View Full Version : Cars & Parts Wanted.
- 3dr oil breather system
- Mk4 Fiesta looking for a new 1.25 engine
- broken T5 or MT75 gearboxes needed for spares
- 2 x Mondeo wheels/tyres
- fiesta si parts need asap
- escort/sierra cosworth replica/copy
- 3door cos. wheels wanted. w/wo tires, good condition NORWAY
- crank pulley
- Escort cosworth coilovers
- every thing to convert a fiesta turbo to t3
- RS2000 1995 onwards WANTED
- S1 Over riders
- 2wd saph cossie brakes
- speedo drive for a T5
- Saff boot catch
- 2WD cossie fuel cap and key
- Escort Mk6 Amparo Blue 3 Door
- escort rs cosworth parts
- mk5 escort rs2000/cosworth lights
- S2 ambers side reps and front indicators
- S1 Rear Gearbox Mount needed......
- wanted escos lowering sprigs
- escort cosworth parts
- 2wd sapphire bits wanted...
- RS1800 boot badge
- 2WD Brake master cylinder and brake fluid reservoir
- Escort cosworth speedo clocks.
- 2wd cossie parts
- escort cosworth side lights needed
- 2wd cosworth heatsheild (standard)
- Red Rs Escort RS Turbo Rolling Shell
- OFAC chip wanted
- cosworth coilpack HT Leads
- capri
- paddle clutch cvh
- Wanted - T5 Gearbox + prop..........
- FRST OFAB EDIS + Map Sensor
- Escort RS Turbo Bonnet Vents
- 3 Door Cosworth Wanted
- 17" rs 7 spoke diamond cut alloy wheels wanted
- Cossie crank sensor - damaged or WHY?
- PACE intercooler
- XR2 Pepperpot
- wanted 3 door rear arches
- Steering wheel boss kit for Sierra
- escort mk4
- s2 rad, uprated intercooler and few other bits
- 909 Parts
- 2wd cossie exhaust
- RS Turbo Brake servo fluid reservoir
- weber marelli l8
- rs turbo pistons 0.5-1.0 oversize
- cosworth strutt brace
- escort cossie headlights
- 200 Block
- Cosworth 2wd sump...
- 2wd coilovers..
- ecort cosworth heatshield
- mk 5 bits
- mk 5 bits
- 4" Mongoose For Saff 4x4.
- Nice set of standard wheel nuts for a Cossie
- st170 focus 2004 catalitic convertor.
- mk4 escort roll cage
- AP 4 pots for 330 x 32MM Discs
- ford 55mm throttle body and maf of a mondeo si
- Tubby exhaust housing
- 2wd saph cossie fuel tank
- bias pedal box
- Wanted!
- few mk5 escort xr3 bits needed
- Sierra Cossie 2WD Intercooler
- Mk II Escort Wanted
- Cosworth Fuel Pump Cradle
- 4x4 Cosworth Front Hubs
- wanted s1 rs.
- Rs turbo full loom
- s1 full body kit
- Fiesta Rs Turbo
- CPS Bracket
- Saff Twin Bar Strut Brace & Vent Cover.
- L6 2wd ECU wanted
- Wanted Outer Lens Morrette Headlight
- cosworth 4x4 gerabox
- Escort SI Alloy needed
- frst block
- Intercooler to TB Blue Samco Hose
- 3 door project
- 3-dr cap lock
- any uprated 2wd beams out there?
- 2wd gearbox
- ESCOS ARB
- S2 Parts. Intercooler, Gearbox, spoiler, Samco's
- standard escort turbo and manifold wanted
- escort cosworth bits
- 2wd bellhousing
- Weller, comps, revs anything oldschool 14" and above
- corbeau side mounts
- radiator needed asap !
- frst wheels steering wheel and centre console
- escort rs turbo wanted
- Grey injectors +GT30 or T4 Turbo
- Saph fuel pump mount
- Please remove
- 2wd Cosworth 3" rolled out Backbox
- fiesta van wanted mk3
- Greens and stage 3 chip for t34
- RS turbo engine
- xr2i 16v wanted
- b5 gearbox needed asap!!
- turbo heat shield wanted
- Need a power steering pipe
- 16" mondeo 5 spoke alloys
- Escos Wanted
- frst wheels wanted
- stil auto alloys
- -60mm springs for mk6 escort
- Small turbo cam cover
- wanted new car cheap run around
- wanted saphire cosworth
- rs turbo radiator
- alloys
- A Diesel/LPG Car with loads of Toys for £3500
- mk1 fiesta
- Fuel pump cradle
- cosworth front pully crank bolt
- Chip wanted rs turbo
- Rs turbo actuator
- FRST Driver Door
- Cosworth T34 .48 housing wanted
- Ford 2008 Head unit (Later type)
- Mint mkv RS2000
- fiesta rs turbo coil springs
- 1 15" diamond cut rs 7 spoke
- 3 door cage
- Red 90 Spec Escort turbo Boot Spoiler
- s2 rs turbo new cam wanted
- Focus RS engine..
