panther black st225 bonnet
  215. got some, cheers.
  216. Mk2 rs2000
  217. Escort cosworth loom
  218. Escort cosworth 18" wheels wanted
  219. Wanted saff cossie boot carpet...
  220. Wanted saff cossie interiors-pillar trims...
  221. rollcage for a mk 4 escort
  222. Sierra gear knob
  223. Sierra Sapphire Headlight Protectors
  224. Mk4 escort green tint opening rear quarter window wanted
  225. MK 4 escort steering boss
  226. Various Saff parts wanted
  227. NOS 3dr ambers
  228. back panel
  229. sorted
  230. Standard size 2wd front dics wanted
  231. 4x4 Cosworth gear lever surround wanted
  232. Escort RS Turbo dress up bits....
  233. Wanted st170 exhaust / px for miltek
  234. Wrc style axle for Sierra
  235. 3 door sierra cosworth
  236. saph cossie 2wd std/or quiet exhaust wanted
  237. Cosworth engine
  238. Saphire Cosworth 4x4 exhaust
  239. Wanted Saph Cossie New / Mint Parts
  240. fiesta turbo speed sensor needed
  241. ......
  242. MTX75 cable shifter Bracket
  243. Saff 2WD ambers
  244. fiesta rs turbo efi tps sensor
  245. Saph Cossie aeroquip bits wanted
  246. Sapphire cosworth spare wheel well
  247. braided rear brake pipes escort mk4
  248. Wanted sierra cossie speedo dial...
  249. .......
  250. Escort cosworth under bonnet sound proofing
