PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 [81] 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. 5th Injector Controller
  2. board
  3. s1 boost hoses
  4. ERST Roll cage wanted
  5. stage 2 box for rs turbo
  6. level 8 standard ford board
  7. Small Turbo Escort Cosworth Ecu
  8. lock set
  9. gauge holder
  10. facet fuel pump
  11. BLOWJOB
  12. t4 size air filter (75mm?)
  13. S2 ERST Radiator
  14. 3 dr bits
  15. mk 2 escort needed
  16. t3 turbo exhaust elbow
  17. Carbon fibre doorcards
  18. s1 boost hoses
  19. Wanted Fiesta Rs - Or Escort Turbo for Saff Cosworth
  20. 4x4 thermostat housing
  21. fiesta mk 3.5 wingmirrors
  22. 3 door cosworth air scoop????
  23. escort rs turbo s2
  24. BLACK GLOVE BOX HANDLE. 4X4 SAFF
  25. WANTED rear shockers for series 2
  26. wanted 3 dr cosworth
  27. 4x4 rear drive shafts and exhaust
  28. BRACKET
  29. Wanted, De-cambered/lowered Leaf Springs
  30. door strips/mouldings
  31. RST Gearbox in ESSEX
  32. escort rs turbo engine
  33. S1 Adjustable Tie Rod Bushes
  34. wanted s1 boost hoses
  35. WANTED 3DR!!!!
  36. wanted cabriolet somewhere near kent..
  37. good viscus coupling for 4x4 cos
  38. BRAKES!
  39. s2 rst top silicone boost hose
  40. ************LOOK************************
  41. silicone hoses, front mount and ras
  42. WANTED URGENTLY PLEASE HELP!
  43. S1 Thermostat Housing
  44. Mk4 Escort Shell
  45. £500 reward for tracing stolen parts
  46. mk 2 xr2
  47. Cosworth T3 bearing housing
  48. efi parts and s2 bonnet
  49. Air box top
  50. 2 or 4wd i/cooler needed
  51. COSWORTH VALVES
  52. is there a xr2i out there for me
  53. pair of Cossie 2wd front struts
  54. Cosworth 4x4 intermediate shaft housing.
  55. Focus RS parts wanted
  56. wanted t3 turbo arouned birmingham
  57. 3dr bits needed please
  58. Wanted Cortina MK2 Bonnet
  59. Stone deflector wanted
  60. Rouse sport seats
  61. anti roll bar
  62. RS1600 or RS1800 ESCORT
  63. MK3 Escort Tailgate.
  64. RS Turbo wanted in exchange for Cosworth
  65. RS Turbo in North East
  66. Escort mk5 trim
  67. black Rs dash pad ( ecu cover)
  68. Cosworth Fog lights and indicators
  69. WANTED ALLOY WHEELS
  70. escort coswort
  71. Need 2 4x4 Cossie front cam caps.
  72. xr3i, rs2000, ghia etc clear bumper indicator (mk5/6)
  73. Wanted, Mk3/4 Gearknob
  74. wanted 4wd gearbox for big power esc cossie
  75. 3 door wanted/swap or p/x my saff
  76. wanted 2wd saff or 3dr
  77. abs sensor
  78. Metal water hoses for series2
  79. flexi for magnex rs turbo wanted
  80. after a fu***d t5 gearbox
  81. bonnet vents
  82. Saph Cosworth Rear Bumper
  83. 3dr Cosworth Bodykit Arch Needed URGENT!!!!! (Drivers Front)
  84. s2 alloy wheels
  85. wanted.. big disc and calliper conversion for S1..plz
  86. escort s2 rst headlamp protectors
  87. WANTED QUAD LIGHTS
  88. S2 RS Turbo to break
  89. Sierra Cosworth heat shield and uprated rad
  90. Chipped ECu for ERST
  91. moonstone 4x4 bonnet an osr door wanted
  92. focus smoothed boot/tailgate
  93. series 1 roof lining
  94. fuel pump carrier S2
  95. brakes
  96. Saph cosworth 4x4 gearbox
  97. exhaust wanted
  98. RST Lsd Gearbox and Uprated Shocks + springs
  99. EFI Inlet...
  100. exhaust wanted
  101. Microcat
  102. Wanted!! escort rs s2 parcel shelf + dump valve siliconehose
  103. Series One Parcel Shelf
  104. wanted t3 turbo birmingham area
  105. Escort Cosworth Carbon Fibre Heatshield & Cam Belt Cover
  106. SERIES 2 RS TURBO WANTED!!
  107. URGENTLY REQUIRED - GEARBOX FOR 2.0 16V ZETEC FIESTA MK3.5 !
  108. Paddle clutch for RS Turbo
  109. P/X SERIES 2 RS TURBO FOR MINT VAN FOR CARRYING M/X BIKES??
  110. Series 2 Escort RS Turbo
  111. who was selling turbo cabby
  112. P8
  113. wanted series 1 rs turbo may px ...any condition
  114. efi fuel pipe+90 spec rocker cover
  115. CAR Gray 90's spec ERST in essex
  116. wanted URGENTLY - 1.25 zetec engine
  117. Escort Cosworth Kick Panel Trim
  118. cossie front bumper
  119. turbo damper
  120. knob that releases the seat forward
  121. seek a new DONUTS for sierra cosworth 4x4
  122. Wanted Ford Orion mk2/Escort mk4
  123. Cosworth fan holder thingy on rad
  124. 2 WD Bilstien Coilover Casing [front]
