View Full Version : Cars & Parts Wanted.
- fiesta ST rear bumper and alloys
- big brakes and suspension for e40 compact
- rouse splitters
- T5 bellhouse/Outer flange for 2wd driveshafts
- fiesta turbo iat sensor
- NSR brake drum & master cylinder
- T34 water pipes
- Escort rs turbo reverse switch.
- powersteering hose (2wd saph)
- Golf mk4 DUW gearbox 1.4/1.6
- Fuel pump non rtn valve and banjo end fitting
- 3dr steering coupling(knuckle joint)
- ERST bottom end, T3 oil feed union
- Steering coupling(knuckle joint) for 3dr
- Needed s2 gearbox cash waiting
- 4wd sierra fuel rail & regulator wanted
- 4x4 engine loom, rad fans
- Fiesta RS turbo oil swirlpot
- Sierra heater box/matrix
- BORBET A'S 17 in for a three door - where from ???
- Recaro head rest
- mk4 rst bonnet
- 3dr fibreglass panels...
- Swirl pot - RS Cosworth
- cossie swirl pot
- WANTED Cosworth T34 Turbo
- Bailey or collins dump valve for s2
- T3 s2 turbo wanted
- anybody got any sharktooths for sale!
- fiesta rs1800 badge
- delete
- 4" outward rolled back box
- cosworth 4x4 bellhousing
- Mondeo / escort gti, cosworth style centre caps
- Escort cosworth compression struts
- rs turbo amal valve - mfi
- Fiesta Turbo flywheel and CPS&bracket needed urgently
- fuel cell
- Wanted s2 engine or bottom end asap
- cosworth 4x4 wheels (sharktooths)
- Povety Spec Mk3 Escort Ashtray WANTED!
- final drive
- Focus Rs inlet manifold
- 5 / 6 spoke comps
- Rear coilovers and rear strut brace + alloy petrol tank
- YB 2wd Inlet Cam
- samco cosworth
- l8 ecu wanted
- 1 old style comp and grp a wheel nut
- black carpet for a saff..
- Pectel board for Level 8 ECU
- Escort Rs Alloy Rad & Koni's/Coilovers
- 3 door sierra amp
- wanted: Silvertop performance exhaust Manifold
- Uprated Throttle Body for Fez RS1800
- s2 90 spec ecu
- wanted.. mondeo mk3 original stereo
- Fiesta RS Turbo Alloy Radiator... FOUND ONE!
- Escort mk4 fuel filler neck
- Escort s2 rs turbo chrome slam blanking panel plates
- escort rs turbo suspension
- Escort Cosworth rear brakes backing plates
- 4wd sapphire front drive shaft flang
- anyone breaking a 4wd saf?
- 195 45 16 legal / part worn tyre
- MK 4 Escort Front Panel
- 88 Spec door cards, rear bench please.
- T38 Boost Hose *required this weekend*
- Wanted: set of green injectors
- Rs turbo shell
- cosworth main crank cap bolts !!!
- Anyone got a ford fair track session ticket for sale?
- 4x bmw 5 stud steel or alloys 15 or 16"
- Sapphire offside rear jacking point cover
- 3 door sierra, front indicator bulb holders
- argon gas
- Escort cosworth thermostat housing urgently needed
- 4x4 bonnet
- drivers side door handle for saf
- Rs turbo konis
- coilovers for fez turbo
- wanted focus rs
- 1 x 2WD Piston and Rod + 1 x 4x4 Piston and Rod
- Big Spec Rs Turbo Wanted (Escort or Fiesta)
- 2wd cosworth turbo heatshield
- 044 fuel pump wanted
- 205 / 200 bottom end
- saph n/s clear indicator. genuine ford please
- rs turbo b&m quickshift
- 2x 245/275 30/35 18 all considered
- mk1 focus rs front bumper
- mk3 escort dashboard
- good consition offside front driveshaft 4x4 saff
- Escos wrc wing mirrors
- xr2
- sat nav wanted with europe maps on it
- S2 90 Spec Door Cards
- escos alternator bracket(one with auto tensioner)
- Cosworth turbo cooler airtec/pro alloy
- ford racing water temperature gauge
- Escort exhaust, prefur magnex or similar concidered to fit mk6 gti
- mk3 windscreen wanted
- new fiesta turbo throttle cable
- wanted small turbo cosworth rocker cover
- Mk1 Orion Parts NEEDED URGENTLY!!
- Ford Escort S1 Rs Turbo Parts Wanted!
- Azev locking key and RL7 center caps
- urgent T34 or T35 standard turbo
- *WANTED URGENTLY* Mk4 Escort fog light switch (In dash)
- 3 door sierra heater adjuster
- Swedish Plenum Required
- l8 or p8 ecu wanted
- iphone 4
- part needed asap
- Ford fiesta rs1800 wanted
- long shot cossie running gear
- cvh cam pulley
- s2 rs turbo engine
- Carbon roof
- 1.8/2.0 silver top zetec
- Fan switch sensor plug needed
- s2 90 spec drivers doorcard
- t3 manifold and t3 exhousing or cosworth downpipe
- efi throttal pedal and cable
- A pair of brembo ap or similar calipers
- Any one got a good mondeo tdci injector for sale?