- 2wd saph stainless zorst needed
- 2.8 capri single rear leaf springs
- 17 inch split rims Wanted
- BOSCH green top injectors wanted please
- WANTED-4x4 Engine
- 4x4 saph cos driveshafts
- Spotlight brackets (Accessory ones)
- alloys! CEC129
- RS500 Airbox (Lid) and Boost Hose
- 3DR Front bumper in white , Tatty or need paint !
- RS mudflaps, What you got?
- wanted:ford racing gauges boost water temp
- series 2 wanted in bournemouth
- Ford 6000 cd player
- P8 ECU
- Escort Mk5 Bits Required....
- fiesta rs turbo
- Rs Turbo Rear Box *wanted*
- Rs Turbo Chip *wanted*
- RS 7s 16'' Centre cap
- Escort or 4x4 Cambelt Cover Mounting Posts
- 15" mondeo steelies and standard escort mk4 bonnet..
- Pace intercooler
- Wtd: T5 gearbox for 2wd cossie...
- 3 door wheel wanted
- Rs500 Fuel Rail And Throttle Body
- Cossie Large K&N
- koni shockers
- some stainless parts for 2wd saph
- series one injector
- Speedo cable
- wanted mk6/7 1.8 diesel gear box ASAP
- Late escos inlet plenum
- wanted a series 1 or 3 door sierra cosworth
- 2wd saph parts needed
- S2 ERST bottom end wanted
- wanted escort door lock connectors
- rs 1600i rocker cover
- cosworth valves
- External waste gate
- Sapphire front bumper
- Saph washer bottle with or without pumps
- rs1600i steering 3 spoke steering wheel
- Header tank.
- S2 RST Washer pump
- Cosworth 2wd steering joint
- Escort Cosworth
- Fiesta Rs Turbo top hosing wanted!
- Mint 2wd Standard Red Rocker Cover
- R5 GT T actuator wanted
- exhaust housing and radiator........WANTED!!!!
- 3DR Washer bottle
- Escort cosworth tuning parts. t25
- Escort mk4 windscreen pref heated any considered
- escort cosworth centre console
- dont need
- oil pressure, oil temp & boost gauges
- 2wd idle screw
- Deep dish alloy wheels for a 3 door.....
- Escort Cosworth Racecar wanted
- wanted fiesta turbo head
- Wanted: Focus RS with engine problems...
- uprated intercooler and radiator s1
- Alloy Wheels Wanted Too Fit Saph Cosworth
- bailey oil breather
- 15 ich 4 stud fittin steels wheels
- mt75 Gearbox reverse switch
- Series 2 / Mk4 Escort Tailgate
- Micro Dynamics EMS5
- Dark greens (803's)
- clifford concept alarm siren
- metering head
- rs rear spliter
- cosworth dash
- Escos airbox (LT)
- rs2000 steering wheel mk 6-7.
- wanted focus rs parts
- Genuine 3 Door O/S Front Wing
- Fiesta mk2 1.4s - Black
- -31 actuator and standard cossie fuel pump
- RS turbo cooling fan needed in scotland ASAP
- Series 1 alloy rad
- white dials escort mk4
- Cosworth Airbox: UN-MOLESTED! FOR UNIVERSITY DISSERTATION
- 2wd cossie wanted anything considered
- red turbo bonnet and central locking motor
- AP Racing pads
- 15 inch alloys...
- A good cheap runabout under £700 or under
- 2.0 mondeo ecu
- Coswoth clear indicators
- Few cosworth parts
- cossie morrette ns headlight
- wanted cosworth crank 200 block
- cosworth 4x4 front pulley
- frst fuel pressure regulator wanted
- 90 spec charge pipe.
- sapph cossie anti rollbar brackets needed
- cossie dump valve needed
- 2wd cosworth engine
- Escort RS Cosworth Monte wanted
- 52mm gauges wanted various ie boost/water/oil/volts/afr plus holder for dash
- Ford Racing Gauges
- Mk3 XR3i Parts Needed
- 8 inch wheels for a Sapphire - for racing
- s1 rear lights+other bits
- Mongoose 4wd sierra cosworth system
- 'sapphire' badge 'ford' badge
- rst series 1
- Focus 1.8 black top zetec engine
- escos
- Esc Cos Standard Rear Lights (Still after some please)