  125. 3 door windscreen
  126. Escort Cosworth Boot Lid
  127. Rev counter for a 3 door.
  128. S1 fuel pump relay???
  129. wanted fu**ed escort turbo t3 for parts/echange
  130. wanted good t3 escort turbo complete
  131. WTD: Fuel Pump
  132. Wanna Swap Red magnacore KV85's For blue
  133. Escort Mk6 3dr 1.8 - low mileage, no rust
  134. Sorted now
  135. P8 Escort Cosworth Stage 3 Chip
  136. universal sports cat, 2.25" diam
  137. S/Steel exhaust system for RS2k mk6 !
  138. fiesta turbo ACT sensor wanted
  139. Saff Cos Drivers Door
  140. speedo cable and clocks
  141. XR2i - Manchester/Northwest area
  142. YB CRANK needed
  143. BAILEY OIL BREATHER NEEDED
  144. i need an engine
  145. escort cosworth Shell Wanted
  146. fuel injectors
  147. 2ltr pinto engine
  148. S2 HYBRID TURBO
  149. lambda
  150. Car Under £100 - Anything Considered - Charitable Cause!
  151. Fiesta RS Turbo Bottom End
  152. Looking for some parts for my S1
  153. Piper or Kent cam kit for RS2000 MK6 needed !
  154. Uprated inlet manifold for RS2000 MK6 needed !
  155. s2 erst lightened flywheel
  156. LHD 2WD STEERING RACK AND rally adjustable brake peddle box
  157. parts needed!!!
  158. S2 erst 88spec front windscreen
  159. DTM Mirrors
  160. Morette Headlights for Sierra Cosworth 4x4
  161. wanted escort cab i got a mondeo si to trade in
  162. Saph Cosworth wanted may px
  163. Sports Catalyst for MK6 escort RS2000 !
  164. S/S Exhaust system needed for RS2000 MK6 2wd !
  165. 2wd Cosworth Rolling shell
  166. Sapphire Cossy N/S Rear Driveshaft, 2WD or 4WD
  167. cosworth wanted £6000 sat waiting
  168. mos
  169. Pace CC
  170. Swop/px/sale for Subaru Impreza WRX (s1 or s2)
  171. Wanted: Escort Cabriolet shell [mk3/mk4]
  172. S2 BODY KIT
  173. mk1 fiesta panels
  174. Bailey PAS Tank
  175. rs boss to fit s1 and non horn rs centre
  176. stage 3 hybrid t3
  177. 2wd anti rattle clips
  178. Wanted Throttle body cossie and 2WD cossie loom
  179. T3 Turbo wanted
  180. RS2000 mk6 modified manifold needed !!!
  181. Wanted - RS1600 or RS1800 Escort
  182. Esc Cos Bosch Fuel Pump 0580 254 003
  183. 4wd cosworth flywheel ring gear
  184. Brand new Kent or Piper fast road cam kit (and vernier)
  185. after a xr3 gearbox in essex!
  186. T4 comp housing etc
  187. RS2K wanted
  188. s2 escort rst shell
  189. 3 door front
  190. RS 500 FUEL RAIL
  191. MK 3 escort xr3 or 3i
  192. Bottom end prefebly a ZVH
  193. Getrag GpA rwd gearbox needed
  194. Ford Escort s1 body kit
  195. Sierra Gear knob
  196. 1 x S2 RST Jacking point cover
  197. 3dr/ RS 500 Race car , complete or just bits
  198. MK4 Escort XR3i Inlet manifold (non EFI)
  199. big valve head efi stage 3
  200. fiesta body kit "cosworth"
  201. s2 rs turbo wanted
  202. Saph cosworth front jacking point covers.
  203. front diff
  204. Rocket gearbox
  205. opening rear quarters from mk3
  206. speedo surround
  207. Escort Mk5a Rear bumper
  208. Rondell/Engell centre caps
  209. Needed, superchip, or engine management upgrade 4 1992 RS2k
  210. momo arrows 17 inch
  211. s2 rst rear suspension bits
  212. No longer wanted
  213. Coilover Helper Springs Wanted
  214. twin headlamps,4x4 bonnet,rear bumper wanted saff
  215. COSSIE FRONT BUMPER
  216. s1 full kit
  217. alloys to fit saph cos 16'' or 17'' or px my st170 wheels
  218. 200 block bottom end or engine
  219. wanted s1 rad and escort cab passanger door
  220. for cosworth
  221. *Mint* s2 tailgate...and ...Rollcage
  222. 3dr wanted at the end of the year
  223. Xr3i Alternator
  224. T2 Manifold...
  225. T2 Turbo elbow...
  226. mk4 cabby needed for cosworth project
  227. FRST head rest x1 or pair
  228. tt kit for xr2
  229. mk2 xr2 wanted
  230. COSWORTH 200 BLOCK
  231. es cosworth panels
  232. ser.2 T.3 turbo
  233. fiesta turbo bits
  234. 4x4 Bits wanted
  235. wanted mint or new 17" rs 7 spokes
  236. cosworth Side Exit Exhaust
  237. 2wd Cossie rear beam
  238. Wanted Mk4 Escort Headlight protectors
  239. sapphire cosworth wanted
  240. Wanted !!! mk2 fiesta, with rs enigne etc!!!
  241. Another Cabriolet wanted
  242. MK4 ESCORT original JACK
  243. t34 hybrid rear housing
  244. brembo
  245. Touch up paint
  246. Rs Turbo Vents
  247. helpp.... in need of one of theese..
  248. mk6 escort
  249. 4x4 cosworth front calipers
  250. Escort Cabby ..