- steel conrods
- Escort rst bit wanted
- Cheap rotbox saff wanted in scotland
- Escort rs turbo coilover suspension
- Escort rs turbo leather interior
- s2 rst fuel accumulator
- saff and 3dr ambers wanted
- Cosworth 3dr grille
- Rear lights
- Street/Sport Ka Clutch pipe please!
- Capri/escort old skool alloys
- saff 'c' pillar trim n/s
- Leather Saph seat wanted
- secs monitor
- 044 pump
- Escort MK3/4 Rollcage
- wanted
- very nice rs1600i
- anyone know of any nice rs1600i for sale?
- anyone want to sell COD modern warfare 2 for the PS3?
- 3inch cosworth down pipe
- VSS for A4LD auto box 1992
- s2 turbo
- Escort Mk6 Parts
- 1 MO 6 spoke old style et35 8x18 needed.
- escort/fiesta/sierra outer door handles plus more
- Stainless cambelt cover for 3dr sierra
- can anyone help
- Escort cosworth genuine ford clutch cable
- 3dr sierra cosworth genuine speedo cable
- escort xr3i EFI engine box - mk 4
- Nintendo DSi XL
- anyone got a saph rear bumper
- saph rear spoiler
- escort cosworth driver side drive shaft
- Cosworth rocker cover with no breather hole
- Silverstone - Anyone got any tickets i buy & sell??
- escort series 2 interior wanted
- Slam panel to crossmember steady bar for Saff
- S2 mk4 Escort Black panels
- Lifeline zero 2000 fire extinguisher nozzle 6mm
- 17 inch 5 spoke comp mos et 37 to et 40
- wanted turbo and gearbox
- Focus rs engine wanted standard or big spec why?
- rs turbo wheels ( moved )
- Cossie downpipe/exhaust WTD, pref damaged.
- Any unwanted sierras about?
- Set of cosworth injectors (yellows)
- group a k&n
- silvertop zetec manifold
- fiesta zetec-s rear bumper
- fiesta 1.8 diesel 3dr N95 MOT feb2011 some tax £300
- saph 4x4 cosworth heat sheild
- 3dr SIERRA COSWORTH REAR WHEEL STUD
- cosworth 4x4 bottom end???
- need a pair of mk1 escort wings(anybody)
- rs turbo bottom radiator hose
- Swedish Plenum
- Rear coilovers and strut brace
- xr3i 130ps or rs1800
- Pair of ford horns and Bailey turbo damper
- 3 dr sierra cosworth rear strut covers
- 3dr COSWORTH REAR LIGHTS
- Does anyone know someone stripping a 2wd saph
- Cosworth 60mm alloy radiator wanted
- wanted ford sierra roadworthy
- focus ST170 parts
- scrap saph or escort cosworth engine for mock up wanted
- toyota 3 sge turbo race engine wanted, Caldina or GT4 etc..
- Escort Cossie front bumper
- low mileage mk3 escort?
- 2x 215/35/18 any considered
- cossie down pipe.
- Stage 3 t3 and series one kit.
- XR3i Rev Gauage + Fez Turbo Mater Cylinder
- 16"/17" alloys
- Racetech Electric Oil Pressure Sender
- Suspension
- 1L silkolene pro s 10-50 local to coventry
- P8 ECU and pectel board
- 2WD rear diff mount
- cosworth 300mm rear disc conversion
- Mk1 Focus 3DR Doors
- shock absorbers needed fiesta mk4 1996
- Saff headlight strip without holes
- Escort mk5 morette's wanted
- fiesta rs turbo t2 turbo
- A excellent series1 escort rs turbo
- rs turbo wanted
- parts
- focus ST170 Hubs/knuckles(front)
- escort st alternator
- cvh efi flywheel and pickup
- erst suspension
- Ford sierra rs cosworth 4x4 rear prop shaft
- Escos aircon rad
- 2wd Diff Mounting bracket
- 2wd Coilovers and sapphire rear bumper
- Rs 2000 rear hub
- Cosworth 2wd brake pressure reducing valve
- 18 inch azev a's for escort cossie wanted
- Rs turbo alternator
- 10" x 18" Comp M.O wanted ,bent ,broken or perfect !
- need parts for escort van
- Focus rs under bumper debris tray wanted
- 4x4 cossie crank pulley
- Anyone got/know for a 1.6zetec se motor?
- sapphire rear bumper
- cossie 4x4 front bumper
- cossie 4x4 Front bumper....
- 2wd alternator shield
- anyone have good std 4x4 cos intercooler near Bristol>??
- Big Turbo - please delete the thread
- Ford granada front and rear hubs 5 stud
- High torque 2wd Cosworth gearbox
- 4WD cosworth front hub
- bonus
- escort rs turbo s1 kit,
- MK2 Focus RS /ST rolling gear wanted
- s2 parts
- Sierra Saph Scuttle Pannel
- set off 4x4 sharktooths
