View Full Version : Cars & Parts Wanted.
- 90's spec cabrio half leather rear bentch or whole interior
- erst leather interior, or saff leather front seats
- Xr4x4 Moonstone Blue 24v Cosworth
- 90 spec s2 wtd
- Sapphire Cosworth Interior Parts
- Ford Escort Cossie part ex for golf V6 4motion fsh low mila
- leather needed
- 1988 Sapphire Steering Column Flexible Coupling - pix and No
- looking for a nice spoiler for my MK4 escort cabbie
- Wanted Escort MK3 sunroof
- cvh oil pump
- Sapphire Cosworth Airbox
- Coilpacks
- one or two Compomotives
- 2wd saff cossie Leads
- front shocks spax
- 3dr/RS500 Cosworth Steering rack connector to main collumn
- wanted escort mk1 twin cam
- saff rear bumper
- black 3door mark 3 escort
- mk6 RS2000 alternator wanted
- 4" back box for cossie
- wanted mk1/mk2 escort rs2000 mexico sport harrier
- 3 Door Wanted
- T2 turbo
- Cossie piston
- bare efi frst head
- Fuel and Water temp guages for Escos
- Fiesta Zetec S - Wanted!
- WANTED SERIES 1
- T34 or similar turbof or high spec S2 rebuild
- map sensor bracket
- RS500 spec cooler wanted
- Sierra Cosworth RS500 Intercooler
- Fiesta 16v XR2i or Early RS1800
- s/s exhaust for rs2000 mk 5/6
- 1.6 CVH escort RST STARTER MOTOR with HEATSHIELD!!
- MK6 rs2000/GTI Bumpers
- idle speed control valve for a cossie
- saffy leather.!!!!!
- S2 Escort RST
- cosworth engine management
- New good spec T34 for 4x4 Sapph
- mk2 xr2
- S1 washer bottle rubber seal
- engine needed for MK6 rs2000
- Weber twin 40s, and best place to buy a cam??? advice?
- Wanted: Turbo for 450/500 BHP Cosworth
- Stage 3 efi head needed
- ESCORT/FIESTA DIESEL VAN WANTED A.S.A.P!!!
- mk6/7 escort tailgate & rear bumper
- mk4 cabriolet roof
- st220 parts
- -31 actuator wanted
- mk1 mexico gear box
- 9" diff wanted, 3.9 or 4.1 ratio plated pelase !
- fuel filler neck for mk xr3i
- Escort RS Turbo to swap for R Reg 5dr GTi.
- [Wanted] Escort Cosworth Leather Recaros
- morette quad headlamp conversion for esc cos
- RS FOCUS - P/X For My Escort
- S2 BONNET/ WINDSREEN
- Moonstone or magenta 4x4 Sapphire
- samco coolant hose
- rear strut brace for s2 or rollcage
- MINT S2 TAILGATE
- Sierra cosworth downpipe (old one will do)
- XR2 Wanted
- Front prop shaft wanted Escort Cos
- Mint dashboard
- RS turbo fiesta gearbox wanted.
- HELP need fiesta rs turbo ASAP cash waiting here
- 90 spec LOW MILEAGE s2 wtd
- RS1600I front spoiler
- WANTED: 2.9 24v cosworth engine and loom
- 2.8 capri or 3.0
- Wanted. Original Fiesta RS Turbo ancillary hoses
- S2 escort RS turbo flywheel wanted
- frst wanted, dont mind one needing work
- Cossie 4x4 Front Calipers Wanted
- Wanted - shark tooth alloys
- SECS monitor...
- 7,5" RWD diff, quaife, grippe or similar
- rs500 style intercooler for 2wd saff
- !WANTED! Frnt caliper bolts & Rear ARB bolts
- mirror conduct cap?
- 3dr /500 bits wanted..
- Capri
- steering wheel??
- pepperpots
- Saph Sunroof WANTED
- Starter Motor For Escort Cossie
- series 1custom passenger door
- Recaro seat Diaphragm
- Rear Brake pressure reducer
- 200 block wanted
- esc cos quad headlamps conv........
- mk4 Cabriolet Escort Drivers door req'd Northwest
- Mondeo ST24 Half leather trim wanted
- Found One
- Grey 90spec s2 for swap with my SERIES 1 RS TURBO!
- RS 500 Airbox ,& turbo damper wanted...
- FRST front seats
- SAFF WINDSCREEN WASHER RESERVOIR NEEDED.
- Level 8 ECU
- KA 1.3 Endura Engine URGENTLY WANTED
- 7" rear diff
- Escort rs turbo brake pads..............
- side skirts
- mk3 escort smoked rear lights
- 3dr Cosworth rear quarter window surrounds
- Escort RS Turbo Wanted
- Coilpack leads for Escos
- 2.8i LSD or 3.7 LSD
- Wanted 3dr Bonnet Grill --
- 2wd Sapphire Cosworth wheels
- 195 OFAB CHIP
- Escort cosworth. clear bumper and side indicators
- EEC4 Cossie phase sensor dizzy type driver thingy
- desperate lady gaggin 4 rs2000
- needed quick metering head and injectors
- Headlight duct
- WANTED : 3DR magnex rear box only....
