PDA
View Full Version : Cars & Parts Wanted.
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95
  1. BD14 cams 4x4
  2. does anyone have a spare reverse switch for a t5 box?
  3. 2wd saf cos rad needed
  4. Cheap Air saw
  5. 2wd saf cos rad needed
  6. Genuine Ford New O/S saff wing moulding
  7. Ford racing gauges (OLD STYLE)
  8. Sapphire N/S Front Bumper Bracket
  9. 4x4 prop
  10. Reciprocating saw
  11. big power saff wanted 2wd prefered
  12. mk5/6 rs2000 exhaust
  13. saff cos moretts
  14. saphy windscreen washer bottle and pump's
  15. Escort Rs Turbo driverside drive shaft
  16. cosworth 2wd engine
  17. FMIC for FRST -
  18. transit sized van
  19. 3dr electric window switches
  20. FRST T3 Exhaust system
  21. fibreglass rs500 lower spoiler
  22. 2.0/2.1 Zetec Turbo Bottom End Wanted
  23. 3dr windscreen and rubber
  24. escort rs turbo engine
  25. 90 spec s2 bumper + tailgate
  26. 15" steel wheels
  27. Sapphire Cos 4x4 exhaust hanger needed
  28. 4x4 cozzy suspension wanted
  29. yb parts needed for my rebuild
  30. Scap sierra gear box
  31. 88 spec rocker cover erst
  32. 2wd cosworth crank pulley v belt
  33. wanted RST adatper plate MFI to EFI
  34. Cosworth 3dr bumpers
  35. Shell
  36. abs sensor
  37. 2.0 zetec cams and cossie .48
  38. 3dr sierra kit panels
  39. 044 fuel pump
  40. Wanted L8 ecu
  41. WANTED drivers door XR4x4,Help
  42. 2wd Sierra Cossie Front Discs
  43. In-tank fuel pump for a 1990 e30 325i sport
  44. MK1 Sierra 3door or MK1 Sierra XR4i Rolling shell or complete car.
  45. cossie fuel pressure reg dead or alive
  46. mk3 escort / s1 front bumper
  47. sorted
  48. Standard 3 Door exhaust
  49. focus st 170 exshaust
  50. raceline 17'' gold
  51. escort cosworth big rear brakes
  52. Mk6 RS2000 Side Skirt Jacking Covers
  53. fiesta quad lights
  54. Still needed cossie breather & dipstick....
  55. cosworth idle control valve
  56. Water sensor for a 3 door Cossie
  57. 2wd oil pump and pick up needed asap
  58. 90 spec series 2 front bumper
  59. focus rs caliper, and cheap 17's
  60. sapphire morrette headlights
  61. escort mk6/7
  62. 2.0 zetec cams
  63. 205 45 16 tyres wanted
  64. Cossie parts needed...
  65. 4x4 cossie front shocks and RL7 centres caps
  66. Need a mint!!!! sunroof for series 2
  67. fiesta rs turbo rad
  68. Genuine RS500 Intercooler
  69. zetec flywheel bolts
  70. series 2 radiator
  71. 1 x 1mm Oversized 4x4 piston
  72. escos rear quarter pop out glass!
  73. RS Turbo rear coilovers
  74. anyone with a damaged 4x4 cossie bonnet ???
  75. trouser to manifold bolts
  76. Need roof skin for rs....help.....
  77. GGR header tank
  78. lifting eyes
  79. Wanted: Cheap diesel snotter - must be road legal :cry:
  80. Silicone hoses
  81. series 2 90spec exterior parts
  82. Honda civic rear bumper black 1997 3 door
  83. 3 door parts wanted
  84. Wanted Escort GTi/Si Front Bumper
  85. Sorted
  86. escort cosworth 7-10k why ???
  87. yb/pinto pistons wanted
  88. 2wd cosworth pick up pipe and spray bar
  89. cosworth 2wd header tank[mint]
  90. N95 Nokia
  91. 2WD Cosworth Uprated Front Brake Kit
  92. ERST S2 Cam Pulley
  93. cosworth oil breather
  94. recaro seats
  95. 3dr cosworth cage
  96. That door open/lights on/ warning lamp thingy for a 3 door
  97. escort rs turbo radiator wanted!!
  98. sierra cosworth 2wd front discs
  99. Wanted map sensor
  100. L8 Standard Ford baby board
  101. sierra bumper fixings (for 3 door coz/normal sierra)