- White sapphire Boot lid
- Wanted Escort Cosworth P-reg
- White 90 spec bumper, spoiler, tailgate and o/s sill - ERST!
- 3dr cossie Parts
- focus rs interior & some other bits
- Rs Turbo Engine, Gearbox and Loom.
- ***2WD actuator bracket wanted***
- wanted rondell centre cap
- 3 door cossie
- cosworth 2wd door side mouldings wanted
- L8 ecu
- Wanted XR2I!!!
- 17" Rondells
- FRST, ERST or ERST cabby wanted...
- 90 spec S2 recaro
- cossie iscv
- RS Turbo T3 Hybrid Turbo wanted
- fiberglass RS 500 front bumper
- frst backbox
- low mileage 1996 fiesta rs1800/turbo or mk6 rs2000 (2wd) wtd
- Escort RS Turbo Engine
- wanted series 1
- ERST or WHY-=swap for my cabby *pics added
- Escrot Turbo Interior Choke Blank
- ST170 Gearbox
- Wanted Escort cosworth imp blue FOUND ONE THANKS
- Zetec DCOE manifold
- Mk1 XR2/Ghia
- Sierra sappire cozzy 2wd in magenta or crystal blue
- Escort Mark 4 rear bumper
- diff wanted lsd
- S1 chassis legs
- Cossie Wanted
- rst wanted swap for
- ESCORT MK1 OR 2 WANTED
- series 1 trim
- ESCORT RS COSWORTH
- Stage 2 hybrid Wanted
- Cheap mk2 xr2 northwest
- ** Xr2i 8v Bottom Rad Hose ** Urgent **
- Escort RS Turbo Centre Vents Gauge Pod Wanted
- [Wanted] FOCUS RS Turbo Manifold
- TYRE X1 225/40/18 N1 88Y MICH/PILOT/SPORT FOCUS RS WANTED
- Cossie engine and box required
- Gearbox Mount & Gear Linkage for S2!
- 2wd stainless steel exhaust system wanted.
- rs 7`s diamond cut
- Escos rear arb
- Diff wanted
- compomotive mo's 17"
- fiesta xr2
- cheap!!! esrt,frst,saff cossie flywheels wanted
- injector pipe wantd
- 2 escos relays wanted
- Help !! More S2 Parts Wanted
- saff cos twin headlamps
- EFI fiesta turbo block
- Wanted,Rear spoiler....
- 2 Bar MAP sensor wanted
- Saff cossie bits, boot, spoiler, bonnet etc...
- 330mm rotors
- RS2000 mk6
- stack dash wanted
- fronh hubs
- 2wd magnex
- S/S exhaust for 2wd cossie to swap!!!!!!
- Series 1 parts wanted
- cosworth block
- RS 500 bits...
- wanted mk2 escort
- Cossie Webber FPR
- mk2 escort bits
- escos spoiler add on
- Big 4wd Brakes
- fiesta rs1800 inlet manifold/throttle body
- series 1 bumper end caps
- Cosworth weber FPR
- s1 turbo....or rs1600i
- Cosworth 4x4 calipers and carriers
- stage 2 hybrid
- WANTED : OLD SKOOL
- Adjustable Vernier pulley
- Standard Cossie Cam Sprockets ***Cheap***
- ERST chipped ECU
- Escort RST Swirl Pot
- poly bushes front only wanted
- S2 90 SPEC PARTS WANTED
- Stainless Exhaust For S1 Turbo
- focus rs alloy
- cosworth 4x4 starter motor
- Wanted 3DR door rubber strips....
- Wanted 3dr abs ecu
- RS500 Inlet plenum (sp) cash waiting
- fiberglass rs500 front bumper, whaletail etc
- S2 Suspension
- Fast Ford Mag
- White 3Dr RS 500 Grille , Fibreglass bumper & Bonnet wan
- escort rst injector pipe needed
- Green injectors required please!
- WANTED Strut Brace for Capri
- Fiesta RS1800 or Turbo
- ford probe
- Saph coss recarro head rest
- 4x4 rear calipers
- MK2 Fiesta red bootlid
- S2 RST Pro Alloy radiator!!
- 3dr front hubs
- Standard Mercury Grey Series 2
- T4 and grey,s WANTED
- escort mk1 rs2 or mex wanted
- parts wanted for sapphy cos
- XR4i rear drums and backplates
- anyone got a 1.8 cvh sierra for breaking i need
- st170 or cossie 4x4 front brake set up wanted!
- s1 bottom rad hose needed!!
- 2wd alloy header tank
- Chrome roll cage MK5 Escort
- Standard S2 Head wanted
- Airbox for Small turbo Escort Cos
- RS Steering wheel Wanted
- We want your FORDS.... Any crash damaged/insurance
- drivers side rs turbo jacking cover
- Escort S2 RS Turbo Wanted (Found One )
- EECIV throttlebody wanted.
- new or recently rebuilt s2 rs turbo bottom end
- p8 ecu