  102. mk1 fiesta parts, and cvh coss management parts
  103. Mk5 Shifter and CVH Cambelt Cover
  104. Fiesta RS Turbo Boost Hose
  105. 1 x Mondeo 5 stud alloy wheel wanted
  106. Cossie turbo damper
  107. mk1 fiesta parts
  108. wideband controller and gauge
  109. Lower splitter
  110. Cheap 4x4 Cam Belt cover
  111. Stupid little glovebox clips
  112. 4wd Cossie rear diffs
  113. Sierra clocks and 3dr/xr4i clock surround
  114. mk3 escort/s1/orion ghia/xr3i central locking door solenoid
  115. RS1600i front spoiler
  116. RS Turbo Piston Wanted
  117. Sierra washer jet
  118. 4x4 saph Front Prop
  119. WANTED: Saph cossie headlight glass
  120. zetec black top baffled sump + oil pick up/ dipstick
  121. s1 vibratechnic gearbox mounts
  122. escort mk5/6 cosworth door rubbers
  123. standard L6 ecu wanted
  124. 2wd saph breaking
  125. Wanted escort rs turbo parts.
  126. OZ F1 Cup Racing alloy
  127. cvh efi engine
  128. 2wd sierra with 200 block
  129. 2wd Cos parts
  130. s2 rst shell
  131. rollcage for erst
  132. door striker bolt. plus door plate
  133. Genuine RS500 Intercooler.
  134. Ofac ecu wanted
  135. Small turbo escos cam cover
  136. Wanted T4 Turbo
  137. zvh engine
  138. WTB: Small Air Compressor (6 litre preferably)
  139. light blue injectors
  140. yb 4x4 1mm oversize piston
  141. Scrap 3dr loom
  142. EFi ECU
  143. standard 2wd front springs
  144. swedish inlet wanted
  145. wanted 2wd coilovers
  146. 2WD T5 Speedo Drive
  147. cosworth idle controle valve
  148. Escort Rs turbo S2 Injector Clips
  149. rs turbo escort 60mm lowering springs wanted or swap for standard height springs!!!??
  150. 5 k wanted .............
  151. Focus RS Power Steering Pump Bracket - Urgent! Cash Waiting!
  152. Door card
  153. bailey dv top niple thing 90 degree one
  154. wanted frs !
  155. mk5 rs 2000 shell wanted?
  156. sorted
  157. compamotive mo 6 spoke
  158. .48 exhaust housing or Cossie in good condition
  159. front mount intercooler
  160. Saph cossie corner window pieces
  161. Couple little escort rs turbo bits needed
  162. Mig welder
  163. bd10 exhaust cam
  164. 4x4 Front Hubs & outer CV's
  165. Faulty or not working focus m1 speedo
  166. wanted escos cloth front and rear doorcards
  167. Defi white 60mm EGT gauge
  168. Series 2 crank (1986 onwards).
  169. Wanted cobra evolution seat/seats
  170. does anyone have a good 2wd flywheel?
  171. roll cage / safety cage for saff cosworth
  172. Rondel alloys
  173. Mk3 front indicators clear
  174. All sorted now!
  175. Good .63 exhaust housing
  176. Escort Cosworth Big Turbo Air Box
  177. 2WD Thermostat Housing
  178. -10 Aeroquip fittings & -10 Braided Hose
  179. level 6 ecu and greens
  180. big brakes AP ETC ETC
  181. ford 16" alloys
  182. Baileys Header tank cap for s2
  183. 2 Matching Dump Valves Please
  184. Help - Found what I wanted.
  185. frst ofac map sensor and frst air temp sensor
  186. 2wd saff rolling shell.
  187. s1 rs turbo radiator
  188. rs turbo or cossie
  189. wanted....rear arch liners for a saff
  190. Mig welder
  191. Wanted: mk3/mk4 escort gearbox/clutch components....
  192. Ap racing clutch kit
  193. Cts cvh gearbox
  194. fiesta rs turbo magnex exhaust for T2 turbo
  195. WANTED: saph rear bumper!
  196. crossmember for 2wd sappy-GOT ONE NOW
  197. Any1 breaking a mk1 4i
  198. cosworth n/a inlet manifold ??
  199. cosworth bias pedal box
  200. 3dr rubber.
  201. escort rs turbo series 1 header tank wanted!
  202. rs turbo bonnet
  203. Turbo damper for cosworth
  204. BRAND NEW -31 Actuator for T3
  205. damaged,rotten 4x4 saff bonnet
  206. series 1 roof lining
  207. Desperate need of mk 4 grey door
  208. koni 4wd suspension wanted
  209. 0.63 housing
  210. Gunson Fault Code Finder
  211. escort rs turbo grs intercooler
  212. wanted, FOCUS RS FRONT BRAKE FLEXI HOSES
  213. mk5 escort 3 door rear quarter panel!
  214. FRS Conrod
  215. Fiesta mk5 zetec-s standard exhaust
  216. mk3 xr3 bumper plastics + rear spats
  217. rs turbo baileys header tank + breather
  218. Bits for a 2wd saph
  219. -8 fuel hose
  220. want electric windows for saph front and rear
  221. RL7's 17x8 racelines wanted
  222. focus rs caliper
  223. 2wd saph headlining & c pillar trims
  224. Front passenger side jacking point cover wanted!
  225. mk2 golf gti 8v 3dr...or mk3 xr3i
  226. s2 water inlet pipe
  227. biger beakes for s2
  228. 17" Rs Turbo Alloy Wheels
  229. Fiesta RST Door Locking Mech/Motor
  230. micrometer wanted
  231. wanted set of 4x4 cossie pistons, .25 .5
  232. wideband lambda, 4x4 inlet or sweedish
  233. moonstone saffy
  234. Has anyone got a 90spec xr3i seat ?
  235. wanted urgently ------
  236. 70mm 304 stainless tube....Wanted :)
  237. mk6 front bumper wanted
  238. Wanted set of compomotive mo or similar...
  239. Snap off steering wheel boss
  240. garratt -31 actuator
  241. 3 Door Loom
  242. cosworth alternator heat sheild
  243. escort mk4 g max shocker
  244. sorted
  245. Leather n/s/r side piece- saph
  246. 3 bar map sensor
  247. 3dr cosworth heater fan guard and guard from engine
  248. rear 4x4 shocks that are ajustable at the bottom uprated
  249. escort cosworth scuttle panel/wiper arms
  250. 1.8 black top zetec engine
